Question about Aiwa CDC-Z127 CD Player
Mute button stuck on
I have an Aiwa CDC-Z127. my mute bottun is stuck on and i can't get it to turn off... any ideas?
3 Suggested Answers
imseth85
  • 30 Answers
SOURCE: aiwa fm/am compact disc player cdc-x304 face plate
Buy a new radio, you'll never find just the faceplate... trust me on this one it's not worth the headache.
Posted on Mar 31, 2008
  • 101 Answers
SOURCE: I have a aiwa cdc-x176m car stereo The sound is
i have never seen a car stereo with its own battery - could be something as simple as a bad ground - don't rely on the radio chasis and a screw that attaches it to the dash. make sure the black wire in the radio harness has a good ground
Posted on Oct 19, 2009
caroldon
  • 17129 Answers
SOURCE: i just got the aiwa cdc-x227 and the mute is
check for a logo that shows a speaker with a cross(X) across. just switch this back. this is also available on the remote. You could normally find this on the top side so as to mute easily when in a traffic junction. Check if this button is jammed. Also check if the display shows a mute , if not the sound reduction could be a different issue related to the audio output. check if any speaker connections are short, or speakers connections touching the body. Chek on the wiring once again with a multimeter , for any shorting, correct positve voltage and good ground. hope this helps. Good day
Posted on Jul 07, 2010
Hi Folks, I have an Aiwa CDC x204 car stereo that seems to be stuck in demo mode. I replaced the battery, so my guess is that this is the default. Upon reading the instructions, it indicates to...
This is what worked for me:
  1. Power the radio off (hold the power button in top left corner in for several seconds)
  2. Remove face plate
  3. Hold in reset 10 seconds
  4. Press push-menu dial/button 3 or 4 times
  5. Insert cd and hit source to switch to tuner before cd starts
Not all of these steps may be necessary.
I suspect having the power off before the reset button was the important part.
Sep 15, 2010 | Aiwa CDC-X204 CD Player
I just got the aiwa cdc-x227 and the mute is on.how do you unmute it?
Jul 07, 2010 | Aiwa CDC-X227 CD Player
AiWa stuck on mute - no sound from subs.
have you tried powering down unit and seeing what happens?
Dec 02, 2009 | Aiwa CDC-X227 CD Player
I have a aiwa cdc-x176m car stereo The sound is muted and cannot figure it out does it contain a battery
Oct 19, 2009 | Aiwa CDC-X176M
Which wire is the remote wire i'm trying to hook up an amp
The remote wire is blue, or blue white. If it has both, use the blue white.
Aug 17, 2009 | Aiwa CDC-Z127 CD Player
My volume doesn't change
MORE THE LIKELY THE SENSOR WENT OUT IN THE KNOB.
Jun 17, 2009 | Aiwa CDC-Z127 CD Player
No sound from my car stereo, a aiwa cdc-z137.
Doudle check rca's. Also check the setting in the menu browers. Make sure the mute overide is not on. Not sure if your model has it but is very common, and overlooked
May 13, 2009 | Aiwa CDC-Z137 CD Player
No volume
I have the same problem, it works occasionly when I move the unit around, I think it has something to do with the chasi ground, Right now I have it set decently loud to the point were I can hear the music over other noises, when I hit he power button it lowers enough to talk of a cell phone or have a conversation in the car, its not a fix, but it works as a temporary solution
Sep 16, 2007 | Aiwa CDC-Z127 CD Player
Aiwa CDC-Z127 CD Player Logo
70 people viewed this question
Top Aiwa Car Audio & Video Experts
Greg Cann
Greg Cann
buzz flewhart
buzz flewhart
Ron Lankford
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
