Helo i m Babar i have dell Optiplex gx520 one day i on my Pc after lot of weeks i saw the diagnostic lights 1,4 are stable and battery light is also on what should i do for it? please answer it!
That's TWO Problems bro: Your RAM is not SEATED properly and the CMOS Battery is probably very low. Pop the Side panel open with the computer UNPLUGGED. Check to see how many slots of RAM are in the PC. REmove them one at a time, then put them back in carefully, listening for a type of CLICKING sound that indicates proper seating of RAM STICKS. Remove the CMOS battery and install a NEW One. It looks like a NICKEL. After that, plug up the computer with the side panel STILL off to check and see if the lights stop blinking. If they do, shut the computer down again, UNPLUG it and re-fit the side access panel. PROBLEM SOLVED!!!
SOURCE: Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
SOURCE: Dell Optiplex GX520 message:
Hey,
there is a 3 volt flat battery inside the computer, it in most cases clearly visible.
Replace it with the same type of battery, then adjust the clock in the system setup.
All done, all fine.
Let me know if you need anything else.
Thanks,
Ekse
SOURCE: Dell OptiPlex GX520 PC Desktop Problem
Hello everyone, check your cpu - I've just had one of these in for repair and the cpu was faulty - removing the ATX 4way 12v lead let the pc start rather then detecting a short and shutting the psu down. Changing the cpu cured the fault.
Thanks
SOURCE: dell optiplex gx520 keyboard
If your dell machine is recognizing the keyboard properly and installing its own built in drivers properly then the USB ports are working and it a problem with your keyboard
SOURCE: My Dell Optiplex GX520 will not boot. There is no
If 1 & 2 are off ... then you have problems.
Memory modules are detected, but a memory failure has occurred.
According to Dell's notes:
Their remedies are:
