Question about Garden
Chainsaw Bar Lube Oil Leaking
I purchased a used chainsaw. Started and ran fine when the guy sold it to me. When I got home and filled it with chain lube, it leaked out as fast as I poured it in. I removed the cover, chain and bar. The bottom of the mounting bar plate was sheared off and the chain catcher was also missing a chunk out of it. I can see the where the lube is leaking from when I removed the mounting bar plate. It looks to be about a 1/8 inch diameter hole where the lube is probably supposed to come out of. The hole is not threaded so it does not look like a screw of any type was initially in it. The problem is that the hole is wide open with no kind of check valve or anything else in it regulating the amount of lube. Is this supposed to be this way? Do all I need is a new mounting bar plate to fix the problem or is there something else missing from inside the lube's holding tank?
Thanks
  • choochmm Feb 15, 2009
    Thanks for the quick response. I am going to order one asap. The darn thing only cost's $0.77.
  • choochmm Feb 22, 2009
    Well, I installed thenew mounting plate and it stills leak around the bottom of the plate. When I look at the hole behind the plate, I get the feeling that there is something missing from that hole so that the lube does not all pour out. Does anyone possibly have a picture of a chainsaw where the mounting plate has been removed so I can see if I am missing another part?
    Thanks
    President:
  • 1,902 Answers
A new mounting bar would solve this issue. On that mounting bar there is a little piece that allows oil to drop onto the bar when you call for it or if this is a electric bar oil chain saw. Then it tracks when it needs to open.
Posted on Feb 14, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 15, 2009
    lol expensive buy. Chain saws are really easy to work on and are pretty dang cheap to continue to keep up and running.
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Poulan Pro Chainsaw PPB1838 Bar Lube Leaking Out
If this is a Poulan as listed I would go to psep.biz and look at a schematic for the tool. You would need the model number and type number but their breakdowns are good.
Posted on Feb 15, 2009
dontbother10
  • 2220 Answers
SOURCE: Husqvarna chainsaw 440e - enough chain lube?
That seems low to me. Page 15 in your manual is the only oil discussion I found. Usually there is an oil pump adjustment reference somewhere. I didn't see one beyond return it for service on page 15. Are the chain and bar hot after cutting a while? I recommend you not get a longer bar without an oiler adjustment. I think the hand of the EPA has been here.
An IPL (exploded parts list) for a 440 can be found here:
http://weborder.husqvarna.com/order_static/doc/USA/2009/I09000/I0901018.pdf
There is no oiler adjuster listed. HTH
Lou
Might be a good idea to copy the IPL,
Posted on Oct 07, 2009
Testimonial: "thanking you"
I need to remove the automatic oiler in my homelight chainsaw z3850b
Chainsaw Oil Pump Replacement - Homelite ... - YouTube
? 5:57
https://www.youtube.com/watch?v=8dj0Voh3TTM
Jan 21, 2014 - Uploaded by RepairClinic.com
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
How to Repair a Homelite XL Chainsaw Oiler - Home Guides
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Dec 21, 2015 | Garden
What oil please
Best to use proper chainsaw oil to lubricate the chain cutting in the wood, but at a pinch you can use multigrade car engine oil. Don't use secondhand oil as the added acids,pollutants, etc., from the engine will break down the oil making it less efficient....and leave staining on the wood.
Chainsaw oil can be readily bought from good garden centres.
Hope this helps.
Jul 14, 2014 | Ryobi 18-inch Electric Chainsaw Chain Saws
What kind of oil do I use and how much should I add?
Hi natcarc2003...
You will use "Bar and Chain Oil",it is used to lube the chain and bar of your chainsaw as you are using it.
You will push down on the top of the oil fill lid to push the oil onto the bar and chain.
It can be bought at any small engine repair shop, WalMart,KMart,HomeDepot,Lowes,etc.
You will fill the reservoir with the oil till it is about 1/2 inch below the surface of the opening of the oil fill on top of the chainsaw.
Please take time to rate me thumbs up
Sep 10, 2011 | Remington Electric Chain Saw
1.5 hp poulan electric pole saw - what type of oil do you put in?
Hi kim 1481...
You will use "Bar and Chain oil"...it will lube the chain and bar of the electric chainsaw.
You can find it at Ace Hardware,Lowes, Home Depot or your local hardware store.
Aug 21, 2011 | Garden
Oil leaking out by bar all the time
if its leaking out the bottom were the bar goes in too the chain saw this is normal this is the bar lube oil its thicker that regular oil and sticky U should have a screw plug marked lube for this
Apr 05, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What oil does a ryobi cs216 electric chainsaw use ?
if you are talking about the bar chain oil (?) --- then all you need is just that ' bar/chain oil ' ,, you can get it from any hardware store that sells chainsaws.
now out here in the middle of nowhere Alaska where I am,, we just use used motor oil from our generators as a bar chain lube and it works just fine, ( not my ideal thing to use , but that is what the boss says to use and after 3 years here and using it -- I have not had any issues with our 4 saws that get over 3000 hours of use every year ).
I say -- use only good,clean and new bar chain oil.
c...
Jan 18, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
What type of oil do I use for the blade?
Don't use car oil or anything else,but the recommended purpose lube,which you can pick up
at any home improvement store. The oil has a special
viscocity,which will work properly in the chainsaw.
Apr 01, 2010 | Remington Electric Chain Saw
Lou
Oct 07, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
What type oil do you need for an electric chainsaw?
you need to buy chainsaw lube oil, its red and lubricates the chain.chainsaw chain lubricant. plz rate-bozcro
Sep 10, 2009 | Heavy Machinery
Feb 14, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
1,338 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
