Question about Hotpoint WMA11 Front Load Washer
Hotpoint WMA11 Can anyone suggest why the machine won't spin? Have just changed the motor brushes as they were very worn. Spun first time after that with no load. Put some wet washing in and that spun too. Did a load through a whole cycle and that didn't spin. Water drains out of machine. Have tried with various loads. I know the machine has a out of balance sensor but it doesn't even work with no load at all. Just agitates.
  • philbry Feb 15, 2009
    Thanks. The motor does seem to get power but just agitates for short bursts in either direction.
    Where is the balance sensor btw? Is it mounted on the motor?
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    Is the washer getting power to the motor when it goes into spin cycle?
    President:
  • 1,902 Answers
If the motor is not getting power when it is called for spin. Then check the computer and the timer. Also check the balance sensor
Posted on Feb 14, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 15, 2009
    Yes it is mounted on the motor. This will trip if it senses that the washer is off balance and usually when it trips you have to replace Cheap part. Go to repairclinic.com
Machine starts then program end light flashes constantly and has done nothing?
I had similar problem and Eventually replaced motor brushes which solved the problem
Feb 26, 2012 | Hotpoint WMA11 Front Load Washer
Wma11 starts to load water then goes to end program within seconds
hi try another program like spin cycle if is still the same the programmer timer control could be the fault
regards
shaun
Dec 05, 2011 | Hotpoint WMA11 Front Load Washer
My washing machine won.t spin or turn so could it be the motor as i can,t hear it or would it be the brushes.i,ve got a hotpoint aquarious
I would try the brushes before replacing the motor, or you may have a broken wire. Before attempting any repair unplug the machine from the mains. The brushes on these motors are held in with 2 screws and although it may be a bit awkward they can be changed while the motor is still attached to the machine, but it will mean tilting the appliance so it is resting against something rather than just proping it up . For Hotpoint WMA workshop manuals click here
Mar 18, 2010 | Hotpoint WMA40 Front Load Washer
I have a Hotpoint WM52 that fills but will not spin / rinse
Check the brushes in the motor, and replace if less than 5mm or or so in length.
Please rate my solution.
Thanks.
Aug 11, 2009 | Hotpoint First Edition WMA12 Front Load...
How to change brushes on wma11, mainly how to i get the top off?
There are two screws on the rear of the lid, one near each corner, undo these and lift the rear of the lid a little and pull back to release the front from its clips. ( but first, if I am correct in thinking the motor is underneath on these, tilt back the machine and lean it against a wall or cabinet, and look to see if it's underneath.
Jun 15, 2009 | Hotpoint WMA11 Front Load Washer
Fitting new belt on hotpoint washing machine
check if plug is loose on motor,in the general area where the belt was changed has anything been disturbed,cables i mean?,sounds like the motor brushes may be worn(this would cause motor to stop),they are situated 180degrees apart at one end of motor,they are easy to change,there is a spot at brushes to put a screwdriver in to remove brushes-hope this helps
May 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washes but does not spin
I AM NOT A MECHANIC, BUT IT SOUNDS LIKE YOUR MOTOR COUPLING NEEDS TO BE REPLACED.
May 13, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Machine will not drain water or spin
hi..Most washing machine have a drain filter that can become
clogged over time.Front load washers typically have a small
removable panel about the size of a half sheet of paper on the
bottom front of the machine.the filter is inside.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | Hotpoint Aquarius WF210 Front Load Washer
My washing machine wont rinse and spin, after washing it will beep as if it was finished doing the washing.
A hotpoint WMA30 does not beep on any program as there is no 'beeper' on the pcb. The 'end' led illuminates when it finishes on any program. The most common cause of no rinse or spin is a blocked filter or drain hose. If there is water in the drum when it has finished then this is the probable cause. However if it's empty when finished and has not spun then either the belt has come off or the motor brushes are worn to a point that there is no contact with the motor armature.
Apr 17, 2009 | Hotpoint WMA30 Front Load Washer
Hotpoint WMA11 Front Load Washer Logo
176 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
