Question about Kitchen Ranges
I am trying to replace the broiler ignitor on a Tappan gas range, model 30-3982-00/04 and there is not enough slack in the old ignitor to pull it out and then connect the new ignitor. I need to know how to access the wires and connect the new ignitor. Thanks,
  • 1 more comment
  • matthew_t_qu Feb 14, 2009
    I am trying to replace the broiler ignitor on a Tappan gas range, model 30-3982-00/04 and there is not enough slack in the old ignitor to pull it out and then connect the new ignitor. I need to know how to access the wires and connect the new ignitor. So far, Drumbanger's solution was to go to another site.
    I am trying to replace the broiler ignitor on a Tappan gas range, model 30-3982-00/04 and there is not enough slack in the old ignitor to pull it out and then connect the new ignitor. I need to know how to access the wires and connect the new ignitor. Yavier posted a link to another site that shows me what the wires are attached to, but not how to access that area of the oven. Is there an access panel on the back of the oven? Do you have to take the inside walls out?
    Moniter sent a link to a helpful site.
  • 370 Answers
I am service tech in grants pass oregon. What i do to make it easy is to get heat resistant wire nuts and just cut the wires off the old ignitor and then wire nut the new one in. I do this on a regular basis and it is very easy. There is no harm in doing this. It just makes it easier. It also will make it easier if you have to replace it later on too. Do this and it will fix it up.
Posted on Feb 14, 2009
    Sergeant:
  • 326 Answers
    Sergeant:
  • 250 Answers
I have a 6 yr old Tappan stove, model TGF657BFW5. the burners work fine, but the oven and/or broiler take 5 to 10 minutes to light. when the oven and/or broiler do light, the flame is only about 1/8 to 1/4...
that ignitor should lite the flame within 40 to 60 seconds if not the ignitor is bad.even though it glows red it doesn't mean it's good it works with amps change the ignitor
Nov 06, 2017 | Tappan Ovens
Oven ignitor
is the ignitor getting white hot in the center.it may not be drawing enough current to open the gas flow regulator.the only othe thing foe you to replace is the main control board.or better known as the clock timer
Jun 09, 2010 | Tappan TGF351ES Range
Ive got a tappan gas oven that wont light. The stove top burners light, but the oven or broiler wont. There is a ''glow plug'' that turns orange but the gas never ignites. What is wrong?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
gfgshg
Mar 13, 2010 | Tappan TGF320 Gas Kitchen Range
heatman101
ssgs
Feb 25, 2010 | Tappan TGF320 Gas Kitchen Range
GE gas range model JGBS10BEH2BB oven and broiler
you need to check the ignitor even if the ignitor glows it might not be pulling enough amps to call for gas replace the ignitor and this should take care of the problem
Aug 28, 2009 | GE Kitchen Ranges
The igniter in the oven of my Tappan gas range will come on but I get no gas to the oven burner
the ignitor is bad it is not pulling enough amps to call for gas replace the ignitor
Jul 09, 2009 | Tappan TGF320 Gas Kitchen Range
I have a series 30 Tappan Gas Range with a broiler pilot light that glows but does not light.
Either a weak ignitor or stuck valve. I tap on the valve with the plastic end of a screwdriver while it is glowing and if it lights the ignitor is weak. If not the valve is stuck and both should be replaced.
eric
Jun 30, 2009 | Tappan TGF657 Gas Kitchen Range
Trying to replace broiler ignitor on Tappan 30-3982-00/04
Thanks for the updated model number. I took a look at your unit and I see from the factor there is a molex connctor if you follow the wires You will see this. Might want to pull out the bottom drawer and tackle this from this area. The wires coming from the ignitor should be long enough to insert them into the hole specifically for the oven ignitor and then from the bottom, make your splice under the unit via the drawer. I hope you are a smaller guy. Been there and done that.....If I can help further, I am here.
Eric Campion
Feb 14, 2009 | Whirlpool RBS275PD Electric Single Oven
Hello, Can't find model/serial number. Older Tappan custom gas stove. Burners work but oven does not. Told it has electric ignition that could be problem. Where to find it, how to remove, where to get...
Serial number labels are usually located in any one of a number of places -
Under the cooktop in one of the corners
Inside the oven door frame (not on the door)
Behind the bottom drawer pullout on the oven, left hand side
Oven back.
If this unit is anything less than 20 years old, there will be a label somewhere.
Reply back you findings and I can give you more information as to how to repair, and we can identify part numbers. You might also try www.repairclinic.com and see if you can drill down through parts when only knowing the manufacturer.
Jan 30, 2009 | Tappan TGF363 Gas Kitchen Range
Oven won't lite
you have a bad ignitor. it may light up a little but it is not getting hot enough to light the gas. replace the ignitor
Nov 27, 2008 | Tappan TGF320 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
