Question about EliteGroup P4VMM2 Motherboard
Setup s ays drive c not registering
While running setup and soon after formating setup says that drive c is not registering. Will not copy drive.cab, shuts down when certain files are copied from setup. First I thought it was a virus. but wwent out to purchase another hard drive same error
  • 31 Answers
Try original installation CD.
Posted on Feb 14, 2009
Help, really don't know what I am doing, I am trying to sort out my daughters Acer laptop for uni. I tried to copy and paste windows from C drive to D drive, It would not complete the action, so now trying...
you just can not shift windows like copy and past from drive c to drive d. if you try to delete system files of windows it prevent action what may create damage to run windows properly. Keep your windows in drive c and if you want to remove copied files of windows from d, just format it. before format copy other files without windows as everything will erase on drive d. to format just right click of drive d> select format from menu. then copy back necessary files. Note: windows is system software called operating system, you can not setup or use to copy like other files and folders. Number of system files are hidden there.
Aug 23, 2013 | Acer Aspire 9410-4317 Notebook
Included "Start Lacie" file not
Format the drive with win XP or use a third-party HDD software like partition magic.
keep in mind that the choice of a correct file system is very important, "NTFS support volumes up to 16EB" while FAT12 is limited to 32 MB.
Keep me posted!
May 28, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I stopped the formating of my hard drive and then try to reinstall windows xp, the set up stays at 27% at copying driver.cab. it been more then hour it running.
You may have to try formatting your HDD again. If you have bad sectors on the hard drive, an incomplete format will not be able to flag back sectors so your windows install might be trying to copy to a bad location on the HDD. (speculation) your HDD may have no bad sectors, but this is one example of what could happen with an incomplete format.
You might also have a dirty install CD. take the CD out and look at it. If it is full of finger marks you might want to clean it and try again.
Chris
May 19, 2011 | Computers & Internet
My desktop computer by eMachines is running super slow and is not connecting to the internet. What can I do to fix it? I have cleaned it..but does not work.
Your desktop is affected .
Try to system restore in earlier date. Follow the step
How will you confirm?
Follow the steep. Press win key +R >type gpedit .msc and soon an windows will open.
Press win key +R>ms config and soon an windows will open.
Press win key + R REGEDIT an windows will open soon.
Go to tools option >folder option >view>check on show hidden file
Check off hide protected operating system file
Check off hide extension known type file.
BUT still there are no hidden file in drive C:
Think your computer has affected by serious virus.
>start>program>accessories>system tools >system restore >set earlier date. If you have the strong virus you can not do that, then you should better to copy your data if necessary
follow step>set your hard disk in another computer .before install be ensure that .another pc is well condition.
>show hidden folder can see all system file >can open task manager>run type ms config >enter, it will be open windows>run type gpedit.msc> enter, it will be show.>run type regedit enter ,it will be open .think your another pc run in ok condition. Then type gpedit.msc and hit >administrative templates>system>turn off auto play>select enable>click down arrow >select all drives.
SET IT FROM BOOTH SIDE BECAUSE THERE ARE TWO SIDES >Go tools> 1 folder options>views>check on show hidden files and folders>2 check off hide extension >3 check off hide protected.
Now auto run program off. you can see and delete easily all the hidden unnecessary file .auto run file. Placed virus affected hard disk in this pc.explore drive select autorun/recycler/system volume information by dragging and delete it. Don't do the system drive for ensure r click on my computer >manage>disk management>identify system drive >and system drive letter>
Now You can copy your file and store in another drive which formatted emediate.And you can format drive one after one and transfer all the file to the formatted drive .Switch off the pc and put your pc again and install your os and set the pc same way Then type gpedit.msc and hit >administrative templates>system>turn off auto play>select enable>click down arrow >select all drives.
