Question about Xerox Phaser 7400/DXF Laser Printer
917 error code
What is it. i just baught the machine yesterday.
  • JDTec
    JDTec May 11, 2010
    Error in the Transfer Unit Belt. The Belt Rotation Sensor indicates an error.It is a major problem. Return it if you can.
  • 2,072 Answers
That is a transfer belt error, The edge of the belt is not being sensed.
Take the transfer assembly out and reseat it. if that doesn't fix it, return the belt assembly for a warranty exchange. Sometimes just taking the transfer assembly out and putting it back in retracks it properly.
Posted on Feb 16, 2009
Error 917
917 Error in the Transfer Unit Belt. The Belt Rotation Sensor indicates an error.
Code 917: The Transfer Belt Rotation Sensor indicates a belt error.
Initial Actions:
? Check the condition of the Transfer Unit drive gear.
? Cycle the printer's power.
? If the problem persists follow the procedure below.
Troubleshooting Procedure Table
1 Test the Belt Rotation Sensor.
Run the Service Diagnostics Belt Hole IC test.
Does the sensor function correctly?
Yes) Go to Step 2.
No)Replace the sensor. If the error persists, go to Step 3.
2 Test the Transfer Unit Motor.
a. Close the Interlock Switches for test.
b. Run the Service Diagnostics Transfer
Belt Motor test.
Does the motor operate?
Yes)Replace the Transfer Unit. If the error persists, go to Step 3.
No)Replace the motor. If the error persists, go to Step 3.
3 Check all pins on the HALL1 Harness for continuity.
Disconnect HALL1 and P/J310
Is the harness conductive?
Yes)Replace the Motor Driver Board.If the error persists, go to Step 4.
No)Replace the HALL1 Harness.
4 Check all pins of the DRV0 harness for continuity.
Disconnect the DRV0 ribbon cable.
Is the cable conductive?
Yes)Replace the Engine Control Board.
No)Replace the DRV0 Harness.
Aug 18, 2011 | Xerox Phaser 7400/DT Laser Printer
What state in usa is area code 917?
Area code 917 is a New York City telephone area code for all of the five boroughs (Brooklyn, Manhattan, Queens, Staten Island, and the Bronx).
Jun 07, 2011 | Computers & Internet
Error code 51? F & F intuitive washer
Hi just read your posting.Error code 51 means you have a Recirculation Fault.This means while the machine is filling or washing it loses water.Error code 37 means you have Pump Block error which means the machine is not draining.Please look under the machine to the front right and you should see a pump with a red or black fan attached.Can you confirm this please? I think there is a problem with your diverter valve and the information on your type of pump will help me rectify this problem for you.Please reply with additional information on the type of pump in your machine.Looking forward to your reply.
Jul 01, 2010 | Fisher and Paykel Washing Machines
Hiya i baught yesterday the vodafone samsung h1
change your sim through vodaphone store
Apr 04, 2010 | Samsung Lands Phones
I have a oki 9600 Fatal error 917
Replace the transfer belt unit. A 917 is a belt **** sensor error.
Jun 19, 2009 | OKI C5150n Led Printer
What type of drive?
some do, some don't - if the escutcheon around the shifter handle has an R and 1 2 3 4 5 6, it's a manual shift, otherwise, it's a hydro - the "917" is not a "series", it is a source code for sears, it designates who made the machine for sears
Apr 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Fatal error 917 on an Oki C9600 printer. What does this mean and how can I resolve the problem. Many thanks James
A fatal error 917 means there is a problem regarding the belt **** sensor.
Usually it means the printer can't see the transfer belt rotating.
First thing to try is to remove and re install the transfer belt, if that does not work you should replace the transfer belt.
Jan 07, 2009 | OKI C9600hdn Laser Printer
Power Off/On Fatal Error : 917
The 917 fatal error is a belt **** se sensor error. This could be caused by the belt not installed correctly or the belt at the end of its life, or the belt being torn. Please power the printer off and then reseat the transfer belt and then power the printer back on. If the error remains then I will need you to check the life remaining on the transfer belt. Also make sure the transfer belt is not torn.
Aug 08, 2008 | Xante Ilumina Digital Color Press Printer
Xerox Phaser 7400/DXF Laser Printer Logo
935 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
