Question about Whirlpool RBS275PD Electric Single Oven
Trying to replace broiler ignitor on Tappan 30-3982-00/04
There isn't enough slack in the wires to prevent them from falling out of reach once I cut them away from the ceramic body of the old ignitor. How can I increase the slack? Thanks in advance,
  • 1 more comment
  • matthew_t_qu Feb 14, 2009
    Sorry, I am new to the forum and just clicked 'Ask a question'. I posted in the wrong forum. It's a Tappan gas range, model 30-3982-00/04. Thanks a lot,
  • matthew_t_qu Feb 15, 2009
    I actually had to pull the oven out away from the wall and remove the two back panels to get at the wires.
  • Affordable Appliance Parts
    You list a electric oven and the model number verifies it is indeed an electric oven yet you are requesting help with installing an oven ignitor. Please verify the model number so I can see your unit as you do and offer more proessional help.
    Waiting to hear from you,
    Eric Campion
    Novelist:
  • 117 Answers
Thanks for the updated model number. I took a look at your unit and I see from the factor there is a molex connctor if you follow the wires You will see this. Might want to pull out the bottom drawer and tackle this from this area. The wires coming from the ignitor should be long enough to insert them into the hole specifically for the oven ignitor and then from the bottom, make your splice under the unit via the drawer. I hope you are a smaller guy. Been there and done that.....If I can help further, I am here.
Eric Campion
Posted on Feb 15, 2009
    Bottom line is you did get it....When I service in homes, I try not to move the unit unless absolutely necessary. There is alway the liability of damaging their floor. If I can ever help in the future, I am here. Eric
Maytag oven gas flow cuts in and out
probably a weak ignitor,even though they look like they are orange in color they may be weak and not passing enough current to keep the gas valve fully open to supply enough gas to properly heat the unit to temps,replace this part,a good test is to try the broiler,if this works ok then its for sure the bake ignitor
May 05, 2012 | Maytag Ovens
KGHST307HBS6 bake cycle does not heat up, no gas smell, broiler still works, ignitor glows about as bright as the broiler ignitor and was recently replaced. The gas valve recently replaced and no smell of...
you have 2 posibilities the first one is very unprobable and the second will fix the oven
1) the new gas valve is defective and while the proper amprage is being supplied to it,it simply wont open
2) even though the bake ignitor is indeed coming on it isn't drawing the proper amp draw (3.2-3.6 amps) to open the gas valve ,the very fact the ignitor comes on totally eminates that the control isn't providing power to it for the bake ignitor to heat
i have been a appliance repair technician for over 30 years and am 100% confident that by replacing the bake ignitor the oven will work fine
Jul 20, 2011 | Ovens
I have a GE Gave oven. THe top burnes work and the broiler works but when I set the oven to BAKE, nothing happens. THe digital display says it is pre-heating, but it doesnt get hot??
you have a bad ignitor,take out the racks and remove the floor of the oven,you'll see the round ignitor with two 1/4 inch screws holding it on,you can remove the burner tube that the ignitor is connected to with the ignitor on it or you can remove the screws,cut the wires close to the old ignitor and remove it,screw on the new ignitor,leave around6 or 8 inches of wire on the new ignitor,cut back the old wires so you can wire nut the wires together,start the oven and the ignitor should ignite the flame in like 20 to 40 seconds.it doesn't matter what wires you connect,you don't have to worry about if the left wire coming out of the ignitor connects to the same wire the old one connected to,just as long as the wire nuts are tight on the 2 connecting wires you'll be fine.the part number is WB13K21 and the ignitor is around 80 bucks.you can kill the power to the oven but no power is going to the ignitor if the bake isn't on so as long as you don't touch anything else you'll be fine,let me know how you make out
Nov 15, 2010 | GE 30 In Freestanding Gas Range ...
I have a 6 yr old Tappan stove, model TGF657BFW5. the burners work fine, but the oven and/or broiler take 5 to 10 minutes to light. when the oven and/or broiler do light, the flame is only about 1/8 to 1/4...
that ignitor should lite the flame within 40 to 60 seconds if not the ignitor is bad.even though it glows red it doesn't mean it's good it works with amps change the ignitor
Nov 06, 2017 | Tappan Ovens
Tappan 30-3822 will not bake. Top burners and broiler work, oven will not fire.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 16, 2010 | Tappan 30IN ELEC IGNa Oven
Tappan Gas Stove does not ignite immediately you smell gas then it ignites with a burst 10 minutes later. Is this the ignitor?
Short answer is the ignitor can cause this. I can also be a failing valve. Easiest way to decide to fix or not is to swap the ignitor from the broiler and if symptom is gone replace it.
Eric
Jul 18, 2010 | Ovens
Ignitor appears to be working (glowing) but oven and/or broiler do not come on.
The problem is usually the ignitor not reaching the correct amp draw .When the ignitor does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. Even if the ignitor is glowing it may not still be reaching enough of an amp draw. The ignitor are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for testing this.
Mar 30, 2010 | Magic Chef 9122 Gas Single Oven
Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
Whirlpool RBS275PD Electric Single Oven Logo
79 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
