Question about KitchenAid KEMC377K Convection / Microwave Oven
Microwave is arcing. Can it be fixed?
The oven is arcing. Can it be repaired by me or do I need to call a pro?
  • KitchenAid Master
  • 9,086 Answers
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
For many brands, you can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If you need further help, please please reply back with your brand and model number so we can help you.
Posted on Feb 15, 2009
The unit started arching inside the front panel on the upper left corner.
Arcing Inside the Microwave - Martin Microwave Inc.
microwaveglasstrays.com/shop/articles-arcing.html
Microwave Glass Trays, : Arcing Inside the Microwave - Microwave Glass Trays ...glass tray, microwave plate, glass trays, turntable, microwave oven, carousel, ...microwave energy, and will eventually it will start producing arcs and put out one heck... the damage is non-repairable and the unit should no longer be operated.
Notes on the Troubleshooting and Repair of Microwave Ovens
www.repairfaq.org/REPAIR/F_micfaq3.html
Microwave oven does not respond to START button. First ..... but with the leakage from the spot welded waveguide inside the unit. ... My clue in was a spark between the waveguide and the case, when I was messing with the Controller PCB.) ...
MICROWAVE OVEN ARCING ' MICROWAVE OVENS
Dec 15, 2015 | Microwave Ovens
The plastic round ceiling cover in my OTR Samsung smh9187 has always been missing the locking clip/screw and has gotten loose but was easily turn back in position, yesterday it came loose and fell down ,...
Microwave ovens have special coatings on some of the interior panels and covers to prevent arcing. If there was arcing then that can cause the main component in the oven to fail and be expensive to replace. IF you do keep it you have find what is arcing and repair that.
Dec 27, 2014 | Microwave Ovens
Lg combi multiwave
see the troubleshooting section and follow the steps and fix it.
God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Sep 30, 2013 | Microwave Ovens
Oven aftron
follow this steps and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity paint.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#10#ixzz2aaus0Uj3
Jul 30, 2013 | Microwave Ovens
Microwave when turn on making a noise and sparks comin from fan area?
Waveguide Cover
Rack Support
Feb 06, 2013 | Turbo Air TMW-1100M Green World 1000 Watt...
Kenmore microwave is sparking when you it start and then goes to pause
see this steps and fix it. God bless you
If you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
If your microwave has a shelf in it, and you do not use it, keep it out. If one of the shelf supports breaks or comes out, the microwave will arc where the support was. You will have to sand the spot down, paint with appliance paint and re-install support. If the shelf shifts on the support and touches the side it will arc.
Your magnetron waveguide will either come out of the top, or side of the oven cavity. Some will have a stirrer in it(mostly top waveguides) with a panel over, or just a cardboard type cover over it. Over time, the stirrer cover can become warped from the heat which will expose the stirrer's metal shaft which will then cause sparking. These covers and stirrers come in a kit and can be replaced from inside the oven cavity.
Your cover over a side waveguide is coated with a substance on it, and overtime this coating can come off from the heat and moisture in the microwave. These waveguide covers are very easy to replace from inside the oven cavity. Touch up any paint that may have chipped or come off because of the arcing.
If your waveguide cover and/or stirrer are all OK, then the spark is coming from your magnetron. The antenna on your magnetrom has overheated and burned, sending the microwaves out at the wrong angle. If you catch this microwave oven repair early enough, you can usually get by with just replacing the magnetron. If the arcing has caused servere damage inside the waveguide, you will need a new microwave. Waveguides are not replaceable and most you can barely see into them, let alone sand and re-paint. In this case of microwave oven repair, when you remove the magnetron, you will see the burned antenna, or your magnetron will fail the test below.
see the guide for test the magenetron and another component.
Oct 03, 2012 | Kenmore Microwave Ovens
Convection/microwave turntable motor arcing; 7 yrs old is it worth fixing
If arcing and is seven years old time to replace the item, more cost effective with full warranty.
Mar 05, 2012 | Microwave Ovens
Sparkscome from food (no metal involved) and heating VERY quickly!
Arcing in or above oven chamberThere is often a simple cause:
  • Arcing in the oven chamber with a normal load (a cup of water, for example), often just indicates that a thorough cleaning of the oven chamber is needed, particularly around and inside/above the waveguide cover. Any food that gets trapped here will eventually burn and carbonize resulting in a focal point for further arcing. Usually, the waveguide cover is designed to be removable without taking the (cabinet) cover off of the oven. However, burnt food and carbon often make this difficult so that some disassembly will be required. See the sections: "SAFETY" and "Getting inside a microwave oven".
for more information see "Arcing in or above oven chamber" section of online Microwave Repair Manual.
If the microwave is clean, please post a reply and I will look at it again (this time include a model # and/or approx manufacture date)
Oct 21, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Arcing in microwave oven (Welbilt MR95TW microwave oven)
the magnetron is what is arcing.. not sure if i would consider it easy enough for a do it yourselfer. there are a few components that need removing. plus the mw needs to be taken down in order to do it.
Mar 04, 2009 | Welbilt MR95TW Microwave Oven
Not working
This sounds very much like an arc and may produce ozone that you can smell. If it is an arc, the high voltage power supply for the magnetron is at least working and the fact that it is arcing may come from a breakdown of insulation, something that could be a safety hazard if you decide to open the unit - be very careful; the energy needed to feed the magnetron will definitely roast human flesh too.
While there are a number of things I offer guidance for on microwave ovens, this one makes me uncomfortable and I really wish you would either retire it or have a pro look at it for you.
Jan 22, 2009 | Sharp R-1500 Microwave Oven
KitchenAid KEMC377K Convection / Microwave Oven Logo
153 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
