Question about Bernina Sewing Machines
I am looking for an instruction manual for a Bernina minimatic 807 sewing machine. Can you help please
  • Anonymous Mar 14, 2014
    Ineen instruction for overlocking on a Bernina sewing machine 807 please
Can any please tell me where I can purchase a manual for a Bernina Artista 200 Manual as I accidently threw my away.
Regards Cathy
Posted on Feb 15, 2009
Which model old style cam type buttonhole attachment from Singer will fit on the Bernina 807 minimatic machine that is an equivalent to the singer featherweight that I can make keyhole buttonholes.
In my earlier response, you need a shank that is made for your Bernina 807 and Berninas made in that era. Only "Old Style" Bernina presser feet and adapters will fit your machine. No other brand will work, not Singer, not Janome, not Brother, nothing but Bernina Old Style. There are several Bernina old style presser feet. Look for presser feet with the number printed in black ink or presser feet that have the number stamped into the metal. Do not buy a Bernina presser foot with red numbers--will fit only newer Bernina machines.
If you want to use the Singer buttonholer attachment, it needs to be for a straight shank machine. You will need to have a Bernina shank adapter for your machine.
Bernina Presser Feet (down at the bottom of the page, click on the blue text that says "Bernina Shank Adapter" On the next page, scroll down to the last two items that indicate they are "Old Style." The first Old Style item is the shank adapter you would need to attach the Singer buttonholer attachment to your machine. (Am assuming it will work, no guarantees!) If it doesn't work, then you will probably not be able to use the Singer buttonholer with your Bernina machine.
This shank adapter would fit your machine:
http://www.ebay.com/itm/Adapter-Low-Shank-Feet-Foot-Bernina-500-1630-Old-Style-/380397208368
If you are looking for a snap-on adapter, it needs to state that it will work with a Bernina Old Style machine, ie the old Record machines (930 Record, 830 Record, 730 Record, 707, 807 Mini, 630 Record, and 530 Record--or in other words, Berninas manufactured prior to probably 1996).
Bernina Presser Feet (down at the bottom of the page, click on the blue text that says "Bernina Shank Adapter" On the next page, scroll down to the last two items that indicate they are "Old Style." If you are looking for the snap-on, go to the very last item on the page (Old Style). This will fit your machine. Remember, if it says Old Style, it should work on your machine.
This snap-on shank will fit your machine:
Presser Foot SNAP ON SHANK Adapter Bernina Old Style 530 532 1630...
This presser foot will fit your machine:
http://www.ebay.com/itm/BERNINA-ORIGINAL-20-SATIN-DECORATIVE-STITCH-FOOT-OLD-STYLE-830-1530-930-etc-/132055492681
This is an entire kit of snap-on feet with shank (included) that will work on your machine:
http://www.ebay.com/itm/20-Feet-Set-for-Bernina-Sewing-Machine-Old-Style-530-1630-Models-/381790565625
Here is a kit of snap-on feet with shank (included) as well as the buttonhole attachment you were asking about:
17 Feet Set for Bernina Sewing Machine Old Style eBay
Although, I believe you will be able to make only straight buttonholes with this buttonhole attachment.
Hope this helps.
Jan 07, 2017 | Singer Sewing Machines
How is it possible to replace the light bulb in the Bernina minimatic 807? I managed to remove the dead bulb, but cannot install the new one
Try using rubber gloves, like surgical gloves and moisten them slightly. Usually, that will provide enough grip while trying to insert it. Very difficult from experience. But, can be done.
There is a bulb insertion accessory tool included with some newer machines (although not Bernina--another brand) that is basically like a cut-off plastic chopstick with a suction device on the end. If you are creative, you may be able to fashion something of your own.
Dec 22, 2016 | Bernina Sewing Machines
How do I remove the top on a Bernina 807 in order to chnage th elong belt ?
V-Belt replacement 801/801 Up Machines
Only the belt cover needs to be removed for this belt change. This is done by removing the three screws on the end/belt cover. Loosen the 5mm Allen socket head screw below the step pulley to relieve the belt tension. Remove the lower motor belt. Lift the step pulley and slide off the hand-wheel, (assuming that you have already removed the release knob and clutch ring).
