Question about Bunn NHB Coffee Maker
Bunn ST15 I have a bunn ST15 and wanted to know if I can use this as a pourover machine or must I use the water hookup?.
  • 3 Answers
This machine should work fine as a pour-over. Actually evaporation would be no different if the machine was hooked up to a water line as this model does not use a probe to maintain water level. And since the element feeds through the bottom of the tank, it would take a lot of evaporation to burn it out. As with all Bunn coffee makers, use somewhat regularly and they will be fine.
Posted on Apr 28, 2010
  • 131 Answers
Bunn's official position is that this brewer must be hooked up to a water line. The problem with using these as a pourover is the evaporation of the water. it doesn't take much of a loss of water to burn out the element in those models.
Posted on Feb 15, 2009
WHY HAS MY CAFE STOPPED WORKING? IT DOESNT DRIP COFFEE INTO CUP.
Sounds like your machine is congested. Consider cleaning out the nozzle or the filter.
Sep 22, 2014 | Bunn Commercial Bunn My Cafe Pourover...
How much coffee per hour does the Bunn VPR-APS Pourover Airpot Coffee Brewer brew??
Bunn's pourover airpot coffee brewer brews 3.8 gallons of coffee per hour.
May 09, 2013 | Home
No hot water pouring water into top not plumbed is that an issue? bunnctfw15-ts
If it is not connected to water then it has to be used as a pourover brewer by pouring water into the top for brewing, there will be no water from the faucet.
Apr 19, 2011 | Bunn CWTF15-TS 23000.0006
I have a VPR pourover Bunn coffee maker. I've had it many years with no problems. The cord is getting hot and popped the circuit breaker.
Most the time the plug goes bad.This is a cheap molded plug.You can pick up a new plug at the hardware store.Pick up a 120 volt standard 15 amp plug.
Feb 15, 2011 | Bunn VPR Coffee Maker
My Bunn Pour-Omatic Coffee Maker leaked all over the counter when I made my coffee. It was mild for a week or two but became very severe. I am pleased to say I followed a suggestion that I found only by...
Do you have the model and date code located on the bottom of the brewer? If you will call Customer Service at 800-352-2866 we will be able to assist you in resolving this problem.
Jan 15, 2010 | Bunn -O-Matic Corp. 10-Cup Pourover Brewer...
Filter basket overflows after cleaning Bunn VPR Coffee Maker
Some people also try adding fresh grounds to brewed grounds, resulting in an overflow. A restricter valve can be used, but a better solution is to simply pour in half the water at a time. This is what people who buy non Bunn filters do to stop overfills.
Oct 05, 2009 | Bunn VPR Coffee Maker
WE have the Bunn VPR series. It's a pourover
Hello this coffee maker has a one and a half gallon internal tank, could be one of a few problems, first thing to check is the spray head, unscrew this you may need some channel locks to get it off and check it..use a tooth pick to clear the 6 holes with any lime that may have formed...also if you use a commercial coffee company for your coffee they should have supplied you with a spring to clean the spray head tube. After checking these 2 items the next thing to check is there enough water in the tank..when the vpr is left on and not used for a few days the water in the tank evaporates..it takes approx two and a half pots of water to fill up the internal tank...try pouring another pot of water in...also turn machine off and take the 2 screws out of the top and see if there is lime blocking the drain hole in the fill pan. Hope this helps...please feel free to comment again if you have any other questions...Good Luck!!! Mike
Jul 14, 2009 | Bunn (VPRBUNN) 12-Cup Coffee Maker
Our Bunn A10 Coffe Maker has no brew timer on the left side. How can we adjust the coffe maker so that we can get a full pot?
Hello. I need to know if you have an automatic unit, or a pourover. The pourover will not have a timer at all. The difference is you have to pour the water in to get coffee out, an automatic would be connected to a water line, and you just push a start button. If it is an automatic unit, there has to be a timer somewhere to adjust the amount. Here is a web address that has your manual, and a parts breakdown should you need to find where the timer is located.
http://www.bunnomatic.com/pdfs/commercial/manuals/29079.0000.pdf
Hope that helped, and thank you.
Mar 05, 2009 | Bunn A10 Coffee Maker
Bunn NHB Coffee Maker Logo
189 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
