Question about Philips DVDR3320 DVD Recorder/VCR
Won't recognize blank DVD+R disc
Can't direct dub on my DVD recorder from vhs tape. It won't recognize the DVD+R disc
  • 8,596 Answers
Try the next disc in the stack, and see if it will recognize the next one. If not, the problem is most likely the recording speed of the +R disc. Before you go changing disc types, however, I would also check the Record Mode you have set for the dub - if the REC Mode is set for XP, try changing the mode to SP and see if you have any luck. If it still won't work, try one of the tested +R discs:
SONY (2.4x, 4x, 8x, 16x)
TDK (4x)
Mitsubishi (4x, 8x)
Ricoh (2x, 4x, 8x)
-Tha Mp3 Doctor
Posted on Feb 15, 2009
Dubbing VHS to DVD With Magnavox
If you are trying to dub a commercial (pre-recorded) tape it will not work. If this is not what you are trying to do, get back to us.
Jun 07, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: http://www.lg.com/us/tv-audio-video/video/LG-dvd-recorder-RC897T.jsp . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
Just got this Toshiba DVR620KU and need to record from home movie VHS to DVD. Have DVD-R, I have set the time, have it on the program VHS to DVD, I start the VHS, put it on pause. Go DVD, select rec...
Good one!
Sounds like you are doing everything right. Only things I can think of are:
- Make sure the disc is a blank one.
- Try a different disc.
- Make sure the tape you are trying to dub is not encoded with Macrovision copyguarding. If it is a home-made recording then you are OK, but a factory recording on a store bought tape may cause some difficulties.
If you are still having troubles try a complete 15 minute reset by unplugging from the power source.
Apr 22, 2010 | Toshiba DVR620 DVD Recorder/VCR
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How do we dub VHS to DVD without remote?
Fisrt, is it set up already to dub. It willnoe finallize if not. If so then just put a blank dvd in, push dubbing, insert tape, check source to make sure it is going to dvd then push dubbing again
Jul 09, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Will not record on a DVD R
what I would do is play the vhs tape for a bit then rewind and press the dub botton only and see what happens. if nada then insert a new blank dvd and make sure its formated.
Apr 05, 2008 | Sony RDR-VX530 DVD Recorder/VCR
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Philips DVDR3320 DVD Recorder/VCR Logo
275 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
