Question about DXG Technology DXG-506V DV Digital Camcorder
My camera won't turn on!
I push the power switch down, the light on the side turns red. Solid red, no flashing, nothing. Then after about 20 seconds the screen flashes saying DXG and then turns off. Everytime. What can I do to fix it?
  • JRossi1984 Feb 17, 2009
    I have the same problem and have tried different batteries. I have noticed that without a memory card it turns on and off alot quicker. There must be a reset or something. I also tried to turn it on while plugged in to the computer, but have the same problem.
Check your memory card you need a sd card or mmc for this camera make sure your card is not an sd hc card over 2gb it will not support it
Posted on Mar 05, 2009
HAd been working fine turned it off came back later turned it on e light comes on blinks 14 times. unplugged it hoping for a reset. no.
14 blinks TC-P50ST30 - Badcaps Forums - Badcaps.net
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Aug 2, 2013 - 20 posts - ‎3 authors
14 blinks TC-P50ST30 Troubleshooting TVs and Video Sources. ... power button down for 5 seconds then red power light flashes 14 times. 55 inch Plasma Viera (VIERA TC-P55GT30) not turning ...
Jul 26, 2013
Sony KDL - 52W4100 powers off after turn on, gives 14 ...
Jun 30, 2013
Panasonic plasma TC-P42S30. What is killing my SN ...
Nov 9, 2012
More results from www.badcaps.net
LG 42 inch flat screen on light blinks 14 times & will not
www.justanswer.com > TV
Question - LG 42 inch flat screen on light blinks 14 times & will not - 5L. Find the answer to this and other TV questions on JustAnswer. ... First push the menu button with the sets remote and if nothing comes up then. Friend this is a very ...
Easy Common Fix for Sony TVs KDL- Red light blinking ...
? 6:32
https://www.youtube.com/watch?v=lkZWrWWvnZU
Dec 14, 2013 - Uploaded by Tampatec
Easy Common Fix for Sony TVs KDL- Red light blinking. Tampatec .... Shuts off and the red led flashes 14 times... I just want to know for sure if ...
How to fix Sony TV red blinking light on off shutdown
Dec 31, 2015 | Televison & Video
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
JBL Flip won't turn on
this doesnt help. how can i get back on?
Jan 11, 2013 | Harman Kardon JBL Flip black
Archos 70 won't turn on
I have the 8gig Archos 70, the whole thing froze as described in other posts. The solution is not for the feint of heart though. Mine would do absolutely nothing. So what the heck, I opened it up (nothing to lose at this point). Messed about a bit. Read that when it "Bricks" like this there is nothing that can be done. If it is Bricked, something locks it in the memory and function. As long as the battery is connected, it will remain that way no matter what.
Solution. Cut the black power wire from the battery (there are three long wires red white and black), leave for 20 minute, and solder the wire back together and heat shrink the joint. Reassemble, plug in power cord and it should reboot...
My archos is about 3-4 years old, and is mounted to the wall in my kitchen for use as an internet radio
Feb 28, 2012 | Archos 70 android tablet Notebook
Sanyo pcl-xu50 flashing red power light when i turn on my projector the light goes green it powers up for about 20 seconds then the power light changes to a red flashing one for about 10 seconds then back...
Projectors shut off when they overheat. They overheat when air does not move through the projector cooling it. This happens when the fans are not working or air filters/vents are not working.
Check to see whether the fans are working. If they are working, open the cover and see whether air filters/vents are covered with dust. If so clean them.
Sep 26, 2011 | Office Equipment & Supplies
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
My camera wont charge correctly
I had the exact same problem so I went searching for an answer. Here's what I found and it really did work. I had to do it about 7 times... and I read others had to do it about 20 times. But worked for them as well. Good luck!!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Jul 29, 2009 | Casio Exilim EX-S880 Digital Camera
Controller not working
I had the same problem, so I called customer service and had me do this:
1) with the USB cable plugged into the controller, power down the ps3 and turn the on/off switch in the back to "off".
2) hold your thumb down on the front button (where you normally can turn it on) while turning the switch on the back to "on" again. keep your thumb or finger on the front switch.
3) You will hear the normal "beep" that you usually hear when the PS3 boots up, but after a few seconds later, you will hear a secondary beep. Remove your thumb or finger after this second beep and the PS3 will reset itself after a few seconds. I have a projector connected to it, so I had to set the display screen back to HDMI afterwards, but when I disconnected the USB cable the controller worked wirelessly again. The customer service rep said that this allowed the controller to pair with the PS3 again. Note: You probably do not have to have the controller plugged into the USB cable at all while doing this. I just happened to have it plugged in. Hope this helps.
Mar 29, 2009 | Sony Wireless Controller for PS3
DXG Technology DXG-506V DV Digital Camcorder Logo
304 people viewed this question
Top DXG Technology Video Cameras Experts
Jose Ma DM.
Jose Ma DM.
Mike McWhinney
Are you a DXG Technology Video Camera Expert? Answer questions, earn points and help others
