Question about Maytag Neptune MAH5500B Front Load Washer
Wont start how can i turn off a delay start time. my maytag neptune washer is beeping every other minute and flashing d5
  • Michael Masters
    Michael Masters May 11, 2010
    is this a touch pad version. whats the exact issue?
    Novelist:
  • 117 Answers
Try unplugging the unit for an hour allowing the microprocessor to reset. Plug it back in and use as normal. Let me know if this helps.
Waiting to hear from you,
Eric Campion
Posted on Feb 14, 2009
My Maytag front load washer , powers up and lets me change the settings, but when I press the start button , it beeps and displays d5 and wont start??
this fault code ind a door lock problem ,hence this is why it wont start , it thinks the door is not closed , id say the door latch mech. needs service
Feb 26, 2016 | Maytag Neptune MAH9700 Front Load Washer
We have a maytag neptune washer and on evey setting, it's telling us d5 - what does it mean?
D5 means blocked coin 1 or coin drop control circuit failure, coin recognition and price display disabled while blockage persists.
Nov 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front load washer says control lock and wont start and buttons wont work
unplug the washer for 15 minutes then:plug it back in and, restart a few times in a different cycle canceling each time until the door opens. Do this only if the tub is not full of water if it is let me know and, i'll show you how to drain the washer first before we try to open the door.
Jun 09, 2009 | Maytag Neptune MAH6700A Front Load Washer
Maytag Front Load Washer - SD error
hi there,
it appears that you have a door switch problem. the door latches on these machines are equiped with a mechanical switch and if this switch disengages in any way, the machine thinks that the door is open, even if it's not.
the code that you see is actually a "dS", which stands for door switch.
check the door latch, which is where the door switch is located.
thanks.
Sep 26, 2008 | Maytag Neptune MAH6700A Front Load Washer
Maytag neptune error code d5
make sure it is installed correctly - there are 4 yellow plugs at the back that need to be taken out.
May 30, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
May 20, 2008 | Maytag Neptune Washer
Wont work, flashes LR
rapoyner The "LR" error code means "locked rotor". It appears on the display after the machine has repeatedly tried to turn the motor. The cause of the problem could be the motor itself, the motor control board, the main control board or the wiring. If your washer is less then five years old most likely the parts are still under Maytag warranty. It has very sophisticated design and I wood recommend to call the Maytag authorized repair man even if the warranty is already expired. Gendos
Jul 06, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washer
Sounds like you need to replace the door switch
Jun 23, 2007 | Maytag MAH8700A Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
257 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
