Question about Karcher 2500 PSI Pressure Washer
2001 saturn l200 crankshaft position
I have the 2.2 liter motor in a 2001 l200 sedanand and am replacing the timing chain myself. on alldata.com they saidbefore i pull off the crank shaft pulley i need to put it at 60 degreesbtdc before pulling it off. they do not mention how to get it there orhow to come up with a plan on getting it there. any ideas on how tomanually set this?
p.s. the cartoon on the website has one of the webs of the crankshaft pullley strait up and down that is all i can make out.
I unhooked the positive wire from an alternator in a 2002 Saturn, the plastic clip wire broke off,Need to know where to reattach it, thanks
Hershel, Check the attached links Saturn alternator replacement,instruction and guides, hopefully this will show you the wire in question. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2002 Saturn alternator wires Google Search
Alternator Removal
2001 Saturn L200 Alternator replacement
2001 Saturn L200 LS Series with 2 2L Ecotec Engine Alternator Replacement
Apr 08, 2016 | Cars & Trucks
Where is crank position sensor on a 1994 toyota 2.2liter 4cyl ?
Where is the crank position sensor on a 95 Toyota celica gt 2.2
search.aibing.cc/Where+is+the+crank+position+sensor+on+a+95+Toyota...
P1335, No Crankshaft Position Sensor Signal - Engine Running. ... 91 1991 ToyotaCelica GTS Engine Mount Right 2.2L 4 Cyl Genuine. ... 1990, 1991, 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001 . ... Powered by a 2.2-liter engine, the Celica now had ST and GT trim models. ... in 1986 and a 2.0-liter ...
Where is crank position sensor on a 1994 toyota 2.2liter 4cyl ...
www.fixya.com/cars/t26080657-crank_position_sensor_1994_toyota
31 mins ago - It is not behind pully nor in dist all videos show - Toyota Cars & Trucks question. ... Change a crankshaft position sensor on a 2000 eclipse.
toyota camry crankshaft sensor - ABMforum.com
abmforum.com/toyota-camry-crankshaft-sensor.html
toyota camry crankshaft sensor 99 camry crankshaftcamshaft position codes i got a problem with my 97 ... The car 96 toyota camry 2.2 liter 4 cyl. ... 1994 toyota camry 2.2L 257k miles Symptoms Car overheats Top radiator hose hot bottom cold ...
Toyota Camry 5SFE Engine Timing Belt, Water Pump and ...
hubpages.com > Autos > Do It Yourself Auto Repair
Jul 10, 2014 - The Toyota 5SFE motor is a four-cylinder, 2.2 liter, timing-belt-driven, double ..... Remove the lower timing belt cover with the crankshaft position sensor. ..... I've never, ever replaced the harmonic balancer on a 4cyl 5SFE.
1995 Toyota Camry LE 4 cylinder - YouTube
? 2:27
https://www.youtube.com/watch?v=7TW6hlUiHWQ
Sep 6, 2011 - Uploaded by jacasan2000
Feb 03, 2016 | Toyota Cars & Trucks
P0017 on a 2007 suzuki xl7
did you look it up?
alldata.com shows.
it means the engine needs service and inspections here.
Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor "B"
Number of Trips to Set Code: 2
Trouble Code Conditions:
Difference between camshaft (bank 1 / exhaust side) position and crankshaft position is out of specified range.
Possible Causes:
  • CMP sensor
  • CKP sensor
  • Signal rotor
  • Timing chain
  • Timing chain tensioner
  • CMP actuator
  • ECM
Feb 24, 2014 | 2007 Suzuki XL-7
2001 saturn l200 will not start even though starter turns engine over.will the engine sound different during turnover if the timing chain is broken?
if the timing chain is broken it will sound different like there is no compression also this is an interference engine i think meaning the valves will hit the pistons if the timing is not correct,like in a broken chain or belt.you should check to see if you have spark at the plugs and if the motor is getting fuel.if not then each system will have to be checked out depending which is not working.
Nov 02, 2011 | 2001 Saturn L-Series
2001 saturn l200 2.2 liter. It is getting spark and I'm assuming fuel because I can smell fuel. The motor turns over but will not start. Where do I start?
You may have washed the cylinders with fuel and have no compression, try removing the spark plugs and put a little oil in the cylinders (save time and do a compresion check), replace the plugs and try to start, it's going to smoke, but it will go away.
Dec 23, 2010 | 2001 Saturn L-Series
Timing belt tensioner replacement
It depends what is being replaced, timing belt, tensioner, belt, pullies, oil seals. Doesnt your car have a timing chain?
May 24, 2010 | 2001 Saturn L-Series
usually at the crankshaft pulley it has markings/graduations to match alongside the front cover. These markings indicate the position before TDC. I am more familiar with Toyota vehicles, but the saem principle should be applied to other vehicles. Markings for Toyota would be about 4 strokes, starting from 0 then 5, 10, 15 etc. These indicate the amount of defrees BTDC. You will have to check to c how urs is
Feb 14, 2009 | 2001 Saturn L-Series
Karcher 2500 PSI Pressure Washer Logo
49 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
