Question about HP Pavillion ZV6000 Notebook
Problem with screen
I am having a problem with my screen. It has some sort of bad connection in the screen or behind the screen. Some times the screen will have some horizontal lines and some times it will start going white with fine black spots. This might sound bad, but if you tap the back of the screen you can get it to clear up. I'm resonably sure its not the inverter. Thanks
  • Andrew Hawkins
    Andrew Hawkins Feb 15, 2009
    I already pulled the screen off, cleaned the contacts of the ribbon cable and plugged it back in. It made an improvment but didn't fix it. I also unplugged both connectors on the inverter and plugged them back in. Still nothing. Thanks for your reply
  • HP Master
  • 4,806 Answers
Hi there
Obviously a disgruntled Fixya member!!!
Ok, it sounds like you just have a bad connection either at the inverter end (bottom of screen) ot the cable that goes to the top behind the screen has worked loose.
To fix this, you might have to remove the lid from the base of the laptop, but i find that unscrewing the bezel (plastic that surrounds the screen) and removing the plastic and re-seating the connections again, you have to be carefull though as the ribbon cable behind the screen is fragile.
Good luck and thanks for using Fixya!!!
Posted on Feb 14, 2009
No Picture or sound on my JVC HD-56FN97 Television
No, if bulb is bad you will not see anything on screen.
Are outside sources connected to different inputs on TV?
Apr 13, 2014 | Televison & Video
The LCD screen intermittantly flashes
It could be the on/off switch that turns on/off the monitor when you open and close the lid. If the hinges are lose, damaged due to a drop, jar or have dust, dirt, etc. it will get stuck. If you have canned air clean around the hinges. Also there is a ribbon cable behind the monitor and a backlight at the bottom of the monitor. This video will give you the idea: http://www.youtube.com/watch?v=2Yi6GNFcP3w
Dec 15, 2012 | HP Compaq nc6000 Notebook
52 Inch RCA D52W17 BYX1 projection screen tv cuts off when i TURN ON
The set literally has a 3 strikes and you are out where it will try three times and go to shutdown.
The common issues this set has are bad solder connections under and around the high voltage transformer and also in some cases the High voltage splitter block (located way up front behind lower grill below screen unit and behind a removable inspection plate).
The transformer rarely fails but can--photo of what is general appearance of this type of part is attached.
Oct 26, 2012 | Televison & Video
Dust behind the screen
i think you want to bring it to the notebook center,it's strongly recommended because notebooks LCD is a bit fragile
Aug 22, 2012 | HP Mini 1000 Netbook
Will not come on screen black power light on,
Try connecting it to an external monitor when you boot up and see if you can get some sort of indication about whether the machine is actually booting up or if it is completely dead.
You may have a bad screen or screen inverter, or a bad motherboard. I see these kinds of problems frequently and they usually take some time to track down the cause.
Jan 07, 2010 | Acer Aspire One PC Notebook
It is starting to have a convergence problem, for a short time then go back to normal. There is a big bow in the middle of the screen.
carefully remove the back of the tv and look for the convergence panel then make a note of where the plug/socket connections go then remove
once you have done this use a good soldering iron and re-solder any bad connections on the panel
that should sort it , post back if you have any more questions.
Sep 15, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Hitachi Ultravision 46UX50B Flickering/Dead Display
It is possible that you have some loose connections, but I have seen the relays in the power supply get to be intermitent and will not stay closed. Tapping lightly on the relays will usually tell whether or not they are bad.
Jun 30, 2009 | Televison & Video
Wavy diagonal lines only with component cables, not hdmi
You have a bad format board which is no longer available. the DM chassis can be sent in for repair by an authorized Mitsubishi servicer Call mit at 1 800 332-2119 they might help with cost of repair have receipt and purchase date available.
Jan 12, 2009 | Mitsubishi WD-62725 62" Rear Projection...
HP Pavillion ZV6000 Notebook Logo
70 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
