Question about Microsoft LifeChat Stereo Headset with Noise-Canceling Microphone
How can i regain audio when not using headset.
Does software block speaker signal/
  • 119 Answers
No the software doesnt block the speaker signal. you will need to go into your sound applet on control panel and designate which ports the speakers are plugged into and which the headset is plugged into. very easy set up and at least in windows xp it even prompts you if your plugged into the wrong port it will tell you the right one to change them to.
Posted on Apr 01, 2009
No sound on laptop
IF you're allowing to adjust the sound volume from your laptop,,, that's means that you have good sound driver software. try to connect audio system or headsets in audio input jack, If there's no sound come out from the headsets?,, update your sound driver and wait for the results. Having the sound from the headsets and nothing from laptop speakers... the speakers of your laptop is defective.
Aug 18, 2014 | Toshiba Computers & Internet
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
Lg tone keeps losing connection
Bluetooth wireless signal can be blocked by your body and even by your head. Try orienting yourself so that the audio source is directly in line with the bluetooth antenna in the headset.
Mar 26, 2014 | LG Stereo Wireless Bluetooth Headset Tone...
I have a Plantronics monoaural headset Audio 310 which is failing to give me a strong microphone signal - going through Control Panel (Sounds and Audio Devices - testing). I am using a voice to text...
Disconnect the microphone from the headset and connect another microphone to eliminate the possibility that it's bad. If the other microphone has the same symptom, then adjust the the sensitivity of the mic through the sound card properties. Or, try another sound card - it may be bad.
Feb 23, 2011 | Plantronics .Audio 310 Headset
After turning on television volume works for several seconds then there is no volume, and cannot regain any volume.
route your audio signals to another audio source like a small set of 2.1 computer speakers or home theater receiver ok sound loss is all to common on cheaply made tv's nowadays simple problem with a simple solution hope this helps
Nov 17, 2010 | Insignia LCDTV26 26 in. Television
Can I use a headset for voice comm. on the VX-5000?
Go to windows setting
Open audio setting
Change microphone resource to the headset
Sep 09, 2009 | Microsoft Life Cam Vx-5000 Webcam
Wireless headset
You do not need an amplified signal. The signal is amplified in the head set. You may need to change the audio settings on the TV change from internal speakers to external amp and/or change from variable to fixed audio out.
Jan 19, 2009 | Sharper Image MC502 System
Headset
You use headsets to have conversations over the internet .. or to have a personalised audio equipment,.
You should have used the mic to start with, as you heard over the speaker your voice,
There are two pins. One for MIc and other for the headphones.
Use mic only when recording. other times keep it muted in control panel-> sound and audio...
you can use headphone for hearing when you don want the audio stream to be on speakers., TO use so, you have to take of the output from the CPU to the headphone pin after removing the speaker pin or configuring the audio controls control panel-> sound effect manager to have sound always in both theh speakers and headphones.
This requires you to have an appropriate configuration so that all 3 pins are aptly placed fot output from the CPU.
Hope you got what you asked for!
Apr 12, 2008 | Labtec C-322 Headset
No sound from my Logitech headset when on SKYPE
Maybe you need to select which Audio device you are using within Skype. It the Settings under Audio you should be able to select the default audio device that Skype talks to. If you set it to the USB headset, it might work properly.
Nov 10, 2007 | Logitech 250 Headset
No more sound from speaker
I had a similar issue on mine. The easy fix was to insert a headset jack and pull it out quickly. I think something got stuck that turns off the speaker after I put the headset in the jack once. If this is the problem, I think you should also see a headset icon when making calls, even though no headset is attached.
Jun 15, 2007 | Sprint Vision PPC-6700 Smartphone
Open Questions:
Microsoft LifeChat Stereo Headset with Noise-Canceling Microphone Logo
128 people viewed this question
Top Microsoft Radio Communications Experts
Adrian W
Adrian W
Level 1 Expert
Are you a Microsoft Radio Communication Expert? Answer questions, earn points and help others
