Question about Kenmore 12502 Top Load Washer
Water still in bottom of tub after drain/spin cycle
Sears Kenmore Type 111 Top Load Washer - after drain & spin cycles, there is still water in the bottom of the tub and we have a significant amount of water pooled on the floor under the washer. I can hear the water draining thru the hose so the pump is working. I think something (a sock or something small) may be blocking the drain but I can't figure out how to get into the tub area to check. Thanks!
  • Anonymous Feb 14, 2009
    Sorry - can't figure out how to respond to update original request! Washer type is topload Kenmore Type 111 Model 110-26682500 s/n CS2601667. What's happening is not all of the water seems to be draining at the end of either the wash or rinse cycle (the pump runs). There's a lot of water that runs out of the bottom somewhere & ends up on the floor. At the end of the complete cycle, I can also still hear water sloshing around in the bottom of the machine. This occurs occasionally so I'm thinking there's something clogging the drain so it's not emptying all of the water. Thanks.
  • Affordable Appliance Parts
    Please supply a verifiable model number so we can see your unit as you do. In order for us to provide you accurate information and supply you with the correct manufactures part numbers , we will need the complete model number, serial number and batch or series numbers (if applicable) found on a business card size metal/foil plate. If you are having difficulty locating this identification label, follow this link which will take you to a Website where they have pictures of common locations where your model number ID label can be found. Here is the link: http://www.affordableappliance.com/Tips/... Once you have the updated information, please reply to this forum.
    Waiting to hear from you,
    Eric Campion
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Posted on Feb 15, 2009
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Washer sticks on wash cycle; runs continuosly on spin cycle
That sounds like you have one of them fancy water saving outfits with a diverter valve that dumps the pump water continuosly over the clothes. Weirdest washer I ever saw. Could be the solenoid that opens the drain pump has failed. Don't know too much about em but I do have the service manual. Post your model number for a more precise answer. Whirlpool Catalyst washer manual
Apr 24, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore Top Load Washer and when it goes into spin cycle the clothes are still soggy when the the cycle is complete. I can hear and see the spin cycle working but it seems to be not strong enough...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Initial thoughts point to two possibilities.
1. There is some type of blockage in either the hoses to or from the pump or the pump itself.
See the following for how to access the pump and check it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134
2. The clutch linings are excessively worn. If they are too worn, the transmission cannot provide full power to the tub for spinning.
Following is a description of how to access the transmission and clutch.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the clutch linings are shot, Sears (and Whirlpool) have replacement kits for the clutch lining. You don't have to buy a complete clutch.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Type 111 filled with water and stopped
with the machine off, turn the cycle dial around 3x very harshly, then try it again. If it works normally now, you'll need a new cycle switch soon!
Mar 27, 2009 | Kenmore 24032\24036 Top Load Washer
Washer stopped in first rinse cycle
do you hear a clicking noise when you close the lid if not check your lid switch
Dec 30, 2008 | Roper RAB2121KW Top Load Washer
Kenmore 22062 will not cycle correctly
Problem fixed. I took apart the bottom of the washer to access the pump, and found that there was underwire from bras stuck in the discharge tube blocking the water from exiting the washer and that was causing the cycle problem. I guess that the washer knew that there was too much water in the tub and kept trying to expel it.
Nov 14, 2008 | Kenmore 22062 Top Load Washer
Water after spin cycle
remember ,,the tub has a balance ring on top..and that filled with water,,,if your getting water at bottom make sure your drain hose is at proper height,,,+theres always water between the pump and the drain hose no unit can drain 100 per,,
Nov 05, 2008 | Kenmore 24902 Top Load Washer
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 12502 Top Load Washer Logo
528 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
