Question about Sony KP-57WS500 57" Rear Projection Television
MY SONY TV MODEL IS KP-FX432M91. IT IS AVAILBLE ONLY IN MIDDLE EAST/UK, its stby lt blinks 10 time and set would not switch on. I have Replaced Q8013,Q8014, IC8005 and resistor R8051 in D board , no luck. One thing very strange, If I keep the power off more than 8 hours, TV starts working normal, it comes on at first attempt and even with repeated on/ off, tv works normal but if tv is kept off more than 15 minutes. Then problem starts and TV does not come on and to switch it On as earlier said you will have to wait for 8 hours. Next plan is to replace Driver IC8002, which is not availble in middle east.
Pls Pls Comment.
  • 2 more comments
  • arinc429 Feb 17, 2009
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
  • arinc429 Feb 23, 2009
    10 Blinks, HV PORT, Solution
    Sony asked 300 dollars to fix 10 blinking problem of TV kp-fx432M91.I decided to fix it myself on throw away basis, could not get much help for 10 blinks from Net. Bought Service Manual from net then few parts and finally above mentioned IC 8002 fixed the problem. Pls look for IC Part No. MCZ3001DB in D board, You will find two IC of same part number but look for the IC driving Two FETs of High Voltage Power supply section.
    Q8013, Q8014, R8051 and IC 8002 are the essential components for HV section and these must be checked/replaced.
    These all components cost only 12 Dollars in Middle East and 30 Dollars in USA and Sony may ask u minimum 250 dollars to fix 10 blinking problem.
  • kamgan Mar 11, 2009
    When it is switched on for the first time it works very well,but if switched off, you wait for more then 10 hours for you to switch it on again,it begun with 2min then 10min and now 10hours.what seems to be the problem.
  • phpalpha Apr 05, 2009
    I used to have the same problem and after 10 hours it would turn on and would continue working for as long as required. I have replaced the above mentioned components, and now I have the 4 blinking problem. I have checked IC Vertical Drive, LA78045 - replaced, didn't work. What can I do?
    • Sony Master
    • 5,138 Answers
    Tyoe in google bar understanding sony blinking codes.
    Posted on Feb 16, 2009
    Hi? My Sony Projection T.V model KP-FX432M91 is taking time to power on and once it has powered on it work fine.what might be the problem?
    Power button may need to be replaced. Try turning on via remote.
    Some TVs need to warm up before coming on. Hitting the power button several times may in all actuality be Turing it off and on.
    Sep 20, 2016 | Sony Kp-Fx432M91 43" Projection Wega...
    Why does my sony 45 inch screen have mostly green color?
    the color tv display used mixing of three colors, (red, green and blue). it lost one color, coomon problems: lose contact of base of picture tube or its wiring, sockets, capacitor dead in rgb section, dead video ic
    Oct 05, 2014 | Sony KP-FX432M91 Projection TV 43 WEGA, 3D...
    TV won't turn on
    Here is a link with the codes for this set and others like it:
    Personally I would suspect the high voltage block for this set is bad.
    Nov 03, 2012 | Sony Kp-Fx432M91 43" Projection Wega...
    Sony tv model kp-fx432m91 LED light blinks
    I can assist you with that problem the LED blinking is actually indicating a specific error based on the number of blinks.Let me know how many blinks in between pauses.
    May 05, 2011 | Sony KP-FX532M91 TV
    Sony porogction
    try the sony website...
    Sep 13, 2009 | Sony KP-FX532M91 TV
    My Sony WEGA KP-FX432M91 TV LED blinking few times and then turned off please help me to solve this problem Regards Nima
    You need a professional.
    Stop using the TV until it is repaired.
    Continue to use it and your problems will multiply and grow more expensive.
    Call the manufacturer to find you nearest authorized service center.
    MR. TV Sales & Service Inc
    Milwaukee Wisconsin 53405
    (414) 762-8600
    Established 1974
    Mar 24, 2009 | Sony KP-FX532M91 TV
    TV wont turn on
    Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206
    Aug 20, 2008 | Sony KP-41T65 41" Rear Projection...
    Sony KP-FX432M91 TV 10 blinks
    my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
    my email address is
    Oct 31, 2007 | Sony KP-FX532M91 TV
    Sony KP-57WS500 57" Rear Projection Television Logo
    612 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
