Question about Toshiba 46HX83 46 in. Rear Projection HDTV-Ready Television
How to remove screen
I've removed 8 screws, but the screen is still attached at bottom...can't tell what's holding it on !
  • Toshiba Master
  • 5,138 Answers
You still have several more underneath screen remove them and slide screen upward and out.
Posted on Feb 14, 2009
How to install a center console on a pacifica
Hi Melissa, I'm glad to help, here is the instruction below I said I'd send. Have an awesome day.
23 - Body/Interior/CONSOLE, Floor, Front/Removal REMOVAL [img id=LOPTableImg src="https://w05.dealerconnect.chrysler.com/service/mds2002/common/images/collapse.gif"> Click to display a list of Labor Operations associated with this procedure 1. Remove shift bezel. (Refer to 23 - Body/Interior/BEZEL, Shifter - Removal) .
2. Remove transmission range indicator surround bezel Figure 1.
3. Remove two screws attaching front floor console to the lower instrument panel Figure 2. 4. Open cup holder and remove two attaching screws to bottom of cup holder. 5. Open bin and remove two attaching screws to bottom of bin. 6. Remove front floor console sidewall attaching screws, three per side. 7. Raise front floor console and disconnect wiring harness. 8. Remove front floor console from vehicle.
374297.jpg Figure 1 - TRANSMISSION RANGE INDICATOR SURROUND BEZEL 1 - INSTRUMENT PANEL 2 - AUTOSTICK SHIFTER ASSEMBLY 3 - TRACTION CONTROL SWITCH 4 - TRANSMISSION RANGE INDICTOR SURROUND BEZEL 5 - KNOB SET SCREW 6 - SHIFTER KNOB 7 - FLOOR SHIFT BEZEL 8 - WIRE CONNECTOR 9 - INSTRUMENT PANEL WIRING HARNESS 10 - INSTRUMENT PANEL WIRING CLIP
374299.jpg Figure 2 - FRONT FLOOR CONSOLE 1 - FORWARD CONSOLE CLOSEOUT PANEL 2 - CLOSEOUT PANEL PUSH PIN RETAINER 3 - INSTRUMENT PANEL WIRING 4 - FLOOR CONSOLE BASE 5 - FRONT FLOOR CONSOLE ATTACHING SCREWS TO LOWER INSTRUMENT PANE AND BASE 6 - FRONT FLOOR CONSOLE WIRING CONNECTOR 7 - FRONT FLOOR CONSOLE 8 - ATTACHING L-BRACKETS
May 17, 2014 | 2006 Chrysler Pacifica
How to remove the bottom of the gatwway lt2016u
Ok, on a laptop you need to get some cups and label them toput the screws in so you will know where they came from. Remove the PowerCord, Remove the Battery then start removing all thescrews from the bottom of the laptop. Then remove all the devices fromthe bottom of the laptop such as the hard drive, the memory, dvd/cd drive,wireless card, etc. Take note of how the wires are on the wireless card,those are the antennas.
Look inside the battery case, hard drive case, memory case and dvd drive slotfor screw. Some screws on the bottom case in inside of some of the devicecases might have the icon of a keyboard next to it. Those screws hold thekeyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but becareful because a cable might be attached to it. Then remove the screwsthat hold the keyboard in place that are under where the strip was and gentlylift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift thelcd screen off, also note that you will have to pull the antennas cable and thelcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note ofany cables that are attached to the palmrest and remove them then lift thepalmrest off.
Next start removing any screws you see that hold the motherboard to the bottomcase, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory ofwhere things were.
Jun 09, 2012 | Gateway Computers & Internet
How do I disassemble my netbook?
Jun 08, 2012 | Computers & Internet
Remove the cover on an emachine e525
Umm, well there are things like the motherboard and plamrest that have screws in them that might be holding it. You just can't remove the bottom cover, You have to start by Removing the bottom screws like you did, but then you have to remove other things before you can get the bottom case off. Also the VGA Port might have screws on both sides of it that keeps the bottom case from coming off.
