Question about Ruud UAKA042 Air Conditioner
Air conditioner fuses
11 month old ruud energy star unit were would i find the fuses to make sure there not blown
  • Ken Bledsoe May 11, 2010
    Have you looked on the disconnect attached to the side of the house?
  • 56 Answers
If the unit is located on the roof then they would be in the disconnect box up there. If it is on the ground then the same. If no disconnect box if found then check you breaker box for a tripped breaker.
Posted on Feb 16, 2009
There is no power samsung wa5451anw/xaa-0002
hum not good
sounds like something has fused and blown the mains
you need to look too a control board error for this ...
its a job for a tech,... for sure..
Mar 05, 2015 | Samsung WA5451ANW 4.7 Cu. Ft. White...
I have a 15-year old Ruud Achiever 10 A/C unit outside that has blown a second set of fuses in just a month. The fuses are in the box on the wall adjacent to the unit. What may be causing the fuses to...
A BAD RUN CAPACITOR INSIDE THE CONDENSING UNIT ?.SEARCH YOUR AREA FOR FREE CAPACITOR TESTING.OR LOCAL ELECTRIC MOTOR REPAIR.. CHECK THAT FAN SPINS FREE, IF NOT, IT CAN BE OILED .. SEARCH POST ON OILING FAN MOTORS
Jul 26, 2011 | Ruud Matching Split Air Conditioner
I have a panasonic nw -h665 Microwave. 3 months old. It just does nothing. Fuse Maybe Blown? and where is it ?
3 Months old? Under warranty surely. Just call Panasonic Repair Service for a free repair.
There are fuses in there but they don't fail for no reason.
Jan 14, 2011 | Microwave Ovens
Modle ruud model ugra09ezajs issues keeps poping 3 amp fuses. A coils is clean and so is outside unit. all new bourd 2 months old
Hello,Only 2 things it could be (1 )the wire to the outside unit is shorted someware.Run a new one or locate where it is touching.OR (2) the contactor coil is SHOT replace contactor (outside unit).
Sep 21, 2010 | Aranizer HVAC-1 Air Purifier
I do have the Ruud split unit. My drain line was clogged and when I cut the line at the unit alot of water ran out. Could that of caused it to stop working. The fan will come on but I get no response...
Check for some type of float switch in the condensate pan. It will shut down the unit to prevent more condensate but I am not sure if it would still allow the indoor fan to run.
Sep 21, 2010 | Ruud UBHC Air Conditioner
House has power but AC and thermostat seem to be off. Thermostat doesn't even show a temperature reading.
I would check the inside unit on the main board and make sure the fuse is not blown. Hope this helps Tim
Aug 26, 2010 | Ruud Matching Split Air Conditioner
Its a ruud air conditioning unit manafacture year is 1990. It won't come on at all.
if you dont know what you are doing it is best to call a professional. you could damage the equipment or get yourself electrocuted.ask your neighbors who they use.It could be a simple problem or major,hard to say without looking at the unit.Most common problems are simple repairs such as blown fuses,bad contactors/capacitors and are not that costly.
Aug 09, 2009 | Ruud UBHC Air Conditioner
I have a 23 year old Goodman 4 ton HVAC system that has done well but is needing more repairs more frequently. I am looking to replace the unit but anything I install will be placed on credit which is not...
A 23 year old unit will be a major energy hog.You will see a massive improvement even with a less efficient unit,but go with the energy efficiency.The price of fuel is going to keep going up,and you will be using the furnace for many years.I'm in Ohio,and we get by just fine on electric for the very rare occasion the temperature drops below the level where the heat pump cant keep up.If this really worries you,you can put a couple space heaters back for emergency.Of course your talking about a gas unit,or a dual fuel unit.The dual fuel would be your best bet of course for ultimate fuel efficiency,but they can be pricey for the ones with all the bells,and whistles.Some will even use the fuel that is less expensive at any given time throughout the day.For example in some circumstances electricity is more expensive during the day then at night.Ultimately you have to figure out how much energy you use on average to heat your house.If you know the efficiency of the unit you have now you can estimate the actual output energy that is actually needed to heat/cool your house.Which would be the effective output of the old unit.Figure out how much less energy input you will need with a more efficient unit to get the same average output as the old unit.Subtract the energy usage for the new unit from the average energy use from the last winter.This will be your approximate energy savings.This should give you some Idea of the energy savings.
Jun 24, 2009 | Ruud UBHC Air Conditioner
Ruud UAKA042 Air Conditioner Logo
327 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
