Question about Viking VGSC306-4B Gas Kitchen Range
One stovetop burner does not initiate igniter sparking.
6-burner (gas) with all components functioning normally except: ONE of the stovetop burners won't initiate igniter. Gas comes on but igniter does not spark - on just this one burner. The malfunctioning one does spark normally when any of the other five burners is turned on. Thanks!
  • Anonymous Mar 02, 2009
    Same as indicated before, have GE 4 burner w/ only one not functioning correctly. It does work when another burner is in use. ????
  • toharrov Mar 09, 2009
    To PHOTIADIS: I appreciate your helpfulness and I'll give your suggestions a try! Thanks!
    TOHARROV
Its most likely the igniter. It might just be dirty, but its easy to install a new one. They are attached by two screws and a single plug. I'd suggest turning the power off to the stove before plugging in a new one.
Posted on Mar 08, 2009
My rangemaster professional + 90 gas is when you turn on the oven and turn up the gas all the burners igniters start working can you please help .
Hello. Normally the ignitors WILL all start sparking--only the burner you've initiated will turn on. All the ignitors are wired together with a harness underneath the cooktop. This harness is connected to a spark module and when you choose whichever burner, it simply energizes the module. Only the burner with gas flowing will ignite. I hope this helps you!
Sep 03, 2015 | Rangemaster Kitchen Ranges
One front burner ignites but the igniters continue to spark. when all other burners ignite the igniters immediately stop sparking. this problem started right after spilling some water on burner.
I would make sure you have wiped up all the water you spilled, You may need to take the burners off the stovetop and make sure the tiny little pinholes for the gas to come out are fully dry, Than re-assemble everything and try again.
Jun 06, 2010 | Cooktops
Ran out of propane, Stovetop has ignitors and they seem to be functioning fine. When turning on knobs there is plenty of propane smell but the burners fail to light.
This is normal when you run out of propane. Depending on the length of line you have, there will be a delay in relighting it again because of insert air in the line. My advice to you is to first air out the house til the smell is gone. Then turn on only 1 burner with the igniter sparking and also hold a handheld bbq lighter at the burner to ensure that the gas burner lights when the air is finally purged. This should only take 20-30secs. If it takes longer, air out the room and try again. Use common sense and please be careful!
May 18, 2010 | Thermador Cooktops
How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Jan 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Burners ignite simultaneously (clicking)
When you set a burner to light, all burners spark. This is normal. Move knob back off the spark position as soon as burner lights. All sparking will stop.
Sep 04, 2008 | DCS 48 in. CP486GDSS / CP486GDSSL /...
Viking model VGR48 stovetop burners will not ignite?
First shut off the gas supply & disconnect electrical power to the range.
  • Remove all the burner control knobs, grates, burner caps & trim rings.
  • Remove the 2 screws securing the manifold panel, one from each corner. The panel will drop down.
  • Remove the screws from each manifold pipe mounting bracket. Remove 1/4 inch hex head bolt from the center of the manifold pipe. Push supply tube back to release from manifold pipe. Lift the cooktop assembly at the front to clear the 1/2 inch locator pins attached to the top of the bodyside.
  • Place cardboard between each side of cooktop & bodyside to prevent damage.
  • Move the cooktop to one side, being careful not to put stress on the wiring harness on left side.
  • Remove the wire from the electrode.
  • Remove the screw from the electrode mounting bracket to release the electrode.
You can replace the electrode & reassemble following instructions in reverse order.
Aug 20, 2008 | Viking VGSC306-4B Gas Kitchen Range
Igniters do not spark on one side of cooktop
Is the gas able to flow freely through and out of the bad burners? Sounds like they may be clogged somehow
Jul 11, 2008 | Jenn-Air JDS8850AAS Dual Fuel (Electric...
Stovetop ignitor
Not that this will fix it for sure, sometimes it does. Remove the top of the burner that is causing the problem, and take some sand paper and clean the top of the ignitor and the bottom of the burner itself. That will sometime cure the problem. If not, you could have a bad spark module, or a wiring issue.
May 23, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Gas stovetop not igniting without matches
If the rest of the surface igniters are working, more than likely your spark module is working fine. (This is normal, by the way) I would suspect that you have a bad spark electrode at the burner in question, a bad burner switch, or bad wiring.
I found several part listings for the model number you posted this question under at repairclinic.com. You will need to provide a more complete model number in order to narrow your search to ensure you get the right part. You can find your model number on a nameplate around the oven door opening, or lower drawer opening (if equipped). Some manufacturers also place this information on the back of the range.
I hope this helps answer some of your questions. Please reply back to this posting if you need further troubleshooting guidance.
May 14, 2008 | KitchenAid KGST307 Gas Kitchen Range
Viking VGSC306-4B Gas Kitchen Range Logo
438 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
