Question about Sharp LC32D62U 32 in. LCD HDTV
Programming a Sharp Aquos remote to control an ExpressVu receiver
Does anyone know if it's possible to program a Sharp Aquos remote control for use with a Bell ExpressVu receiver?
2 Suggested Answers
SOURCE: Programming the Acquos Remote
I got a a sharp LC-32D43U and for my motorola cable box i use hte code 31 from jerrold, i take it from the manual and i got it tryin every single code unti i get one that works.
Hope it works for you
Posted on Oct 21, 2008
Input code 0093 into your Comcast remote. Here's a link for the how to: http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/comcast_dvr_remote_manual.pdf
Posted on Mar 01, 2009
Need help programming my Sharp Aquos remote GA935WJSA to control my Bose Cinemate II surround sound. Cannot find the code anywhere.
it is quite possible that it can not be done the way you think you want it.might have to go to a universal to control both .
Sep 02, 2015 | Televison & Video
Aquos remote programming for rcn
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 15, 2014 | Sharp AQUOS LC40D78UN 40-inch 1080p LCD TV...
Want to know how to set up my bell expressvu remote to control my onkyo tx-sr605 receiver?
If you are trying to use another manufactures remote to control your Onkyo receiver they are the ones who are responsible for programming the Hexadecimal codes into their remotes. We do not have codes for any other manufactures remotes. You may want to try the following website for codes www.remotes.com or http://www.remotecodelist.com for any codes to program your remote. As we do not have the remote controller codes for non-Onkyo controllers- you can try the generic remote controller code: 62503 or 52503.
May 04, 2014 | Onkyo TX-SR605 Receiver
I have a new sharp aquos tv LC 60LE633U. Remote is broken but have a universal Phillips remote anyone know the code ? Help please
Hello
Three digit universal remote codes for Sharp tV are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit codes are:
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 28, 2012 | Sharp Televison & Video
Sharp Aquos tv remote Programming code for Pace(Mediacom)cablebox
Check the cable box for the manufacturers name and see if that isn't listed in your owners manual.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Need remote code for programming a bell expressvu receiver
Here for the Jensen remote just click below;
Here is link to the manual:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Here is some helpful information I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Here are some codes I found for the Jensen 323:
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
Hope it may help you;
Regards,
VOTIT
Jan 27, 2009 | Jensen 143307 Remote Control
Device Codes
UNIVERSAL REMOTE CONTROL CODE LIST We have compiled a list (below) of codes for Universal Remote Controls. .... EXPRESSVU 464. FUJITSU 760 860. GE 265 863. GENERAL INSTRUMENTS ...
dogbytecomputer.com/codes.htm - 34k - Cached - Similar pages see if you code is in here.like my dishnet.remote,some no namebrand tv's just can't be controlled by other remotes
Nov 14, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
There is a code out there to try.  The code would be 47.  Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
Nov 08, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Jul 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Replacement remote for bell expressvu
Here is the link to pdf document: http://www.highspeedsat.com/pdf/satellite-tv/expressvu/remote.pdf
Feb 14, 2008 | DISH Network IR Remote Control
Sharp LC32D62U 32 in. LCD HDTV Logo
850 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
