Question about Amana AGR5735QDS Gas Kitchen Range
Oven light will not turn on
I do not have a manual and the oven light just stopped working. If it can be changed or a fuse needs to be changed, I just don't know how. The covering on the light does not appear to come off.
    Novelist:
  • 117 Answers
Thanks for supplying the model number. I took a quick glance at your unit and the light bulb cover screws off counter clockwise. Once off, change out the light bulb. Placing a damp rag around it allow for a much better grip.
If I can help further, I am here....
Waiting to hear from you,
Eric Campion
Posted on Feb 15, 2009
Oven has stopped heating, and automatic interior light has also stopped working. Fan still works though - any ideas?
Stove possibly has a fuse panel which is usually in the inside area of the switches and there is usually one for each burner as well as the oven. Make sure you replace with the right size fuse or you could have trouble.
May 18, 2015 | Ovens
Ge profile microwave just stopped working doesnt light up or turn on model pvm2070dmbb
You should first check the outlet with a toaster or hair dryer to be sure it's working under a load.
Then you should test the fuse then the TCOs.
There is a technical sheet hidden behind the grille or controls.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You can download GE owner's manuals and installation instructions here.
Dec 26, 2013 | GE SpaceMaker Microwave Ovens
The light bulb in my emerson 8997B stopped working. It had come backThe light bulb in my emerson 8997B stopped working.
Buy a different brand of Microwave. This is ridiculous! We are now buying a new microwave - a different brand, one that has a light bulb that is easy to change
Dec 16, 2012 | Emerson Black Microwave Oven
I have a belling 335 and both the oven and rear left hob ring have stopped working. what is likely to be the problem?
The thermal fuse inside rear is faulty. The grill also has it's own thermal fuse so make sure you change the correct one.
Sep 06, 2012 | Belling 335 Electric Kitchen Range
This cooker was fitted by Kitchens Direct last year, so is new. No manual was left by the fitters A power cut, throws the electronics out and the oven stops working. How do I get the light to stop...
Most likely, the digital panel just kind of locked up. The first thing I would try is to turn off the circuit breaker at your home's breaker (or fuse) panel for about 5 minutes and then turn it back on again. This should "reboot" it and hopefully the oven will get its brains back!
I hope this helps! :)
Dec 14, 2010 | Ovens
Our Chef Sapphire Clock & Oven stopped working suddenly after a power failure overnight. Are there any fuses to be found inside, or any other suggestions please. The stove top is fine and all 4...
This oven needs the time set after a power failure. The LED display will read HELPME and there is a small knob on the left side you need to turn it to set to change the time and use the second knob from left side to + and once done leave the knob on manual. The oven can be timed to turn off but it the time is not set on it the oven and stove do not work.dux_training.jpg
Aug 29, 2010 | Ovens
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Fuses
On the kitchen aid double oven the thermostat cut out fuse is located on top of the oven behind the control board and display. undo the srews and move it a little to the right, you will see a blower motor
sitting on top, just behind the blower sits the fuse. very easy to change, make sure the power is off to the unit before working on it. This is your problem if the oven stopped working after self cleaning. the deplay will be dead and no oven light
Jul 09, 2008 | KitchenAid Architect Series KEMC308KSS...
Amana AGR5735QDS Gas Kitchen Range Logo
314 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
