Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
97 chevy suburban wont start
Changed electric fuel pump so its not that. my mechanic put wire into fuel pump relay then started the truck fine he said something about staring it direct but we are not sure what the problem is i changed the relay but that didnt solve problem. could it be electrical
  • 95 Answers
Try putting a dab of solder on each one of the contacts on the fuel pump relay. i had a similiar situation where the relay contacts in the fuse box got strectched out over time so i put a dab of solder on each terminal to beef the contacts up and it worked perfectly. i think this will work because if the mechanic put a wire jumper in the contacts then electrical it is fine.
Posted on Feb 17, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
97 chevy suburban have replaced fuel pump, relay, fuel filter, & the fuel pressure regulator but now it will crank & then die once I press the gas pedal. It also bogs down after coming to a st
possible faulty accelerator position sensor. Have the fault codes read. Replace faulty items. Use only genuine items as non-genuine replacement are not always compatible with the OEM fitted CPU units
Jun 03, 2013 | 1995-1997 Chevy Suburban Ignition Starter...
Iv got a 97 burb wont start put in whole new fule system and the engine still wont start???
I'm going to assume you mean Chevy Suburban.
Did you check fuel pressure before and after you replaced the fuel pump ??
Are you getting spark to the plugs ?
Feb 15, 2013 | Cars & Trucks
I Let my chevy Blazer run out of gas,nw it wont start even though the relay and fuelpump is working.
Is it electric or mechanical pump? Electric is with fuel injection. If its fuel injection, you should hear the pump run when you turn ignition switch. If u don't hear it, try starting, if no, turn off then on. It will self prime. Carburetor is with mechanical pump. I usually put few drops of gas in the carb. Start it, if no, more in carb till it stays running.
Jan 11, 2013 | 1999 Chevrolet Blazer
1991 1500 4x4 5.7 liter suburban. Will start and then die, like its not getting gas. Fuel pump has been checked, gas pressure regulator has been replaced, shop said hose from fuel tank to fuel pump had...
Yes, there is a Fuel Pump Relay. The Relay is located on the firewall just above the left-hand (even cyclinders) valve cover as viewed from the front of the car. There is also fuel pump test lead attached to the harness at the fuel pump relay. Attach a power wire from the battery to the lead and the fuel pump should come on. If fuel pump comes on, the relay could be bad. Also check the fuel filter located under the passenger side of the truck tucked into the frame rail.
Feb 19, 2011 | 1991 Chevrolet Suburban
1999 surburban won't start getting gas and fire. put new coil and check fuel pressure from fuel pump. what can it be,
my 1999 chevy suburban will start with starter fluid bbut wont stay running already replaced coil,rotor on distribitor,and oil pump cant seem to figure it out any ideas
Jan 17, 2011 | 1999 GMC Suburban
1996 CHEVY SUBURBAN WONT START. NOT GETTING ANY FUEL
Can you hear any "hum" from back when you turn key to on? (not start)
Aug 08, 2009 | 2002 Chevrolet Suburban 2500
92 Chevy Suburban Electrical Fuel System
Check fuel flter at fuel pick-up intank (looks like a small wire sock). Remove fuel filter and fitting at fuel rail. Blow out fuel lines w/about 35lbs air press. Ck electrical @ relay - should be 4 connectors - one is key on hot/one is always hot/one is ground and last is hot to fuel pump. Good Luck
May 03, 2009 | 2002 Chevrolet Suburban
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
925 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