Below are some steps to follow.
Look inside the battery case, hard drive case, memory case and dvd drive slot for screw. Some screws on the bottom case in inside of some of the device cases might have the icon of a keyboard next to it. Those screws hold the keyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but be careful because a cable might be attached to it. Then remove the screws that hold the keyboard in place that are under where the strip was and gently lift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift the lcd screen off, also note that you will have to pull the antennas cable and the lcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note of any cables that are attached to the palmrest and remove them then lift the palmrest off.
Next start removing any screws you see that hold the motherboard to the bottom case, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory of where things were.
May 31, 2012 | Computers & Internet
Disassemble
May 16, 2012 | ASUS M3000Np Notebook
Regarding to http://www.fixya.com/support/t9259110-sony_vaio .. how will i remove the case to remove the cooling fan?
Ok, on a laptop you need to get some cups and label them to put the screws in so you will know where they came from. Remove the Power Cord, Remove the Battery then start removing all the screws from the bottom of the laptop. Then remove all the devices from the bottom of the laptop such as the hard drive, the memory, dvd/cd drive, wireless card, etc. Take note of how the wires are on the wireless card, those are the antennas.
May 03, 2012 | Computers & Internet
Clean my laptop keyboard stisky
LOL, you shouldn't eat and drink over your laptop. Count your blessings that you didn't shorten your motherboard out. The best way to clean it is to probably take it apart from the computer.
Remove the power cord, remove the battery, then turn the laptop over and start removing screws from the bottom. Look inside the battery case and there might be screws there, specifically there might be some with the icon of a keyboard. Once you have the screws removed, turn the laptop over and open the lid, then pry off the strip that is over the keyboard just under the lcd screen. Once you remove it you might see more screws that hold the keyboard in place so remove them. Once all screws are removed, lift the keyboard gently because there will be a cable underneath it. Remove the cable that is attached to the keyboard and then you can clean it. I would use something like a toothpick or Q-Tip cotton swab and maybe some rubbing alcohol. You'll have to hold keys down that are around the key you want to clean to get under the key you want to clean that is stuck. Once you've cleaned it press it repeatedly to make sure it does not stick.
Apr 18, 2012 | Computers & Internet
How do i get the front screen off of a 46 inch zenith rear projection tv. it's 13 or 14 yrs old
First, unplug the unit.
Then remove the speaker grills. At the bottom of the screen there should be approximately 8 -10 +/- screws. Remove these screws and the screen should lift right off. Before unhooking the screen at the top, be sure to check that no sensors are attached to screen assembly and have a friend hold the screen while you unhook the two connector plugs that go into the back of the screen.
Jan 17, 2010 | JVC HD-61Z786 61" Rear Projection HDTV
RTC battery replacement
The RTC batteries don't usually go bad on these things. It is attached to the sound card and is underneath the palmrest about 1" to the left of the touchpad. To get to it:
(1) remove all the bottom screws;
(2) remove wireless card door, and free the wireless antennas.
(3) turn over, set the screen to its normal position;
(4) snap off the plastic cover strip above the keyboard;
(5) remove the 3 screws that hold keyboard down;
(6) disconnect the power button board's skinny cable;
(7) remove the aluminum lid to the CPU heat sink (4 screws);
(8) disconnect the speaker cables;
(9) remove the one screw directly behind the cd-rom drive;
(10) disconnect the LCD's cable connector.
Now you can separate the top half of the computer from the bottom half. Be extra careful not to tear/damage/rip the wireless antennas.
After that, you'll see the RTC (CMOS) battery - it's green, round, with a black and red wire attached to it. Can't miss it.
Feb 06, 2009 | Toshiba Satellite 5005-S504 Notebook
Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Mar 14, 2008 | Dell Inspiron 1000 Notebook
Toshiba 46HX83 46 in. Rear Projection HDTV-Ready Television Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
