Question about Proscan 32LA30Q Television
Dvd player wont play
What channel does tv need to be set on
    President:
  • 814 Answers
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Posted on May 21, 2009
Can't change to channel 3 to use the dvd player
Your Vizio TV should have provisions on the rear panel for direct connection of your DVD player. Use those connections and select your DVD player as a video input.
Mar 08, 2018 | Vizio 42 in. LCD TV
I had DVD player hooked up to watch movies, I was trying to set a universal remote because I do not have one already. When I couldn't get the remote to work I pushed Menu on the front of the tv, chose...
Perhaps your dvd player output is set for channel 3 so you have to select that channel for the dvd player to play on your tv. Some older analog tvs have a separate input for dvd on the back or front. In that case you have to select that setting from the tv menu
Sep 17, 2013 | Televison & Video
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
shaun
Mar 06, 2017 | Zenith SY2569X TV
Sanyo Model AVM 3659G won't recognize DVD player
Let's try the easy one first:
  • verify the connections, normally yellow for video, white & red for audio. TV has to be set to Video 1, A/V or Channel 0;
  • in some instances, it could be a single coaxial cable. If it were so, the TV has to be set to Ch 3.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Sanyo AVM-3659S 36" TV
My DVD Player wont play on my tv dont know which is right channel
If you are using a scart lead then you need to set your t.v. to AV or EXT. Plug your dvd in, turn it on and using your tv controls, press av or ext until it picks up your dvd. Sometimes you may only need to press the av/ext button once sometimes 2 or three times, depending how many outlets you have on your tv and which one you have you dvd plugged into.
hope this helps
Oct 28, 2008 | Televison & Video
Need help setting up DVD-VR375 with compatible SAMSUNG TV
if it has component (red, blue, green) cables, plug one set into dvd player's "in's" and tv sets "out's'. you may have to play with the tv channels to be able to watch movie. you just change channels, go from "3" backward until you find a picture and sound.
Sep 01, 2008 | Samsung DVD-VR357
Video channel
if your DVD player supports a HDMI cable a single cable is enough for both audio and video channel.
but both your player and TV must support HDMI.
Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
Am I connecting DVD player wrong?
on some of these older RCA try simply tuning it from the remote down to chanel 01 or 00 this may work. if not you have to go into the setup menu of this set and enable the aux inputs
Feb 19, 2008 | GE 25GT240 25" TV
Dvd/vcr player is hooked up but not playing...
Yes. You definitely need to set your TV on a specific channel - GAME, in your case. Check your TV manual how to get to that GAME channel.
Jan 12, 2008 | Philips DVP3340V
New dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
Dec 24, 2007 | Televison & Video
Proscan 32LA30Q Television Logo
463 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
