Question about Kenmore 62622 Microwave Oven
Internal light does not come on
Kenmore model 721 62644200. Everything works perfectly except the internal light. Bulb looks good and tests good using an ohm meter. Might the bulb still be bad? Or is the problem more complex?
Dennis Morelli
  • Kenmore Master
  • 9,086 Answers
Relay RY1 on the control circuit board has probably failed.
It's the relay closest to connector CN1, the 7-pin connector.
Have you had trouble with the cooktop lights of hood vent exhaust fan recently?
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number 721.62644200) for more information & help or see our Web site.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Feb 15, 2009
I found that by tapping the control panel, the internal light would flash. I opened the control panel and started tapping on circuit board components until I found one that seemed to consistently make the light flash. I resoldered the pins on the loose component and this completely solved the problem.
Microwave no longer heats up food
A model number would help us help you pretty specifically, but without it, here's a generic answer.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose or corroded connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron
- shorted high voltage diode
If the inside light, turntable, and internal cooling fan are not working, then it's probably a door switch. See my door switch help file here.
If the inside light, turntable, and internal cooling fan are working, then the problem is likely in the high voltage section.
In that case, here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/cap_test.html
You can find links to helpful exploded view diagrams and order parts here.
I'd recommend that your bookmark this link to your favorites.
Oct 18, 2012 | Kenmore 1.7 cu. ft. Speedcook Oven Hood...
Oven just went dead, no lights, no power etc. checked power source and everything works fine. Sharp Model R-9H66. looking for repair in spokane , WA..can you help?
Possibly the internal fuse. Unplug unit, remove all case screws on the back of the micro. Slide the case toward the back and remove. Look for a glass tube type fuse, simular to automotive fuses of the past. It should be located near the controls. If bad, the internal wire will be broken or burned, I have been able to find replacements at Radio Shack. Take the old one with you. If the fuse is good, I'm sorry, it's beyond my microwave knowledge level.
Mar 03, 2010 | Microwave Ovens
All instruction manuals missing (lost in flood). Also internal light does not work
check http://www.manualsonline.com/
enter manufacturer and model number
for internal light, check the bulb, probably needs replacing
Nov 05, 2009 | Samsung Microwave Ovens
Yesterday while using the stove top to cook some chili the lights under the microwave blew out with a loud "pop". It tripped the breaker switch so I reset it and everything works like it should except the...
Well I'm reaching here---if the bulb did not fracture/break then it sounds like a capacitor popped--check your owners manual for reset button but I don't think there is one for the lighting---In addition if you can see the circuit board--look for burn spot or wet spot. GL
Sep 18, 2017 | Kenmore 80412 Microwave Oven
My microwave will not heat. Everything else works.
hello. i can help you.
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
Jun 15, 2009 | General Electric Microwave Oven
Microwave external underside light no longer works
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights fan can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
May 20, 2009 | Whirlpool MH1150XMQ Microwave Oven
Remove Kenmore Mod. # 5648598601 from wall.
A lot of those you can replace the bulb without taking it down. There should be screws at the top that lossen up the vent in the front. Remove the vent, might have to open the door and slide it to the left (a little latch) then you should see a filter that just comes out and behind that is the bulb. I would try that before taking it down Forgot to mention that in the other e-mail.
Mar 04, 2009 | Kenmore 80412 Microwave Oven
Kenmore 363.6367 internal light doesn't go on
I had the same problem! I was soooo frustrated! But, when my brother came to town, he took off the grill on the top of the micro hood, took out a few more screws, a plastic screen, another screw in the metal cover for the light and then reached in with his fingers to pull out the light bulb, we replaced it, then re-assembled it. It did take us about 30 minutes to do the job and you will need a phillips screwdriver, and a phillips screwdriver drill bit thing, but we were able to do it. I love having the light in the microhood again.
Dec 09, 2008 | Kenmore 63672 Convection/Microwave Oven
No light, internal fan...then no display
The light isn't a safety issue but I would think that the fan would be.
The fan is designed to remove excess heat from unit and keep it cool. Without the fan, you're now operating the unit under conditions that it wasn't designed for.
With the unit unplugged, try removing the cover and see if a fuse has blown. If so, replace it with the EXACT value of the original.
See if the unit powers up again. Try heating heating up something for 30 seconds to see if the Magnetron is still functioning.
If so, check to see if the bulb is good. Did the bulb and fan stop at the same time? If so, it might be something in common that controls both.
Don't operate it further until you have it looked at. You don't want to cause something else to fail.
- Jim
Jan 31, 2008 | Maytag MMV4205 Microwave Oven
Kenmore 62622 Microwave Oven Logo
173 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
