Question about Apex Digital PF2020 20" TV
How to fix Telefunken tv mp162m'
My tv has power but no picture and the led light indecating power on is not lighting up so no picture and no sound but it is getting power ok can anyone help please
how can i fix my Telefunken PALcolor MP162M
  • ntozz malusi Apr 23, 2009
    When I turn my 72 cm Telefunken TV set it just shows the red led as if it will turn on, but it never really turn on. There is no sound or picture coming out. Please assist!
I found out in my in dept probing around the line output transformer has gone so no tv it is to get recycled
Posted on Feb 15, 2009
Sound is OK. Why is screen black?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Mar 27, 2016 | Toshiba 46L5200U 46 Class 1080p LED HD TV
No picture only sound.
Engineers are right, you need a new LED panel., or the component that supplies the light to the screen.
Mar 18, 2016 | Philips 55pfl4706df7 4000 Series Lcd...
LG 32LB530A Tv sound ok faint picture Led backlid off
Back light led driver or the led array is faulty. check and confirm the voltage to the led back light from the power supply. normally 35V to 100V according to the brand and model of the tv. Check the voltage if the voltage is somewhere around the above mentioned voltage the then the tv have problem with the led array behind the screen . If the voltage is missing then the led driver is faulty. Normally the led drivers is found integrated to the power supply board. If so then you have to replace the power supply board as a whole.
www.electro-medical.blogspot.com
Oct 10, 2015 | LG Televison & Video
Can't see picture in TOSHIBA LED TV, but still have sound and can see picture with flash light
try changing the back light inverter that's what light the screen some sets have separate back light inverter while some comes in he power supply...good luck
Apr 03, 2015 | Toshiba Televison & Video
Lg led tv has sound but no picture
suspect either a back light power board issue or main power board to back light board issue...also, is it under warranty ?
Dec 28, 2013 | LG Electronics 47LS4600 47" LED HDTV
Sony KLV 42EX410 LCD TV works but no picture.sound is ok.
LED driver is the most common cause. You should be able to get replacement parts from www.tvcircuitboards.com they can assist with troubleshooting why the LEDs are not lighting
Jan 09, 2013 | Sony 42 inch KLV-42EX410 Multi System LED...
JVC TV AV-21ST27 no picture and no sound the power indecator light is ON, but turn OFF in 3seconds...
There is some short circuted component/s in the horizontal output section of your TV. Check it.
Apr 11, 2012 | Televison & Video
My tv will not turn on
most plasma tv have two power botton, ha main power which is mostly located at the lower side of the tv, and the sub power/standby power botton located in the top of the tv.. check if there is red, orange and green light on power led indecator. other wise there is problem with you power supply.... you may call qualified technician.
May 27, 2011 | Sony BRAVIA KDL-40V3000 Television
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
AKAI LCT26Z4AD wont power up.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 10, 2017 | Televison & Video
Apex Digital PF2020 20" TV Logo
544 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
