Question about Electric Razor Pocket Rocket Ride-on Motorcycle
The motorcycle dosn't run
I charged it for 2 day's and it never chargers
The battery burns out if you charge it too long. The guy that fixes mine says they should not charge for more than 4 hours max
Posted on May 28, 2010
  • 60 Answers
You probably need a new battery. It is not uncommon for them to just be dead one day .  Check the razr website for replacement parts.  Thanks!
Posted on Mar 11, 2009
Idk man i have this same problem
Posted on May 06, 2010
How long do i charge ever start 16b battery after filling with acid
Hi Anonymous, the "ABSOLUTE" best way is let the battery acid soak into the plates for 1 hour then connect a 1 or 2 amp trickle charger and let it charge for 24 hours for maximum battery life. Read my lips "DO NOT" use a higher rate charger for less hours it will shorten your overall battery life, trust me I was a Harley technician for over 40 years. For more information about your issue please click on the links below. Good luck and have nice a day. BU 403 Charging Lead Acid
Fill and Charge Motorcycle Battery
How to Charge Motorcycle Battery
Battery Basics Layman Guide to Batteries
May 15, 2016 | Motorcycles
How does the charging system on a 1969 Honda 325 cc motorcycle work to keep engine running?
I think you mean a 69 CB350. It sounds like you have a bad battery since the battery charger won't charge it.
On this bike there is an alternator and rectifier that combine to charge the battery whenever the engine runs. If the battery won't hold a charge, the charging system wont work.
Replace the battery.
Sep 26, 2014 | Motorcycles
Charger dosn't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 14, 2012 | Cell Phones
The Battery does not seem to charge so I want to remove it and see if it will charge if connected to an external charger. How do I remove the said batteries?
Remove the batteries .. Every Chair is different .. but if the batteries aren't charging it's probably that they were left uncharged for a time and they dropped down enough that the charger dosn't recognize them .. If they drop down below around 6 volts the charger won't charge them ... I have taken batteries out and charged them individualy with a car charger .. but they never come back .. at best half life.
Aug 31, 2011 | Pride Mobility Products New Pride Mobility...
My xt125r battery wont hold a charge for more than a couple of days.do you think its the rectifier?please help
Remove the battery from the bike ( or at least remove the positive cable ). Charge the battery but make sure water covers the top of the plates in each cell. When charged, disconnect the charger and let the battery sit for two or three days with the red positive wire still disconnected. Now re-connect the red wire and see if the battery is discharged when 2 or 3 days have passed. If so, get a new battery. The batteries only last 1.5 to 2 years. How old is your battery? If the battery DOES have full power after the 2 or 3 days mentioned, start the bike and check the voltage across the battery terminals while running the engine at about 2000 rpm. The voltage should read around 14 volts. If not, there is a problem with the stator, regulator or rectifier. If your voltmeter does show 14 volts or so, and the battery still drains in 2 or 3 days, You will have to find what is draining it. Abraded wire grounding on the frame? Bad switch? Please rate my answer. Thanks.
Apr 16, 2011 | 2006 Yamaha XT 125 R
My on 2007 Enfield bullet have some problem, every thre days battery loosing power so please let me know what is the problem Thank you
it could be a fuw thigs doing this
to many start ups and no running time to recharge the battery up,,,
dud battery ,,wont hold charge,
bike charger not charging the battery up,,,
voltage regulator leaking battery volts back into charger when motor is not running
burnt out or dud rectifier,,,not charging battery or leaking volts back into charger,,
also too many lights fitted for charger to keep up with the extra load needed,
or matbe even that new "**** warming seat" is killing the battery??? hmm?
not an easy thing to answer
Jun 29, 2010 | 2000 Enfield Bullet 350
When Charging a battery with charger do you set it on the 12 Volt 2amp or or 12volt,6amp My Charger is SE-82-6, H943
For charging a car battery that is run down, use the 6 amp setting. The 2 amp setting is for smaller batteries (like a motorcycle or lawn mower battery) or if you are using it to maintain a charge on a battery that is used infrequently (like a boat battery).
May 30, 2010 | Schumacher & Fast Charge Starter Charger
Honda 150 motorcycle, it runs but no lights and
good day Sir, try to check the timing off the magnito and check the fuse i hope it will help you.
Apr 06, 2010 | 2005 Honda CG 150 Titan ESD
Battery died...How to charge
for motorcycles, 2 amp 12 volts max is recomended, usally the slow charge of a car charger
Jul 11, 2009 | 2005 Hyosung GT 250
Electric Razor Pocket Rocket Ride-on Motorcycle Logo
911 people viewed this question
Top Electric Toys Experts
ray gallant
Robert A. Watson
Robert A. Watson
Tom Chichester
Are you an Electric Toy Expert? Answer questions, earn points and help others
