Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave fails to operate
Intermittently my GE Spacemakerm microwave oven fails to operate, and no control panel functions work. During these times the vent door is cycling open and close. To restore normal operation the power cord must be pulled and left disconnected for a few minutes. The microwave will then operate normal for a period; and then, repeat the problem.
The unit was purchased new at Home Depot and worked fine for about a year. A GE repair man tried to fix it at a cost 0f $125.00, but the problem persists. The filter was replaced which seemed to help, but did not fix the problem.
Is the a simple answer or should this just be a confusion that owners of this model of oven must tolerate? I hope not. Any answers would be very much appreciated
  • William Miller
    William Miller May 11, 2010
    What is your full model number from the tag on the unit?
    What did the repair man do to the oven?
    The repair center should have a guarantee on their work - did you call them about that?
    I would suspect that you have a failed electrolytic capacitor on the control circuit board (smart board).
    We see this kind part failure often, and it causes odd buzzing and odd operation, depending on the model.
    We regularly repair such control units for
    customers nationwide by mail for $39.95 postpaid in about a
    week with a one-year guarantee.
  • 137 Answers
Sounds to me like a controller problem, if you paid $125 to have the oven fixed and it didn't get fixed, myself I would raise hell.
Tell the repair guy to come back out and fix the thing, I understand about the "call out" charge, and I sure wouldn't pay it the second time, after all he didn't fix the problem, sorry Charlie trying doesn't cut it.
Posted on Feb 15, 2009
Microwave went totally dead while operating; there is power to the outlet.
If the control panel lights up intermittently, then you either have a loose connection somewhere near the panel, or a failing component on the circuit board itself.
Jul 10, 2015 | LG LMV1813ST Microwave Oven
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a G.E. microwave that is 2 years old that won't heat up
most likely there is a problem with the magnetron or the thermal device connected to the magnetron...this is located behind the control panel ... if all the functions are working except heat most likely the magnetron has failed.... good luck to you
Jan 13, 2011 | GE JES735WJ Microwave Oven
Turntable turns intermittently so unit will not operate
The turntable fan and light all share the same feed, first check wiring for loose connections the problem though is most likely with the controller
Dec 28, 2009 | Viking DMOC205SS Microwave Oven
Microwave runs and has functional control panel, but no heat.
The controler board, or the power supply for the magnetron has probably failed, or a safety switch is not working properly. It is also possible that the controler board is in a protect mode because of a defect.
The magnetron uses very high voltage at very high current. There is a very large capacitor in the power supply for filtering the DC for the magnetron. This area of the microwave oven is very dangerous to work on. The power supply can be lethal if proper procedure is not complied to when working on it.
I strongly suggest that you do NOT attempt to service this yourself, unless you have the proper training, test instruments, tools, and service manuals to work on it.
After servicing, the tech is supposed to verify the operating power level, and do an EM (ElectroMagnetic) radiation leakage test. This is important after servicing this type of appliance.
Take the microwave oven in for an estimate. From this you can make an intelligent decision if you are going to have it serviced or replace it.
Excellent article about microwave ovens:
http://www.betterhealth.vic.gov.au/bhcv2/bhcarticles.nsf/pages/Microwave_ovens_safety_issues?Open
Microwave Oven FAQ from GE:
http://www.geappliances.ca/faq/faq5.jsp
Jerry G.
Apr 14, 2008 | GE Spacemaker Over-the-Range Microwave
GE Microwave TimeCook defaults to Defrost Auto
It sounds like your keypad (membrane switch) is failing.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting. You can use it to test for a bad keypad.
If you'd rather have us fix it for you, we do that for $39.95 plus parts and you can visit us via our link her eon Fixya http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemeker Microwave Oven xl1800
The Control Panel is failing. The Control Panel consists of a Keypad, and a Control PC (Printed Citcuit) Board. You can replace it as a complete unit. Not Cheap!!
Good Luck!
Feb 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Spacemaker oven, Model JVM240
That would almost certainly be a problem on the control circuit board. If the bulbs happen to short / blow out or if they are removed or installed while the microwave is still plugged in, there is often an arc which causes damage to the board. We repair regularly these boards for such problems for $32.50 nationwide.
Dec 23, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
