Question about Solis Palazzo Espresso Machine
Hi, cleaning cycle stalled, all lights on, machine stuck
During the cleaning cycle, our machine stopped with the red light coming on.  Could ventalate at that point, but didn't.  Turned it off, waited and now all lights on, and no buttons or switches function.  Caffine withdrawal commencing, not happy
We forced the mechanism!! Works like a charm!  I think we'll get a backup, the french press didn't cut it this AM.......
Posted on Feb 16, 2009
  • 1,089 Answers
Hi
First off. When you do a descale you must let the machine finish each cycle and that is when the pump stops and you will know this when all the lights flash.
You have finished the first part of the descaling process. Now you need to rinse the machine with clean water. and let the machine quit on its own. That will clear the descale light, then you will have a green blinking light and a red steady for the water. Refill the water tank and prime the machine. that will clear the red light and it will start heating.
Posted on May 24, 2009
Why would a whirlpool duet sport model number WFW8300SW05 starts fine stops during cycle. No error codes door locked red light on water in machine.
you have a plugged or partial plugged drain pump for sure. maybe there is a 20 stuck in it this time! easy to find just follow the drain hose back and you will find your pump.
also could be the cycle your using has a bad area in timing cct. check a different cycle like the delicate cycle and that will confirm pump or cycle
Jun 10, 2014 | Washing Machines
Saecco
When the red light comes on as soon as we start the machine and starts the grup and grup stops or moves very slow then the problem is at the board which leads grup.Usually is transistor TIP33C.
May 04, 2014 | Saeco Coffee Makers & Espresso Machines
Washing machine would not start
On the lid is a switch that turn off the washer when the load pushes against the top. You may have over-loaded the machine.
Feb 26, 2014 | Indesit Washing Machines
My top loading machine will not complete an entire cycle - it stops during the rinse cycle - so I have 1/2" of water in the bottom of my machine - Fisher and Paykel
Hi just read your posting.Now what I need to know is the model number of your machine which can be located on the back on a sticker.Also when it stops in the rinse cycle does an error code appear in you LCD screen if you have that model or do a series of lights come on and in both models it beeps.Now if you have the model where the lights come on they will be in a row of 8.Starting from the left to right what lights have turned on when it stops in the rinse cycle Is it the 2nd and 5th or the 3rd and 8th --etc-?Please reply with this additional information and I can help you rectify this fault for you.
Jun 22, 2010 | Washing Machines
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Saeco Vienna Deluxe starts brew cycle then red light comes on
Hi
I think you put the tubes on backwards to the flow meter. The inlet side of the flow meter is by the pump and the exit to the pump is by the water tank. They cross.
Jun 29, 2009 | Saeco Vienna De Luxe Espresso Machine
Machine stops during the wash cycle.
Hi this is abhishek,welcome to fixya
over weight normally doesnt cause machine to stop during the wash cycle,,iit is actually tub gettiing stuck or a timer problem...
thank uy........
May 03, 2009 | Bosch Logixx WFR 2867 Front Load Washer
Dishwasher sticking half way through cycle
Crawlmom, it sounds like your door latch assy. and switches are not making properly sometime during the wash. Therefore the two dashes. You want to make sure that the dishwasher is level and securely mounted. Another thing is, on this model, if a key pad is stuck, the dishwasher will stop and flash the stuck key. Im not sure where the red light is coming from. Without being there, I'm leaning on the door switch assy. Check this out first and post back. Catriver.
Apr 15, 2007 | Kenmore 24 in. 16939 Built-in Dishwasher
Solis Palazzo Espresso Machine Logo
418 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
