Question about JBL PB10 Subwoofer
Blown fuse on JBL Pwerbass PB10 Speaker
I have a JBL subwoofer model PB10. I had a power surge at my house and now the 1.25A slo-blow fuse has blown. I have replaced it with a 1A slo-blow fuse and it blows. Any suggestions outside of sending it to a repair shop?
  • Anonymous Mar 23, 2009
    wher do i finf a 3ga type "T" fuse for my jbl pb10
  • agap Mar 24, 2009
    My JBL subwoofer has lost power completely. I do not know where the fuse is so that maybe I can replace it.
4 Suggested Answers
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
blueextc3221
  • 15935 Answers
SOURCE: JBL PB10 subwoofer, it makes a loud burp noise when it comes on.
In the industry - It is called "Turn-On Thump".
There are some manufacturers that eliminate components like noise filters on enry level lines to save money.
There is no way to lessen this noise without ripping the amplifier apart and having a technical knowledge of the way amplifiers work. It would involve hard-wiring a slow charge capacitor in the turn on line so it gradually builds power instead of getting it all at once.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 10, 2009
budmrtn
  • 11361 Answers
SOURCE: JBL PB10 subwoofer sounds distorted and lights on the front flash
More likely to be the Class D power amp module, but you should look through the service manual to make sure all the parts are installed correctly. My PB10 AMP module went out and you cannot get one anymore.
http://manuals.harman.com/JBL/HOM/Service%20Manual/PB10%20sm.pdf
Posted on Nov 10, 2009
Hand amp fuse blown
you can change the fuse or wrap it with aluminum foil
Mar 28, 2013 | JBL PB10 Subwoofer
Interested in your Infinity sub repair; could I send you some images to verify infinity TSS-1100 has no light, seems blown to me, not sure if it has the screw you mentioned
Hi my name is MIchael and I repair the following amps JBL PB10, PB12, PS10, PS12, TSS-1100,TSS-1200,VENUE SUB12, E250P. If it has the screw near the on/off switch. If your amp is blowing the fuse, has bad sound, no sound, doesn't power up or if the output is low or muffled. We can fix it - please check ebay and search WE REPAIR JBL PB10, PB12, PS10, PS12, TSS-1100,TSS-1200,VENUE SUB12, E250P - you will find us ... Edwards Electronics ....
Oct 24, 2011 | Infinity TSS-1100 System
Jbl pb10 subwoofer will not come on, that is the two lights in the front will not come even though it is plugged-in
1/ Check the power outlet, dont laugh i have been caught by this one
2/ Is the power cord removable (2 or 3 pin) if so then try another cord.
3/ If not check to see if there is a power switch in the vicinity of the cord
I know it sounds stupid however it does happen.
4/ Check to see if there is a fuse in the same area.
5/ If not you will have to remove the cover back, front, or bottom
to gain acess to the internal power supply, there should be a fuse in
the power supply and or a fuse in the amplifier circuit and or the speaker line.
binary6
Sep 16, 2009 | JBL PB10 Subwoofer
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
Jbl eon15p-1 my speaker it was working fine after 30 minuts wont turn on
Mine has a blown power supply transformer. There are 2 fuses on the power input board. One of the fuses on mine blows instantly because the primary on the tranformer has gone short cct. A $200 part from Jands !!!
Jan 07, 2009 | JBL Eon15P-1 Main / Stereo Speaker
JBL Eon 15 Blown Fuse
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
Dan
Aug 14, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Fuse blows
Presuming you're referring to the circuit breaker in your house, it's probably because you have too many items on that circuit. Your best bet would be to find another power outlet that is on a different circuit, and plug some things in over there.
Jun 17, 2008 | JBL PB10 Subwoofer
Thump at the time of shutoff
The amplifier in the sub as with any other amplifier has a capacitor in it. Essentially a battery that holds a charge. When you trun things off such as subs or amps with a powerstrip instead of the intended on off button, the power supply has been cut, but the capacitor is still energizing the unit. So it catches the noise in the line.
Mar 07, 2008 | JBL PB10 Subwoofer
JBL PB10 Subwoofer Logo
326 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
