Question about Sanyo Televison & Video
Can not change channel on my Sanyo LCD TV
Installed a new Sanyo LCD-47XR8DA last night. I did the Auto tune thing and all seemd fine. When I have turned the unti on this morning it seems to be stuck on 1 x DTV channel and 1 x ATV channel. I have tried the remote over the past hour as well as the manual channel button on the unit.
I have read the trouble shooting in the manual without success. My thoughts were that I should have completed another step in the tuning though I can not identify anything. Why would I have any channels at all.
There seems to be quite a delay in the TV recognising a command from the remote. Sometimes the volume works and sometimes it does not.
I have not solved it but, when I play the dvd player it seems to make everything else work....
Posted on Feb 15, 2009
New LG 32LD350 - Allowed TV to auto-program channels, and for some reason, it skipped past channel 4 during the tuning process. When I select channel 4 in the tuning options, it comes up as no signal. On...
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Mar 11, 2011 | LG 32LD350 32 in. LCD TV
Require the instructions to manually/auto tune the tele, Sanyo 80cm LCD TV. Manual has been misplaced.
Most of the time its going to be menu, setup, select the signal type whether cable or antenna, then there should be a selection to channel search, from there you can do manually or auto..
Feb 04, 2011 | Sanyo Televison & Video
Accidentally set tv to display what appears to be closed captions during a program, not commercials - in Spanish, not my language - when searching for a way to have closed captioning. It displays on only...
You have a setting on the SETUP on your remote. You have the option to use English or Spanish. Somehow, you must have accidentally changed the language. I did this on one of my TV's.
Just go through the setup again.
Hopefully this will solve your problem.
Jan 09, 2011 | Sanyo Televison & Video
My Sanyo 26" flatscreen tv
hi,
if u using a cable connection direct to tv. then goto the setup menu and select auto tune function. wait till all the channel memories. for any further assistants contact me through fixya.
ok
Dec 13, 2010 | Sanyo DP26746 26 in. LCD Television
LCD-32 TV.Can not tune in channel 7
81CM HD Sanyo LCD: Was still under warranty, took it recommended repair man and he simply tuned it at his shop!. Perfect when I connected it at home...Bob Tape
Jul 29, 2009 | Sanyo Televison & Video
No sound on my Sanyo LCD 32" flat screen tv
I had this same problem this morning. Luckily, when I reset the whole thing and did the channel search again the sound returned. I have no idea why it fixed it but it did. Hope this helps you.
Feb 12, 2009 | Sanyo DP32746 32 in. LCD Television
We have a sharp lcd tv c/w built freeview,the last couple of weeks it keeps losing just 1 channel ie bbc1 or itv1 every other channel is fine if we retune the tv everything goes back to normal, is it the...
no problem occur on your set but the only problem is you can not lock the fine tuning (in manual procedure) but is it better to set the program to AUTOSCAN OR AUTO PROGRAM and authomatically tune and save to the memory all the program channel
Apr 29, 2008 | Televison & Video
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
590 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
