Question about Samsung HC-P4741W 47" Rear Projection HDTV-Ready Television
Greenish haze on my Samsung HC P4741W
I just purchaced a Samsung HCP4741 Rear projection TV. THe picture has a Green Haze over the entire picture and some colors do come up but its not very sharp..Does anyone have an idea on how to fix this and the Cost? and where to get parts
  • varvel_a Feb 15, 2009
    yeah i bought it second hand and It was a bumpy lift up to the third Story I am gonna call a tech out
  • 76 Answers
If you purchased it new then this clearly should not happen - if it is second hand and therefore older then the red tube could be burnt out. The convergance may simply require allignment if the set has been knocked about trying to get it to its final resting place - this would need a tech on site to set it up.
Posted on Feb 15, 2009
My 2004 samsung self focus bbe digital tv had a normal picture, but recently the screen started producing yellow images. Everything we watch is in yellow tint. The model number is HC-P4741W. If anyone can...
Check and make sure that you still have your red component cable hooked up and it is tight on both ends of cable. If cable is tight, try another cable to make sure the one you are using isn't bad. If you still have a yellow picture, stick your head in the unit and see if the red tube is lit. If it is not, you found your problem.
Jun 20, 2012 | Samsung HC-P4741W 47" Rear Projection...
DO SAMSUNG HC-P4741W TVS HAVE A TROUBLE CODE LIGHT?
if color is skewed or looks 3d its a convergence problem--select that in main menu and try to adjust--if will not adjust it needs the chips for that replaced.
Jun 07, 2012 | Samsung HC-P4741W 47" Rear Projection...
Samsung HC-P4741W has no picture and no sound
Doubt it is the convergence board. It is in shutdown mode caused by an overcurrent or overvoltage condition. It will take some troubleshooting to pinpoint the part(s) that are defective. Could also be a cracked solder joint.
Jul 06, 2009 | Samsung HC-P4741W 47" Rear Projection...
Green haze not sharp
Good Day;
Sounds like your TV has a convergence problem. If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram. Or call FACTORY SERVICE;
1-800-448-2244.
Good Luck, big IRISH. PS or get from HIT Part X480293: kit.
Aug 04, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Rear Projection TV Picture is all green with Horizontal Lines
It looks like you started out with an intermittent solder connection which may have been fairly easy to find early on. Now, unless a technican can make it come and go while tapping on the circuit board and repair the connection, it may be a very expensive shop repair.
May 29, 2007 | Samsung HC-P4741W 47" Rear Projection...
Zenith D60WLCD with blue haze over entire picture
throw the set away!the part required to repair the set is the optical engine.Zenith made alot of these sets with defective engine assemblies in wich the lcd filters burn,which cannot be replaced.The labor is also silly.Theunitrequires a complete teardown for replacment.You could buy a very nice new set for the repair bill
Feb 20, 2007 | Zenith D60WLCD 60" Rear Projection...
Samsung HC-P4741W 47" Rear Projection HDTV-Ready Television Logo
290 people viewed this question
Henry  Thomas
Henry Thomas
