Question about Ideazon MERC Stealth Keyboard
O key is constantly failing
I have spent more time correcting my spelling because of the "o" key failing so much seems all the other keys work ive tested it in notepad and it definitely fails about 1/3 of the time
  • 3,051 Answers
Hi there:
if you take a small flat head screwdriver and gently pry off the key than examine the area where the key is held in place make sure that there is no dirt or debris in the hole blow it out if you can and then reinsert the key it will have a definate snap to it when it is installed all the way now test it and see if that helps ok best regards mike
Posted on Feb 17, 2009
When I make a spelling error on messenger I can't go back and correct it
Put the curser just after the mistake and press the backspace erase <-----< arrow key until it is deleted and then type the correction.
Nov 14, 2014 | Apple iPad (16 GB) WiFi Tablet PC
There seems to be no help for changing font size on incoming e-mails and outgoing. They are way too small. Can't seem to get to font size on printer any moreto correct it. This problem came about when our...
Hi. It sounds like you may have accidentally set your browser text to a small number.
If you hold down the ctrl key, and scroll with your mouse wheel, it will enlarge your text.
Your question was a bit unclear however, so if this isn't the correct solution, please comment, and I'll try to help again.
Oct 10, 2009 | Microsoft Developer Tools
I have a dell Vostro 1510, Ive had it for about a year and havent had any problems...until now. As you know above the keyboard there is a row of touch sensative buttons; eject button, volume contol, play...
After a long use, some keys get stuck i.e. it seems normal but the button under the key remain in contact. Your problem seems like this. Try to open the key board and check the button. It may solve your problem.
Aug 02, 2009 | Dell Vostro 1510 Motherboard System Board...
Ford Focus T Reg (UK) Key Fob Not Working.
it might be the 60 amp black fuse my partner just said
Apr 13, 2009 | 2000 Ford Focus
Lost manual for Smith Corona sl 575 spell right typewriter
how do I replace the correcting tape in my Smith Corona Spell Write XD6600?
Jan 06, 2009 | Office Equipment & Supplies
When trying to text incorrect letters appear
There should be an option somewhere when you are in the message menu on how to switch from the text mode that tries to finish your words for you to the text mode where you have to push the button however many times to get the the single letter you want. Although if you are in the auto finish mode you can simply ignore what it's suggesting and continue spelling out the word yourself if you want. example: hit 9 6 8 one time each to spell the word "you"..buy if your trying to be able to short hand text like "thk u" your gonna have to look around in your text mode settings.
Jan 02, 2009 | Nokia 6126 Cellular Phone
Lock switch stays on
The light goes on to indicate that the shift lock is engaged, so all letter type in upper case (capital) letters, or on machines with "spell check" to indicate a mis-spelled word. It should go out when you hit eithor left or right shift keys, correct the mis-spelled word or just continue typing.
If it just stays on all the time no matter what you do, there is a problem with the main board.
Oct 06, 2008 | Smith Corona Wordsmith 100 Typewriter
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Ideazon MERC Stealth Keyboard Logo
102 people viewed this question
Top Ideazon Computers & Internet Experts
David
David
Joseph Wright
Dayton Computer
Dayton Computer
Are you an Ideazon Computer and Internet Expert? Answer questions, earn points and help others
