Question about Poulan Pro Chain Saw 46cc 20"
Chain saw trigger
Does anyone know the exact way that a trigger/lock out assembly with spring attaches?
  • dennis110519 Feb 15, 2009
    My trigger locked up and I took the trigger/lookout from the chassis of the chain saw to check the spring to see if the spring had become misaligned or broken, looks like the spring is good but is not on the trigger or lock out. how does this attach?
  • David Ford
    David Ford May 11, 2010
    Are these poulan saws. If so go to psep.biz with your model and type number and you can view a breakdown online.
    President:
  • 2,220 Answers
You don't tell me the make or model, your answer can be found here:
Homelite/Ryobi.com
http://www.gardnerinc.com/recons/disclaimer-lg.php
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Lou
Posted on Sep 05, 2009
Model 137. How do I assemble the brake spring?
Husqvarna Chain Brake - YouTube
? 7:13
https://www.youtube.com/watch?v=gK7eKakMCz8
Feb 13, 2011 - Uploaded by thoughtfulace
... brake assembly and install the spring in the cover of ahusqvarna saw. ... Next time I will try to remember to disengage the brake first. .... How to Remove a Chainsaw Clutch Cover and Reset the Chain ... Restricted Mode: Off.
husqvarna chain brake is stuck. easy fix - YouTube
? 6:31
https://www.youtube.com/watch?v=usP5XaXO7-8
Dec 19, 2012 - Uploaded by Plotnikoff Nate
How to fix your chain brake from being stuck locked to unlocked the easy way. ... BTW, I will NEVER sharpen a chainsaw again. This new chain ...
How to assemble the brake spring on a 137 husqvarna ...
www.fixya.com/.../t26010777-assemble_brake_spring_137_husqvarna
Dec 16, 2015 | Husqvarna Garden
Need to replace trigger lock. It appears that I will need to tear down the saw down.
Hi Bob:
Looks like you've got a nice little "rainy day" project.
Chain saws are notoriously friendly to work on.
I'd start by taking the bar, chain, and associated plates off, then giving it a really good clean. Solvent and compressed air do a great job.
- next step is to remove air filter cover so you can see the carb.
- follow the linkage back to where it disappears into the trigger assembly in the handle.
- a couple of screws will split the handle and reveal the trigger and lock.
Excellent project!
Enjoy.
Nov 26, 2015 | Garden
Poulan Pro PP5020AV pull cord won't retract
You need to wind the spring back in a coil at a time, it is not easy if you have never done one, order a new spring, this will come pre wound in a cassette and is an easy fit.
Nov 22, 2012 | Poulan Pro Chain Saw 46cc 20"
The choke on a Poulan Chain Saw that I just bought will not stay out to start it.
There are two types of choke systems, the basic choke has a ball and spring in the carb body which locks the choke either in or out, the other type is connected to the half throttle position, once pulled out it stays out, however if you lift the throttle trigger it will go back in on its own, queation, are you holding the throttle trigger whilst trying to start it, if so this is why it will not stay out, if this is not the case, pull the choke out with a little more force, it may be just not coming out enought to lock.
Feb 28, 2011 | Poulan Pro Chain Saw 46cc 20"
Replace starter rope spring part no 545008013 on the poulan p3416 chain saw. How to get the spring coil seated in the housing, and then get the starter rope part on top of it.
Hook the spring at the inner mount, then wind the spring CCW until the spool assembly can be attached to the outer spring, then continue to wind the spool until the spring is about half-tight or so. It must be able to wind about three or four turns more without becoming 'bound' which would lock the spool and not permit return of the cord. When the spring is wound, wedge it so that the cord can be attached, the work the cord around the spool so that the outer end will only project beyond the cord port a little way. Pull the cord out to make sure that the spring doesn't bind at full extension, the apply locking pliers to the cord to be able to attach the handle. Melt the cord ends to prevent the knots from pulling out. Hope this helps!
Jun 15, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Spare parts for spear and jackson strimmer spjbc30
solent tools tel 023 8057 8057
email sales@solent tools.co.uk
Jun 15, 2009 | Husqvarna Chain Saw 20" Bar
The throttle trigger and trigger lock are both jammed in and I can't get the saw started. it's a Poulan 16 inch chain saw. Does anyone know if there is something I can do to release them short of taking it...
Clarification Request
Posted by dontbother10 on Sep 16, 2009
We need the make, model, and serial numbers from the manufacturer’s tag to help you farther.
I think your rivits are roll pins but without clarification cannot verify that.
No response to clarification request. Close
May 11, 2009 | Poulan Garden
Poulan P3314 Automatic Oiler
Go to Poulanpro.com and look at a parts explosion and they also have a toll free number that might help. let me know if not and I will research more.
Jan 10, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan Pro Chain Saw 46cc 20" Logo
303 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
