Question about Quantum Fireball Lct15 (QML20000LC-A) 20 GB Hard Drive
I need to download the installation disk for the lct15 20gb hdd
I bought this drive used,and it worked for a while,but when I changed into another computer it got a virus or something, so I reformatted it,and it worked for a while,I installed WinXP Home, and now it will not bootup at all,and it will not format. Whats is wrong?
  • WILLIE O. MITCHELL Feb 17, 2009
    Hello. Iam sorry for the oversight, I got excited because your solution seems to have fixed my problem,and I look forward to continuing to work with you. Thank you very much.
    willie31
  • 36 Answers
Check the bios if the hard drive is detected. if not configure the necessary jumper settings. if not detected, you have a defective hard drive.
if detected:
Try to fdisk it to repair the partition. reformat and install again.
Hope that helps.
Posted on Feb 14, 2009
Can I install a NEW 1T HDD where an old HDD failed?
In a lot of cases, the recovery disks you built may be looking for installation files (windows installation files) from a partition that is on the original drive of the machine. Your new drive would not contain this partition or the files. If you can STILL get into the old drive, I would consider putting both drives in your desktop.....and then use an disk imaging software to do a disk to disk clone of your drive rather than reinstalling Windows from the recovery disk. There are plenty of options for free cloning software.....just google free disk imaging, and you will probably find a ton of options with instructions. One thing to note....when cloning a drive be VERY careful when choosing your SOURCE and DESTINATION drives. Your SOURCE would be your old drive with your data, and your DESTINATION is your new drive. If you mess up that step, it will overwrite your old drive with the "blank" data from the new drive, and your data will be lost.
The other advantage to cloning, is you will get an exact replica of your current configuration. you dont need to reinstall programs or reconfigure things.
Mar 04, 2013 | Gateway SX2802-07 PC Desktop
Install a 2nd hdd (sata) on dell optiplex 360 not working
Can the disk viewed in disk management?
Right Click 'My Computer'-->Manage-->storage-->Disk Management
Disk 0 usually for windos partition (your 80GB HD)
If Disk 1 (your TB HDD) show unallocated, you need to format it to NTFS.
Right Click and select 'Format'.
!!!!Make sure it is your TB HDD!!!!!!!
Jun 08, 2012 | Dell OptiPlex 360 Desktop Computer
Friend bought used Gateway 1200cs w/win xp and no disks, she wants to put new HDD in and I need to make a disk to re-install windows or copy it to a partition. how to?
Some HDDs come with a cloning software - get that. Then you won't need to redo the operating system. However, if you have the original operating system disc, it has provisions to create another partition, but you want to install a new HDD. If I understand you correctly, she wants her old data in the new HDD - that's a separate issue. If I were you, I would just install the new HDD along with the old HDD together and have the old HDD run the operating system.
Dec 22, 2010 | Microsoft Windows XP Home Edition
How do I replace the hard drive in my Dell
Did you format the drive before installing it on your laptop. Some laptop will not detect unformated hard disk. Try to format the hard disk somewhere else and check to see if the laptop detect it after.
Apr 11, 2010 | Dell Inspiron 2650 Notebook
Do i need to change my harddisk?
It sounds like UBUNTU formated your hard drive where xp does not reconized the drive. When you go into BIOS setting, do you see your hard listed? If so, you should be able to put a clean install of XP to the drive. When you start the install, you must select REFORMAT drive and install XP. If this still fails, you may need to fdisk your drive first using DOS command and reinstall XP. Let us know if you incounter any more problems after doing this. Good Luck.
Feb 08, 2009 | HP Pavilion dv6000z Notebook
Computer freezes when trying to detect S-Ata drive
Hi Eamon, download Samsungs drive setup utility, tools from Samsungs web site. Creat a bootable floppy drive setup disk or a CD bootable disk.
http://www.samsung.com/global/business/hdd/support/utilities/ES_Tool.html
Enable the SMART function using the setup software.
If you are going to use the Samsung drive as the primary master drive as the new C:\ you will need to enter the bios & set the Hard Disk Boot Priority, page 30 in you're manual to see the Samsung drive.
Connect only the Samsung into the system. Boot the system & use Samsung's software to setup the drive & format.
Disconnect any other hard disk drives that may have windows installed in it.
Mike
Jun 30, 2008 | EliteGroup K8M800-M2 Motherboard
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
Biostar Motherboard p4m800-m7a
You may have a HDD Problem Diagnose it using the following. DOWNLOAD HIREN BOOT CD, WRITE THE ISO TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 23, 2007 | Biostar P4M800-M7A Motherboard
OS installation problems
Hi, hi check your power supply, hard disks, cd drive, and memory FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP Try using Memtest 86+ http://www.memtest86.com/ to diagnose your memory problem. You can also try the following methods. Turn off power, Unplug. Remove the cover of your PC. Remove the memory from the Motherboard. Note on the locks! Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser. It should be shiny gold. Reseat your memory to the motherboard and Test! DIAGNOSTICS DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 21, 2007 | Tyan Tomcat K8E Motherboard
PC won't recognize external usb HDD
You may not have installed the HDD correctly in the case... I had the same problem with my Thecus N1050 enclosure, the green power light on the enclosure would come on and the drive would spin up but my PC would not see the HDD!!??... I thought, becuase i could hear the drive spinning that i had it installed correctly but this wasn't the case, when i removed the enclosure again and FIRMLY pushed the HDD into the connector (all the way in) and connected it back up to my PC, it recognised it instantly. Hope this helps!
Jul 25, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Quantum Fireball Lct15 (QML20000LC-A) 20 GB Hard Drive Logo
175 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
