Question about Dell 810 All-In-One InkJet Printer
Paper Jam They is no paper jam inside my computer. one day it want's to copy nd print. Then on day it says paper jam and now it keeps on saying paper jam
  • grunty_luv Feb 16, 2009
    I'll put a single peice of paper in there, I'll line it up perfectly; I don't shove it in either. I press print, and it doesn't pull it down. Or if it does, it just does on the right side.
    This usally happens to me for a good half hour to an hour. It's really annoying, can someone please give me a good solution to dealing with this ******** 'paper jam'?
  • Dell Master
  • 13,433 Answers
Try these steps
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
  • 39 Answers
SOURCE: Error message for paper jam when it is actually all clear
make sure you put it in right
Posted on Feb 09, 2008
SOURCE: printer keeps reading paper jam
We had exactly the same problem (and this printer had never been used before) - we fed a piece of thick-quality paper, applied a little pressure from the top edge as it descended, and 'voila' the printer has finally fed one sheet right through.
What it is NOT yet doing is aligning correctly with the top margin of the document - it is more or less cropping off the top portion, but I'm trying to finish taxes and this will darn well do for now.
These printers are cheap plastic junk, manufactured to make the trip to landfill as soon as possible. Damn Canon and all the other corporations making these trashy pieces of electronics. (I still have a LaserJet 5MP, and I'm sure HP hates me for it - circa 1995 manufacture). If I can figure out how to get printer drivers for OS 10.5 (mac) it will leave to see more service still. Grrrr.
Posted on Apr 10, 2009
  • 17 Answers
SOURCE: SHOWS PAPER JAM AND WILL NOT PRINT
Try reseting it meaning kill the power for an hour or so then re start it plugged in. If nto it is the geas, that are almost impossible to fix.
Posted on Aug 11, 2009
uxair shah
  • 812 Answers
SOURCE: my cannon MP160 pixma keeps telling me there is a
Hello thanks for using fixya
Actually you are facing E3 error, E3 error is mostly because of paper jam. their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon service provider.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Posted on Feb 07, 2011
Testimonial: "i had to unload and reload the program. "
azeroth009
  • 65 Answers
SOURCE: Get paper jam message, paper
Please follow this instructions to resolve your issue.
Solution # 1 Power cycle the printer
  2. Unplug the power cable at the back of the printer
  3. Wait for at least 1min.
  4. Plug the power cable again
  5. Print test page using the printer itself (press and hold the OK and HELP buttons on the front panel of the printer, until it will prints a test page, then release the buttons.)
If you still having that error message, please proceed to the next step.
Solution #2 Clear any jams on the printer itself
  2. Please make sure that you will not take out any jammed papers in front of the printer, it can cause a mechanical damage on the printer.
  3. At the back of the printer, take out the access door.
  4. Clear any jammed papers, please make sure to clear the rollers.
Solution #3 Please make sure that the carriage will moves freely
  2. Open the cartridge access door
  3. Disconnect the power cable at the back of the printer.
  4. Check for any paper or other object that might restrict the carriage movement.
  5. Reach inside the product through the cartridge access door, and then manually move the carriage.
  6. Remove any paper or objects you find that restrict the movement of the carriage.
  7. Make sure the carriage can move freely across the width of the product. Firmly push the carriage to the left, and then to the right.
  8. Close the cartridge access door.
  9. Reconnect the power cable to the rear of the product.
  10. Press the power button to turn on the printer.
  11. Print test page using the printer itself (press and hold the OK and HELP buttons on the front panel of the printer, until it will prints a test page, then release the buttons.)
If your still having issues with it you need to contact HP to have your printer replace, if your printer is still in warranty you don't need to pay for anything, but if the printer is out of warranty charges may apply. 1800-474-6836
Good luck :)
Posted on Feb 17, 2011
Testimonial: "Thanks a lot, I found a tiny piece of paper that was preventing the carriage from moving freely."
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
Computer says paper jam in printer but printer will make copies
Welcome to the ever popular-widely experienced world of:
PAPER SIZE MISMATCH!!!
YES! That wonderful world where unbeknownst to you but knownst to us (OK I watch Spaceballs WAY TOO MUCH) When you are sending a print job, somehow the paper size setting has been changed. Either in the printer itself, or in the print properties settings in your OS.
Double-check those paper size settings and try to print. If it still happens, try resetting the print settings in the printer back to factory default. Make sure you print out the printer configuration before resetting in case you need to reinstall those settings.
Nov 06, 2013 | HP PSC 1401 All-In-One Printer
HP Officejet 4215v All-in-One paper jam
MOST LIKELY THE PRINTER IS WORN OUT MAKE SURE YOU CHECK THE BACK OF THE PRINTER FOR A CHAMBER THAT YOU CAN REMOVE TO SEE IF THERE IS PARTS OF A PAPER STUCK INSIDE THERE
Feb 12, 2018 | HP Officejet 4215v All-in-One Printer
My cannon MP160 pixma keeps telling me there is a paper jam when there is no paper in it, it will copy and give me color tests printed out but if i try to print a doc. It says E# paper jam
To solve it
Feb 07, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Says a front paper jam but no paper jammed any where
Your paper feder belt has ink on it and will not feed the paper. Remove the rubber belt and clean it good and clean and use compressed air on the printer tray area. If this does not work open the front feeder tray and set your computer to print from it. After about 500 copys it will normally have c leaned itself and be ready to feed from the main roller.
Feb 14, 2010 | OKI C5500n Printer
Canon iP 1600 printer won't print. Says that
Hi
If it keep saying paper jam Then it maybe just that you may not see any paper in it but it only takes a very small bit of paper that stopping it or I would take a closer look inside, you may have had a paper jam before and it has left a small nit inside. All Best: Pineworks
Feb 01, 2010 | Canon PIXMA iP1600 Printer
Message says Paper Jam, but there is no paper
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 25, 2009 | Brother MFC 420CN All-In-One InkJet...
Dell 810 All-In-One InkJet Printer Logo
230 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
