Question about Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chainsaw PPB1838 Bar Lube Leaking Out
I purchased a used chainsaw. Started and ran fine when the guy sold it to me. When I got home and filled it with chain lube, it leaked out as fast as I poured it in. I removed the cover, chain and bar. The bottom of the mounting bar plate was sheared off and the chain catcher was also missing a chunk out of it. I can see the where the lube is leaking from when I removed the mounting bar plate. It looks to be about a 1/8 inch diameter hole where the lube is probably supposed to come out of. The hole is not threaded so it does not look like a screw of any type was initially in it. The problem is that the hole is wide open with no kind of check valve or anything else in it regulating the amount of lube. Is this supposed to be this way? Do all I need is a new mounting bar plate to fix the problem or is there something else missing from inside the lube's holding tank?
Thanks
  • 2,176 Answers
If this is a Poulan as listed I would go to psep.biz and look at a schematic for the tool. You would need the model number and type number but their breakdowns are good.
Posted on Feb 15, 2009
2 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: Chainsaw Bar Lube Oil Leaking
A new mounting bar would solve this issue. On that mounting bar there is a little piece that allows oil to drop onto the bar when you call for it or if this is a electric bar oil chain saw. Then it tracks when it needs to open.
Posted on Feb 14, 2009
What kind of oil do I use and how much should I add?
Hi natcarc2003...
You will use "Bar and Chain Oil",it is used to lube the chain and bar of your chainsaw as you are using it.
You will push down on the top of the oil fill lid to push the oil onto the bar and chain.
It can be bought at any small engine repair shop, WalMart,KMart,HomeDepot,Lowes,etc.
You will fill the reservoir with the oil till it is about 1/2 inch below the surface of the opening of the oil fill on top of the chainsaw.
Please take time to rate me thumbs up
Sep 10, 2011 | Remington Electric Chain Saw
I purchased a new carb fro my husky 137. When I started it it ran very fast. It is hard to start but when I get it going it runs very fast and will not idle. I was wondering what the initial carb...
1/12 initial settings, sounds like you are sucking air, check the hose from cylinder to carb which runs fuel pump in carb off vac pulses. some saws have one and some just **** through the intake small hole. good luck
Aug 25, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have the same problem with my 350 Husqvarna chain saw. I took the saw to a licensed Husqvarna Dealer. The dealer said that there was noting wrong with the saw. The dealer did clean the carb. I brought...
The temperature is not that different. Is there a fair change in altitude between the dealer and where you live? The jet screws have 'D' heads to prevent owner tampering--how did you adjust them? You need to allow the engine to warm up before pulling the throttle. Make sure the fuel mix is fresh and mixed 50:1 with synthetic chain saw oil--be sure to shake the container thoroughly just before filling the tank each time to prevent oil starvation. It has to be the manufacturer's problem because it is under warranty. It sounds like the jet screws are set fairly lean. Ask the dealer if you can buy the special 'D' head screwdriver to make your own adjustments. Hope this helps!
Jan 09, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
YO. Sawwas running fine. After a 5 day lay-off, she started, ran, but then wouldn't rev up enough to drive the chain. Several attempts to rectify including carb breakdown and cleaning-still same proble....
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the chain is being oiled and that you can turn the chain by hand. Be sure to have fresh fuel mix and be sure to shake the container thoroughly before each tank fill to prevent oil starvation. Hope this helps!
Nov 16, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What type of oil do I use for the blade?
Don't use car oil or anything else,but the recommended purpose lube,which you can pick up
at any home improvement store. The oil has a special
viscocity,which will work properly in the chainsaw.
Apr 01, 2010 | Remington Electric Chain Saw
My chain saw (14 inch gas powered) would not
Modern chainsaws have the ability to run without turning the chain via the chain-brake. To set the brake the uppermost handle is pushed forward (toward the chain) and a firm snap should be heard and felt. To release the brake you pull the same handle back (towards the engine) and get the same "snap".
Concerning oil leakage: Bar/chain lube collects on the inside of the clutch cover and the sawdust mixes with it as you saw. A surprising amount of oil gets absorbed in the sawdust and later seeps back out when the saw is at rest. If the level of oil in the tank noticably drops after sitting overnight you may have a leak...otherwise it's normal.
As for a running chain that wont cut, it is common for chains to be installed backward and the unit still function perfectly (it just won't cut wood). See the proper chain orientation here. In this photo the chain travel is from left to right.
Sep 26, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Chain Lube Leak
It is the nature of the beast. Many chainsaws suffer from this malady. I own a bunch.
Lou
Try loosening the oil cap prior to bed.
Aug 04, 2009 | Poulan Pro Chain Saw 46cc 20"
350 leaks gas when filling
HI. I JUST TOLD A GUY THAT THAT HAPPENED TO ME AND IT WAS THE FUEL LINE, IT POPED OUT OF PLACE. HOPE IT HELPS. JIMBO
May 18, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Chain Lube Pouring Out of Chainsaw
We can see no more detail than can you.
This is a collection of chainsaw enthusiasts that may provide a better answer. Be prepared for a little grief because you a Poulan.
ArboristSite.com Chainsaw thread
http://www.arboristsite.com/forumdisplay.php?f=9
GL
Lou
Feb 22, 2009 | Poulan Garden
Feb 14, 2009 | Garden
Poulan Pro Chain Saw 46cc 20" Logo
286 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
