It is not listed in my user manual
what is it
SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
SOURCE: wattage
The output power for model MA-780 was 700 watts, so I'd bet yours is either 600 or 700 watts.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: do you know what the wattage is of the Goldstar MA-685M Microwave Oven?
600 watts, according to the repair manual.
SOURCE: Oster 1.1 cu. ft. Stainless Steel Combination Microwave Grill - OMW1199
After six months I just figured it out. Push the cook by weight button in and hold it until the clock function comes on. Turn left for hour and right for minute. Figured this out by holding the cancel button in and a child lock came on, I didn't know how to release it so I reversed the process by holding it in and it cleared. I tried it with the cook by weight, which has a small clock icon next to it and voilla.
SOURCE: Oster 1.1.cu.ft countertop microwave model
check the high voltage fuse on the inside of the unit if this is not showing a fault then you would most likely be looking at replacing the magnetron in your unit this is the most common piece beside the fuse that shorts out and is what is directly realted to what is actually heating your food depending on what type of microwave it is it may be cheaper to just buy another microwave if the place of origin on the microwave came from a walmart or target store where as buying a magnetron may cost you between 50-100 dollars which is about the price of a micro wave at one of these stores if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks Rick
Sorry
but your subject line was too long and got cut off.
Please reply
back with your full model number from the tag on the unit.
