Question about E-Machines M5405 Notebook
Turn computer on, screen stays blank.
The eMachines M5405 is 4 years old and this is the first real problem. After turning it on it boots including the Windows sound (tune?). The only response I can get is dim flicker of screen by repeatedly pushing the mechanical switch at upper left of keyboard.
Not sure, but the flicker could be "eMachines" over the windows graphic. I can't reinstall the video driver as the recover disk is 1300 miles from me.
Any suggestions?
Thanks.........Eliot
  • 2 more comments
  • eliotfunk Feb 15, 2009
    Have not done this on a non-functional machine before. Can you point me at a place which explains how to go about this?
    I'll give it a try.
    Thanks again.........Eliot
    The only driver for download is that for a broadcom network driver.
    Well, now its a different animal. By repeatedly pressing the mechanical switch (1 to 50 times) that shuts the display off when you close the laptop, the screen is viewable as normal..... for about 5 -10 seconds. Then it flickers and goes blank again.
    I appreciate the help you have given.........Eliot Funk
  • E-Machines Master
  • 4,806 Answers
Hi there Eliot.
It does sound like a graphics issue, go here and select "downloads" for all the drivers for that computer .
http://www.emachines.com/support/product_support.html?cat=Notebooks&subcat=M%20Series&model=M5405
Post back if you have more problems and good luck!!
Posted on Feb 14, 2009
  • Lee Hodgson
    Lee Hodgson Feb 15, 2009
    If you have a flash drive or you are able to burn a data cd on the machine you are using now, download the drivers in the above link and transfer then to a USB flash or CD.
    Go to the PC which has the graphics problem and boot into safe mode (F8 on start-up) and uninstall the graphics drivers through device manager, then restart the defective PC and install the graphics drivers i told you to download.
    Good luck
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
Tip
Diagnosing a LCD blank screen problem.
Recently a 3 year old VIzio TV I bought started having problems. The set would turn on normally for a few seconds then the picture would go dark with everything else operating normally including sound. Remembering a similar laptop computer problem I diagnosed previously, I immediately suspected a defective TV screen backlight. To verify this in your own TV, get a very bright flashlight and with the TV operating in the failed blank screen mode, shine the flash light into the blank screen from various angles and distance (including touching the screen). If the LCD is still operating, you'll see a dim motion in the flashlight's reflection, thus proving it is indeed a failed backlight.
on Jan 27, 2015 | Televison & Video
Computer won't boot up/// turn on///monitor is blank
check the main power cord that plugs into the wall socket. try a known good power cord. Also, try holding the power button down for 10 seconds and try to power it back up.
Jan 21, 2010 | E-Machines eMachines Refurbished EMA...
The monitor turn off when I used more than one hour.
It is most likely caused by the 'standard' Windows Power Saving settings:
- Check your PC/Laptop 'Power Options' and Edit Plan Settings to Change the 'Turn off the display' setting to your requirement including Never Off.
- Check your Screen Saver option especially if set to Blank screen and change the timeout accordingly..
Hope it helps.
Dec 30, 2009 | E-Machines eMachines Monitor E15T4
Laptop wont boot up
Stay away from Emachines in the future. Pay another $100 and get a real computer.
1. check that nothing is in the CD-Rom drive and restart the computer.
2.Shut down the computer. Unplug the AC power. Remove the battery pack. Wait 2 minutes or until machine cools.
try powering on comp on battery alone, then try with AC power alone.
Dec 26, 2009 | eMachines eMD620-5133 Notebook
Power on emachine T6420 and moniter is blank. The moniter soon loses contact with the computer. The fan run and power is OK there is no beep code.
If you mean after the computer performs the self test the screen goes blank and stays blank, eventually turning off you are having a hard drive problem. When the computer boots you should see an E-Machines logo and/or a self test on the screen. That is done by the motherboard as part of every boot up. After that the motherboard passes control to your boot device and loads your operating system. If your computer stops booting at that point, your boot device is not working properly. That could be caused by many things - virus, hardware failure, power outage. If you really mean you see nothing at all on the screen when you press the power button your computer simply is not working at all. Open the case, blow all the dust out of it and reseat all components you can, then try again.
Jun 05, 2009 | E-Machines eMachines Desktop PC
Computer won't load. blank screen.
- Press F8 during the boot,
- go to Safe Mode,
- After Desktop is displayed,
- restart the system in Standard Mode
If the problem is still there, you need to reload the Windows with Recovery CDs.
Dec 11, 2008 | E-Machines eMachines Desktop PC
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. arnold@supportsave.com
Jun 04, 2008 | E-Machines eMachines Desktop PC
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
E-Machines M5405 Notebook Logo
382 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
