Question about Kenmore 24 in. 15652 Built-in Dishwasher
Kenmore dishwasher does not wash completely
I have a Kenmore Quiet Guard Standard. The dishes are not completely clean. The glasses and dishes have a grit on it .It does go through the whole cycle. I've used a bottle of dishwasher cleaner and it hasn't helped. Kenmore 15652 built-in dishwasher. Cups and glasses on the top rack have a grit remaining in places, both inside and on top of the items. Dishwasher is 6 years old. Very similar problem to mnvgarr's.
5 Suggested Answers
SOURCE: Kenmore dishwasher does not wash completely
I had the same problem. I switched to a gel dishwashing liquid and added about 1/2 cup of white vinegar to each wash cycle. (Just pour the vinegar in a cup, put it in the dishwasher and let the water fill the cup and disperse the vinegar.) Gradually you can reduce the amount of vinegar that you use. Worked for me, hope it does the same for you.
Posted on Feb 15, 2009
  • 228 Answers
SOURCE: I have a bosch dishwasher, SHU535E05UC/14. The
the spray arms are not rotating check they spin freely if they do remove them and clean any residue food deposits blocking holes for water spray.
Posted on Jan 19, 2010
Testimonial: "You gave me some information how to get my dishes clean, it was very helpful. I cleaned all the arms out, there were food particles stuck inside.Thks"
  • 70 Answers
SOURCE: dishes/cups are not being completely cleaned.
1)check the enough inlet water pressure. 2)check any block in the rinse nozzle. 3)check it attains the temperature. 4)check proper detergent& sanitizer going.
Posted on Jun 03, 2010
heatman101
  • 43501 Answers
SOURCE: After we wash and the dishes dry, we find grit on
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Feb 24, 2011
Kenmore ultra wash quiet guard standard. Very little pressure coming out of the jets. Doesn't clean the dishes.
sounds like hard water is the problem and may have clogged the jets. clean it out really well and get the dishwasher filtration system from www.dishwasherfilter.com. that will remove the hard minerals and leave your dishes and dishwasher spotless. awesome product and the results are guaranteed.
Jul 08, 2013 | Dishwashers
My kenmorre quiet guard 2 dishwasher is not draining completely and is leaving dishes with a soapy residue.P,ease help.thank you.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 11, 2010 | Kenmore 24 in. 15932 Built-in Dishwasher
My Kenmore quiet guard standard model 587-15152400 is not getting the dishes clean AT ALL. It has hot water, water is draining, have not changed soap. Don't know why?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Aug 22, 2010 | Kenmore Dishwashers
Kenmore quiet guard standard ocassionally does not use/mix all soap supply and does not get dishes clean. Any ideas?
MIne did the same thing a couple of times. I found that I had put a casserole dish on its side in front of the soap dispenser...so it opened, but the sprayed water could not get to it.
Hope this helps.
Aug 03, 2009 | Kenmore Dishwashers
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Feb 07, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Dec 09, 2008 | Dishwashers
not a dumb question,
is the bottom dishes coming out clean? there is a chopper that breaks and will trap food and not clean the top rack.it is not easy to replace.but not impossible.
Oct 23, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24 in. 15652 Built-in Dishwasher Logo
93 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
