Question about HP PSC 2350 All-In-One InkJet Printer
My 2350 all in one will not turn on.
HP 2350 all in one. My HPackard has been un plug for 6 months. I want to install new cartridges. The on light will not come on while it is pluged in. I pull the electric plug from the wall and quickly re install the electrical connection. The window will show HP Invent and you can see it downloading, it will stop quickly. Keep in mind the on light is still off. This HP is well kept and covered, it has hardly no use...Can you assist me with some information. thx. Joe
  • 495255 Feb 26, 2009
    Exact same problem. JR250's did you resolve this issue?
I'm not sure if this is a solution, but it worked for me. ( who knows how long it will last, but its working for now)
Below are the steps I took:
- uninstalled all the HP drives and software
- unplugged the USB cable from the computer and printer
-unplugged power supply from the outlet and printer
-plugged the USB back in to computer and printer
-unplugged the power supply from the power module. Made sure everything looked ok,
-reattached power supply cord to module ( Made sure everything looked ok,)
-plugged power supply in to outlet ( green light was on)
-proceeded to plug power module connector to printer. ( again, making sure proper connection was made.
* this time the screen came with an error and the "on" power light was blinking.:
This was the error message:
Error:
0xb9000009165:
hw_interupt_hwv.c
-I proceeded to unplug the power and usb from the printer
-downloaded the lastest drivers and software for the PSC 2350
-After the software was loaded and installed ( I checked the box to install with out USB communication at this point)
- plugged the power and then the USB.
-It came to life at that point. (the computer recognized the "new" product)Going through what I presume were several realignments or internal configurations.
I tested a page, and ran the HP Dinostic's page. Everything checked out, and its running fine for now.
I hope this may have given you some ideas as to fixing your printer.
Posted on Feb 27, 2009
Printer has shown error 10.00.00 Supply Memory Error
Please make sure to ask a specific question.
The 10.00.00 Supply Memory Error is given when the printer can not read the information on your ink cartridges. This can be common when using non-genuine ink cartridges (non-HP).
Remove and reinsert your ink cartridges. If that doesn't work, try pressing the green button to accept the error and continue.
May 13, 2010 | HP LaserJet 2420 Printer
Out of paper light flashes even after paper is loaded
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
Apr 25, 2009 | HP DeskJet 690c InkJet Printer
HP K850 cartridge problem
I had the same problem, all cartridges lights came on.
I did two things:
1st: I clean the print cartridges plugs with Q-tips, just to insure there wasn't any ink build on the plugs. If you look were the cartridges are, you will see four plugs one for each of the cartridges. Each plug has four contacts. They should be a bright metal color. If they dull in color, they have ink on them. Unplug the printer and pull all the cartridges out and gentlely wipe the the contacts with Q-tips. Re-stall all the cartridges.
Note: The cleaning did not solve my problem but its good maintenance since in was looking for a solution.
2nd: What work for me was I un-stall my printer totally. Turn off the printer then turn off the computer, had a cup of tea, rebooted the computer and re-install the HP cd disk and drivers, turn the printer back on. After I reinstall the software and put the printer back on my network, everything is working fine for the last two days. The lites are off and the HP toolbox is reading the ink cartridges status correctly. I believe that a virus change the printer drives.
Solution by;
eagleeye140
Apr 10, 2009 | HP Officejet Pro K850 InkJet Printer
All 3 color lights and the spray light are flashing on my HP K850
Hello mward583,
I didn't have the same problem, but I had to un-stall the printer and re-stall the printer. I believe that a virus change the the printer drivers, the printer was finishing printing then the all the cartridges lights came on.
See my notes below. If anything you refresh you printer drivers.
My problem was all cartridges lights came on.
I did two things:
Solution by;
eagleeye140
Mar 25, 2009 | HP Officejet Pro K850 InkJet Printer
Need to replace ink cartridges in HP PSC 23
The HP website under the support area will allow you to lookup your printer model and then download the drivers/software for that printer. Make sure you download the ones made for the operating system on your new computer. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 05, 2009 | HP PSC 2350 All-In-One InkJet Printer
All color indicator lights and ink cartridge light lit
Hello Miriam703,
I did two things:
Solution by;
eagleeye140
Jan 30, 2009 | HP Officejet Pro K850 InkJet Printer
Blinking Lights on PSC 1110
IF YOU GO TO THE HP SITE AND PLUG IN YOUR MODEL NUMBER THERE IS INFORMATION THE ON HOW TO RESET HP PRINTERS. THE FLASHING LIGHTS ARE THE SAME AS AN ERROR WARNING AND YOUR PRINTER MAY JUST NEED TO BE RESET. I KNOW ON A 1300 SERIES IT WAS A COMBINATION OF HITTING THE ON SWITCH AND THE PAPER SIZE SWITCH ON STARTUP, AND WAITING FOR THE LIGHTS TO TURN SOLID. YOU SHOULD FIND YOUR RESET ONLINE. HP IS PRETTY GOOD WITH THEIR ONLINE MANUALS, AND YOU CAN PLUG THE FAULT INTO THE SEARCH BLOCK AND IT WILL PUT YOU INTO THE TROUBLESHOOTING PAGES.
ARCLIGHT1217
Nov 05, 2008 | HP PSC 1110 All-In-One Thermal Printer
Question about mc 2350 cartridge
I just got done replacing my toner.  You'll need to change toner and most likely all of them. There is no other solution.  I refill mine by buying the bottle toners.  It can be messy and you'll need to take some parts off the cartridge to get to the opening plug and reset the lever so that the printer knows the cartridge is full.  It is cheaper than buying a toner. The cartridge has a life of about three refills.  Anyway hope this answers your problem.
Aug 07, 2008 | Minolta magicolor 2350 Laser Printer
Printer issue
First try this, very simple, unplug then plug back in, that may re- set it.
If not, then un-install and re- install. To do this, go to my computer, add and remove programs, click on remove.
Then follow direction on printer cd to re- install.
Make sure you have installation cd before you remove from programs.
Nov 28, 2007 | HP PSC 1210 All-In-One InkJet Printer
Error: 0x07a74dd61959:lib-barracu
Its a Fimware Error.
Try a Hardware Reset.
-Switch the Printer on
-unplug the powerkable
-press "#" and "6" and plug in the Powerkable.
when the Display shows Initialising or Semi-Full-Reset. release the "#" and the"6".
sometime this is working
Jul 14, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP PSC 2350 All-In-One InkJet Printer Logo
331 people viewed this question
Ben Johnson
