Question about Hitachi 55HDT52 Plasma Television
Hitachi 55HDT52 Will Not Power On AT ALL!!!
Hello! I have a Hitachi 55HDT52 plasma television and it up and stopped working on me today. The television is roughly 2 1/2 to 3 years old. I have had no problems with it until today. There were no advance warning signs at all leading up to this. I just watched a blu-ray on it last night and the picture and performance was flawless. This afternoon the tv was on and without warning it tuned itself off. Even the standby light is not responding. It basically is acting like it is not plugged in at all. I tried swapping out the power cable and tried another outlet on the off chance that might fix it. Everything else plugged into the surge protector appears to be working fine. I have come to the conclusion that I may be forced to track down an authorized Hitachi repair center and pay what I imagine will be a pricy repair bill. I was hoping that maybe someone has heard of this issue before and might have a suggestion. Thanks. Hi Bradley_64 I have the very same problem the only difference is I didn't use the blu-ray. I watched tv last night into the early morning, I fell asleep, the tv went off and this morning I can't turn the power on except thru the reset button thered light wil come on,then green blinking light then off again...PLEASE,PLEASE, PLEASE HELP ME...I don't have very much money, just went thru a very bad divorce. thanks in advance heavenlyscents58
  • Anonymous Feb 25, 2009
    I have the same issue with the same TV with only one twist....the TV will power but only black screen with audio. The TV (55HDT52) started blacking out at about 2 1.2 yrs old. Would unplug and plug back in and the TV would work again. Several months later the TV screen went black and now only audio works.
    Any techs out there know what I need to check to see what went out. Power board?, YSUS board?,
    Any help would be appreciated. The boards seem to run 250-450 dollars. :-(
    J.
  • SCOTT J May 11, 2010
    look on the back through the holes - you will see several leds light up - let me know wich ones never light up
SOURCE: hitachi pd7200 42" plasma
Its a know fault with these sets - PDU's fail all time, look at avforums.co.uk
Posted on Mar 13, 2008
Basti
  • 1447 Answers
SOURCE: 55hds69 hitachi plasma
First, try the unplug it, wait a few minutes, plug it in trick, several times. If that doesn't work try pressing the power button and slap the back left side of the set several times. Sometimes, this will shock the ballast and/or lamp into working.
Try checking the wires as well if its pinch or not and try to take out all cables from other devices from the back
Posted on May 14, 2008
SOURCE: No picture but has sound
Join the crowd.
Posted on Sep 20, 2008
Fujitsu
  • 29 Answers
SOURCE: hitachi power light blinking
You have problems with the SDR Printed Circuit Boards
You need change them
Posted on Nov 28, 2008
  • 120 Answers
SOURCE: Hitachi P50T501 plasma tv powered off.
Your TV has a bad power supply on it. Ask the repair service technician to fix your tv.
Posted on Jul 27, 2009
No picture no sound , 55HDT52 TV . we where watching it and it just went out ?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 25, 2016 | Hitachi 55HDT52 Plasma Television
Volume but no sound on hitachi 55hdt52 tv
Check its speaker. If it is OK, check and replace the audio output IC.
Jan 29, 2013 | Hitachi 55HDT52 Plasma Television
Can't select inputs from remote or on tv after trying to use photo input to view pictures
memory / software issue i expect. should clear if you power off at plug leave 15 seconds and power on again
Jan 11, 2013 | Hitachi 55HDT52 Plasma Television
Black sreen volume works
There are alot of checks you would have to do on this set. If you are DIY i can give some examples of voltage checks, also you can check
Take a moment to carefully observe the Buffer "Snot" Chips
(Left Side black chips mounted on the SDR Upper and Lower PWBs).
Look very closely for burns and/or small holes in these chips.
If any defect is seen, the PWB is defective.
Replace this PWB and the Y-SUS
Dec 24, 2010 | Hitachi 55HDT52 Plasma Television
Green LED Blinks, no picture or sound
High dc voltage shut down, theres a problem either in the power supply or a circuit external from it. The protection mode is on preventing further electrical damage.
Have it repaired or use the warranty if available..
Nov 10, 2009 | Hitachi 55HDT52 Plasma Television
Problem with my Hitachi 55HDT52 Plasma - won't come on
Ur power inverter board is dead.Can't sustance power.U need a new board.
Sep 07, 2009 | Televison & Video
Component Inputs on Back all Bad
Part # HP01241 ant sw. module. I checked our parts suppliers and it's back ordered till 6/11 with no guarantee it will be in then. Good Luck, hope this helped.
Jun 06, 2009 | Hitachi 55HDT52 Plasma Television
How do I get a wide screen, hi def display on a wide screen Hitachi 55HDT52? Right now I have to choose between chopping off half the heads or losing the captions. I tried to contact Hitachi about a...
I found a phone number for Hitachi and was told that's the way these TVs work. The problem isn't the TV but the broadcast format and their's no way to adjust the height of the picture on the plasma TV sets. I told them it's something they should consider. My $300 plasma montor can do it so why can't a $5000 TV? He laughed.
Aug 26, 2008 | Televison & Video
Hitachi 55HDT52 Plasma Television Logo
281 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