Additional top cover removals 807/801 Minimatic machines
Early 807 machines had two expansion nipples in the top cover that fit into receptor holes in the upper arm frame. Simply pull up the top cover.
Very late models may have a push button latch mechanism, same as on the 801 machines except those fitted with carrying handles, i.e. 801 Sport, 810 machines.
This is accessed by opening the light cover and finding an aluminum knob in the upper left hand corner of the upper arm frame. Push this in and the cover will release. Lift off the top cover.
Sep 10, 2015 | Bernina Sewing Machines
I need carbon brushes and a service manual for a Bernina 807 Minimatic sewing machine. Where might I find them?
You might be able to find the brushes from AllParts. Good luck on the service manual. You might get lucky and find a book on ebay but it's not likely.
Nov 10, 2012 | Sewing Machines
I need a new or reconditioned motor for a Bernina minimatic 807 where do I look? Thanks
Try www.Sewingstyle.com. They carry a lot of parts for new and old machines. If they don't show it on their sight, drop them an email or call them. They may surprise you.
May 11, 2011 | Bernina Sewing Machines
How do I use the button hole foot on the Bernina 807 minimatic?
There isn't an automatic button hole on this machine. You can do it manually. Thread the bobbin thread as usual, but put it through the little hole on the hook in the bobbin case. Set the stitch length between 0 and 1, like a nice satin stich. Set the needle position to the far left and the stitch width to 2. Sew down the left side. Center the needle, set the width to 4 and lower the feed dogs, stitch about 6 stitches across the bottom. Then reverse the direction, set the needle to the right, stitch width to 2 and go back up the right side. Lower the feed dogs again, set a wide stitch and finish the top.
Another good option is to buy a universal presser foot shank from Bernina and then attach an old cam type buttonhole attachment from Singer. They make beautiful buttonholes and you can even do a keyhole button hole.
Jun 29, 2010 | Bernina Activa 130
Bottom thread showing through in a loop
If you had just changed the thread, try re-threading or just raise the presser foot (this opens the tension) and pull about 6 " of thread through the needle.
Foot down closes the tension to the setting you have selected.
If this does not work, the machine will need to go into the shop.
Berninas hold their value better than any other brand, so be sure to go to an authorized Bernina dealer for service and repairs.
Mar 26, 2010 | Bernina Activa 130
I have a bernina minimatic 807 (old), and am trying to change the bulb. It is really hard...got it out, in pieces, but it'd be really nice to take the door off...which I think I can if I can lift the top. ...
Oh my gosh--how simple it is:
https://www.youtube.com/watch?v=i4YuJS02jt0
However, perhaps the manual would be helpful:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjYqvrshIfRAhXj44MKHQ0TCEMQFgguMAA&url=https%3A%2F%2Fwww.bernina.com%2Fen-US%2FSupportData%2FOut-of-Print%2FBERNINA_807_810_817_manual&usg=AFQjCNFNJyvVESPeSjAOPQT2cX5Z3rclbw&cad=rja
While you have the machine open, it might be a good idea to apply a couple drops of good quality sewing machine oil or (better yet) liquid Tri-Flow Synthetic Lube to every place where metal rubs against metal. (Slowly turn the handwheel and watch the movement.) Also look for the oil port holes throughout the machine an apply a couple drops in each. Do NOT oil the plastic gears or belts!!! Also, move the stitch selector and feed dog levers and hit those with a little oil too. This will keep your machine happily humming!!! You'll probably notice how quietly it runs afterward!
Mar 11, 2010 | Bernina Bernette Deco 600
Hello, Have you an instruction manual for the Bernina 807 sewing machine. Thank you. Regards, T.W.
I went to Berninausa.com and there they listed manuals for the Bernina 820 and 830 only. Maybe the manual is close enough for your model.
Oct 25, 2009 | Sewing Machines
Sewing Machines Logo
444 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
