Question about KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
Noisy Door When the door is opened and closed it creaks very loud. Have tried a little WD40 on hinge pin to no avail.
  • 70 Answers
The noise is comming from the counter balance spring and rope system. You will need to pull the unit out from the counter and then you will see the springs. You will have one on each side near the bottom of the floor. Sometimes a lil grease or PAM spray will quiet them down.
Good Luck!
Posted on Feb 19, 2009
2001 honda passport front driver side door hinge is popping loudly when opening and closing, how do I repair it
You need to go to the nearest auto parts store like O'reilly and tell them you need a new door hinge pin for your car. The pin comes with llittle nit looking pieces. It is simple to put on but it will take time. But put the little pieces on top of the holes for the pin then slide the pin through the nuts and the problem should cease to exist.
Jan 17, 2013 | 2001 Honda Passport
Random door ajar indicator when driving but all doors all closed tight. Any way to find out what door is causing the problem and were are the door switches located?
the door switches are located inside the door frame normally hinge side it will look like a little pin switch more than likely one is stuck spray wd40 into all pin switches and push in by hand numerous times to free the pin switches
Dec 12, 2010 | 2005 Lincoln Aviator
Back door makes terrible squeaking noise when
When you open your door you will see a flat bar that slides into the door while opening and closing. It is located between the two door hinges. There is a rubber on the door where the flat bar slides in and out, remove that rubber and you will see little rollers in the door, those rollers need to be oiled, preferably with engine oil. Oil the rollers and work the doors back and forth, the noise should abate.
Feb 21, 2010 | 2005 GMC Envoy
My 1997 Jeep Grand Cheroke's doors close funny. Both of them don't close smoothly. Anyone else have this problem? It's not when the door latches it's during the close, like something is bent but it's on...
Each door has two hinges. The bottom hinge has a lever spring and two rollers attached that prevents the door from swinging freely when it is opened or closed. (one roller for opening and one for closing) If the door seems like its bent, it is probably because the rollers are frozen and when you open/close the door the lever spring is scraping across the raised edges of the rollers instead of riding them. If the door is not moving smoothly, or is making loud creaking noises, give a good dose of WD-40 to the hinges as well as the rollers, especially the rollers. The rollers should roll when the lever spring engages it as you open/close the door.
Dec 20, 2009 | 1997 Jeep Grand Cherokee
I have a 2003 GMC Envoy when you open the drivers side door it makes a loud creeking noise.. it has been greased and we have used WD40 still creaks.. any suggestions would be great.
try using engine oil.put oil in a little can oiler.oil the door hinges pins and bushings.if it still sqeek.door hinge need adjustment.or the door hinge pin and bushing need replacing.
Nov 17, 2009 | GMC Envoy Cars & Trucks
Doors creak loudly when closed and pushed from the outside. Don't when open.
This short solution may help solve your creaking problem. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly. Putting vaseline insid the hinge pins too is a good idea.
Let me know if I can assist you better, Thanks, Sea Breeze
Apr 27, 2009 | LG LFC21760 Bottom Freezer French Door...
Creaky car door
Do not use oil.....or WD-40
Use a good quality penatrating lubricant [spray].....such as Valvoline or Berryman's.....
Spray into the pins and slide bar, then work the door back-n-forth....several times .till
you no longer have a squeek, etc.
If the problem persists, hold the door and see if there is any up-n-down movement...
You could possibly have bad door hinge that needs to be replaced.....
JLP
Mar 14, 2009 | 1993 Volvo 850
Creaking Sound when Opening Door of GE Profile PTS22LHSCC Refrigerator
My GE creaks too, and it started after we pulled it out for cleaning. It is normally the door hinges. Spray them with Jigaloo which is a dry silicone lubricant.
Try this. Go to your local tire repair place. Ask them for an old inner tube. Cut a double thickness square with scissors and put it under the 4 corners under where the wheels are. It should help them to become self leveling and also sound insulating..
Mar 23, 2017 | GE Profile PTS22LHSCC 33" 21.7 Cu. Ft....
Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Aug 25, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher Logo
163 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