If you did not have the cd rom , you should create a bootable flash. follow the link.
http://articles.techrepublic.com.com/5100-22_11-5928902.html
If you want remove manually 1st click here or http://amiworks.co.in/talk/how-to-remove-new-folderexe-or-regsvrexr-or-autoruninf-virus/
If you want remove manually Autorun virus 2nd click here Or http://www.wikihow.com/Remove-Autorun-Virus-from-Hard-Disk-Drives
You want to save your data download
http://www.hiren.info/bootcd-on-usb-disk
Write cd with the ISO and restart pc cd will start soon, click here or http://www.windowsreinstall.com/articles/bios/ for BIOS SETUP and go mini windows and deletesystem volume information and RECYCLERfrom all drive except "C"
drive. Because Heart Of Castle.If can not remove download bootable f cecure,click here or http://www.techmixer.com/free-f-secure-rescue-bootable-cd-to-clean-virus-and-malware/ b> And write the ISO and boot from CD at the start time. SET THE BIOS SETUP for BOOT FROM CD
http://www.windowsreinstall.com/articles/bios/ DONT USE KAV because it will delete your windows file
Now you will install and just delete C drive and create C drive same andinstall.
Installation guide click here.http://www.microsoft.com/windowsxp/using/setup/winxp/default.mspx
Hope this helps.
May 14, 2011 | eMachines Computers & Internet
AutorunRemover Autorun Virus Remover license code
Your note book is virus affected.
If you want remove manually Autorun virus 2nd click hereOr http://www.wikihow.com/Remove-Autorun-Virus-from-Hard-Disk-Drives
drive. Because Heart Of Castle.If can not remove download bootable f cecure,click here or http://www.techmixer.com/free-f-secure-rescue-bootable-cd-to-clean-virus-and-malware/b>And write the ISO and boot from CD at the start time.SET THE BIOS SETUP for BOOT FROM CD
http://www.windowsreinstall.com/articles/bios/DONT USE KAV because it will delete your windows file
Hope this helps. Let me know if you need more informationThanks
shibuda
May 11, 2011 | Computers & Internet
It does not format and gives an error of G/: is not assessable. and volume does not have recognized file system
Your pc has afected by virus so clean pc .
You want to save your data with out Format all thepartition ,download hiren boot, from the bellow link.
Now burn the ISO file, under image burning option,from nero ,in the another pc which is run's well. Restart pc, the cd will start soon, if the hiren boot cd ,willnot run, set bios setup. Now click herefor BIOS SETUP ,restart again and select miniwindows and delete system volume information and RECYCLER from all the partition or drives except "C"drive(Partition C:)
Because "systemvolume information" and "RECYCLER" is the Heart of Castle. If it not removethe virus ,download bootable f secure,click here And write the ISO under image burning option,from nero and boot from CD. Now you can scan for fix.
Insall clean OS, delete partition C: and create C same .
If you do not want install the OS ,download combo fixfrom bellowthe link
http://combofix.net/
Follow all the steps.Rstart the pc >press F8> select save mode usethe down arrow key .copy and paste the combofix and dubble click on it and wait for few minutes. Do not do any thingwhen the combo fix will be running.Let them do .
If you need more information, reply me soon.
Thanks
Feb 24, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Trying to install outlook 2007 run into error 1311 can not find file sku 112 cab
That cab file may be corrupted. If you have installed winrar you can extract the setup and check. Try to copy files. Locate the cab file. Get the properties. Verify the digital signature (Go to digital signature tab-> view details
Check whether the digital signature is ok.
If not you have to download another copy again and replace the cab file in the extracted folder and run the setup.
There is no other way to repair it.
please rate the answer if it was helpful to u
Jun 13, 2009 | Microsoft Office Outlook 2007: Windows
Try to format my hard drive it will not format. or at least i cannot find anything that has.. all it will do is copy over the old windows but i know there is a better way to clear everything off!
go into the control panel. click administrative tools. open computer management. click the tab called disk management. make sure the drive you want to format isnt the system drive. (it wont let you format while running) and format the drive from there. you can also choose the drive letter you want to format to. very useful if you are a neat person. (C: MAIN, D: documents, M: music, Z: dvd writer, V: virtual memory.........)
Aug 13, 2008 | Computers & Internet
EliteGroup P4VMM2 Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
