Question about ZT Group Cisnet A7020 PC Desktop
This the cisnet
Why wont the dell moniter respond to my cisnet pc, the moniter light is orange the the cisnet is red whats wrong
  • 1 more comment
  • pchead Feb 14, 2009
    the video card is the original video card i never touched i just connected all the wires and got nothing
    an on board i think
    i connected the moniter cord to the moniter connection on the back of the pc and plugged the power cords into the wall and cut the power on the pc lit up and the light was the moniter never responed except when i plugged it into the wall i got the orange light i thought it would be the video card but was not sure, this is second moniter ive tryed
    Scholar:
  • 51 Answers
Well, I CAN say, that usually an orange monitor light means:
  • "No Signal"
  • Either because, the computer isn't on, or the monitor just isn't receiving a video signal from the video card.
Is the video card an on-board adapter.. or is there an actual addon video card?
Reply in more detail as to how you have everything hooked up, and what exactly happens, and I'll be more than happy to help figure out what is wrong.
Posted on Feb 14, 2009
  • ChappDogg May 11, 2012
    Same problem as that guy and exactly how you explained. Everything is hooked up as purchased. No actual video card, so must be integrated into the mothetboard
Dell GX280 orange light on MOBO
Dell Support > Optiplex GX280 Desktop PC > User Manual,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tindex.htm
I chose the Mini-Tower model because the following information applies to all models;
Small Form Factor (SFF)
Small Desktop
Desktop
Small Mini-Tower
Mini-Tower
Computer and Software Problems > Troubleshooting Tools and Utilities > System Lights,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tools02.htm#wp1114432
Now scroll down. What do the Diagnostic Lights indicate?
Post back in a Comment.
Regards,
joecoolvette
Oct 09, 2012 | Dell OptiPlex GX280 PC Desktop
Black Screen
its your motherboard its failed i would recomend a motherboard replacment hope this helps
Jul 11, 2010 | ZT Group Cisnet PC Desktop
On button is orange and moniter wont come on
If the PC is on and running and the light is oragne it means your video card is bad or the cable is loose.
Power off your PC (gonna have to hold the button down on PC until it turns off) and then turn off the monitor.
Reseat cables on both ends from Monitor and PC then power back on again and see if that helps.
If it still doesn't work you have a bad video card.
Hope this helps
TankMurdock
Apr 24, 2009 | X2Gen MG19VT 19" LCD Monitor
I have a cisnet not exactly sure what model my sister gave me
chack the monitor cable with c.p.u and other probleam is your R.A.M is not work fine
Feb 14, 2009 | ZT Group Cisnet PC Desktop
Computer would not boot up, only showed red light
I'd say power supply first.
If you have an expansion slot filled with a video card, remove the video card (provided you have onboard video connector as well) then try to reboot. I just went through similar issues with an GForce video card, it went bad, but the machine appeared to boot althugh I couldn't see the screen. Removed the card & it came up using minimal VGA drivers provide with WinXP.
Obviously you cannot check the video driver if you're not booting up...and seeing the screen.
Find a buddy with a regular monitor and hook it up and try to boot. Dell monitors sometimes require their propietary drivers, so write down the model when you take your pc to a friend's place, and DL the driver and install it (provided you got it to boot up)
Brad
My pc is not turning on (all the light does is blink orange)
Woops -the blinking amber light of doom is a common fault on dells -
usually a solid amber is the Power supply while a blinking one indicates Motherboard problems. If machine is still under warranty dell will replace it.
If not then it will cost you to have them replaced.
Dec 07, 2008 | Dell Dimension E520 PC Desktop
Orange Light permanently on motherboard. PC won't start
If all you did was change hard drive
I suspect the hard drive has been installed wrong
Ensure blue or red stripe goes to the number 1 pin on M/board and the stripe goes next to the 4 pin power supply on hard drive
Sep 23, 2008 | Computers & Internet
If the repair store said the CPU or MB is bad... buy a newer computer.
Jun 08, 2008 | AMD CISNET A7021 MT A/3000+ 512MB 80GB...
Dell monitor E152fpb
The orange light means that the moitor is not seeing any signal. Make sure that the cable is in the correct position on the PC. If that is correct, try it on another PC to determine whether or not the monitor was damaged internally during moving or the PC is not sending out a video signal.
Dan
Mar 20, 2008 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
ZT Group Cisnet A7020 PC Desktop Logo
142 people viewed this question
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Kyocera HP Expert
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
