Question about Singer Sewing Machines
The feeder feet does not move on my Singer 534
The feeder feet move back by depressing the Reverse button, however the fabric will not feed. I have oiled the machine where indicated and removed all lint. I have NOT taken it apart besides the normal removal of the pressure foot and bobbin tray.
mohammed387
  • 1952 Answers
SOURCE: feed dog is not working.
Think of it as if it as two sets of fingers, behind and in front of where you are making the stitch. The numbers on the indicator should be thought of as X to one. 1 is always the rear hand, and X is the front one. If you go to a lesser number (like 0.5) with your front hand (feed dog) it means that they only feed the fabric one half as far as the rear one, so you are stretching the fabric at the point where it is being sewn. If you go to a larger number (like 2) that should be read as 2 to 1. In other words, your front hand is pushing the fabric twice as far as the rear one is, so it is compressing the fabric where it is being sewn. Wonderful invention!
Posted on Jan 22, 2009
Jannarama
  • 14 Answers
SOURCE: feeder feet under presser foot clicked down not able to get back
The switch for the FEED DOGS is on the left side of the machine.
Posted on Mar 19, 2009
  • 52 Answers
SOURCE: fabric won't feed forward
Do the feed dogs move up and down? If they dont the plastic gear underenth has probably broken you can take this to a singer dealer and have them replace the plastic gear with a nylon one which would last longer than that did
Posted on Jul 16, 2009
SOURCE: I have a singer 3343c
the presser foot only holds the fabric against the feed dogs in the needle plate area
check the feed dogs to see if there in the up position
if not there should be a nob in the feed dog area to move them up & down
on some models when you remove the extension table the nob is at the back
Posted on Dec 10, 2010
  • 6 Answers
SOURCE: I place the fabric on
This is easily solved. Before you start sewing make sure your upper and lower threads are long enough for you to hold before lowering the presser foot. If these threads are too short they both get carried down into the bobbin along with the fabric and cause a big tangled mess. Always hold your threads at the back of your work with your left hand then lower your pressure foot and don't release the threads untill you have taken several stitches. Keep holding these threads during backstitching at the beggining of a seam too. Works like magic.
Posted on Dec 21, 2010
Hi there. I have a singer 507 machine which was sewing fine until I changed thread in bobbin and now the feeder teeth are not moving to feed thE fabric thru, not sure what I may have done - Help!
the bobbin has nothing to do with the feed teeth
however it is possible that at some point you moved the forward /reverse knob lever to middle where the teeth will not move
Jan 03, 2017 | Singer Sewing Machines
Singer model no 9022 feeder feet does not move material thread bunges under material
Check that the stitch length is set high enough that the feed dogs will actually advance the fabric. Setting the stitch length too low will cause the machine to basically sew in place.
Also, check that the feed dogs have not been "dropped" to allow darning or free motion quilting. Dropping the feed dogs lowers them so they will not rise above the needleplate and will not grip nor move the fabric.
If your machine is mechanical (not computerized), it may need a good cleaning and oiling. If the old oil has solidified, it could be preventing the feed dogs from moving like they should.
Aug 27, 2016 | Singer Sewing Machines
The little Teeth/feeder under the foot doesn't push the fabric out. The fabric doesn't move
check where the direction button/lever is
it controls the feed mechanism and if it is in the middle the teeth will just go up and down
set it one way and it moves forward and set the other way will go in reverse
it is graduated to provide a stitch length ( number of stitches per 1")
Oct 23, 2015 | Sewing Machines
Singer Sewing Machine model #2638 Does not feed fabric
Here is a link to page 22 of the manual. It shows you where to flip the lever to raise the feed dogs. If your feed dogs are not grabbing fabric your feed dogs are lowered.
https://www.manualslib.com/manual/1050311/Singer-2638.html?page=23#manual
Sep 20, 2012 | Sewing Machines
Fabric quit feeding through
there called feed dogs & if they don't feed the fabric thur the machine need they need to be check to see whats wrong with them
Mar 07, 2012 | Singer 3116 Simple
Needle stays in one place. Fabric does not feed
There is a latch under the the feeder lpate next to the bobbin lift it up to lift the feeder feet. wcbotha@yahoo.com
May 10, 2010 | Singer 7426 Mechanical Sewing Machine
Reverse stitching on a singer 514, HELP!
In the center of the stitch length knob (at the right side of the machine) is a button. You would push that button in to get the machine to reverse.
May 08, 2009 | Singer 7442 Mechanical Sewing Machine
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Feeder feet under presser foot clicked down not able to get back
Mar 19, 2009 | Kenmore 15343
FEEDER FEET WILL NOT PULL FABRIC,REVERSE WORKSB
I'm sorry to say that it sounds like you have a broken gear that is preventing the feed dogs from moving properly. Depending on the machine, this could be a very expensive repair.
Feb 01, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
181 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
