Question about Kenmore 65924 Electric Dryer
How to i open a kenore dryer to clean it
How do i open the dryer to clean all the lint out
  • Jim London
    Jim London May 11, 2010
    Hi, Do you mean the lint trap or inside the cabinet or where exactly?
    Genius:
  • 1,122 Answers
Is your lint screen on top or inside?mike
Posted on Mar 01, 2009
How do I clean lint from inside GE Harmony Profile Dryer?
You have to remove the panel. The assume the lint filter works better then they usually do and do not make it easy to open up and clean inside. You may have to open it from the back side which does open up to allow repairs, etc.
Aug 12, 2014 | GE Profile Harmony DPGT750ECPL 7.3 Cu. Ft....
Dryer heats but clothes wont dry and have checked lint screens front and back. How much "air flow" should be coming out the back of the dryer?
Do not use this dryer until you fix it. You need to check the pipe or flexible tube that comes out of your dryer (where the hot air comes out). Even though you clean your dryer lint trap some lint gets by. If you can get to it, go outside and find the opening where the dryer air comes out of your house. Then open the little door and look inside but not when the dryer is running. If there is any lint inside clean it out. Then disconnect the air outlet from the back of the dryer and inspect. It should be free of lint. If it is full of lint clean it all out. You can also call a pro to perform the inspection and cleaning. Good luck.
Jan 16, 2014 | Dryers
I own a Bosch Nexxt Series Electric Dryer, the clothes come out with a petrolium smell, grease or something. I have cleaned the trap, duct work, bearing shield to no avial. It is not the washer, the
Instructions
Dryer Does Not Turn On
Ensure that the dryer's power supply cord is firmly plugged into an electrical outlet.
Inspect the structure's fuse box for a tripped fuse. Each fuse is assigned a single "On/Off" switch. If any fuse switch is in the "Off" position, flip that switch to the "On" position. If the problem persists, contact a professional electrician.
Press the "Start/Stop" button on the left side of the dryer's control panel.
Close the dryer door firmly so that the door clicks into place. The dryer will not operate if the door is not shut.
Lint Filter
5
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull the lint filter out of the dryer. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then reinsert the filter and close the door.
6
Turn the dryer off and allow at least 30 minutes for the dryer to cool, as excessive heat can cause a drying program malfunction.
7
Increase the ventilation of the room the dryer is located in, such as by opening a door or window. Excessive heat will cause the dryer to automatically turn off until it cools as a safety measure. Increasing the ventilation will help keep the dryer cool.
Clothing Not Fully Dry
8
Clean the moisture sensor. Open the dryer door to access the moisture sensor. The black-colored sensor consists of two bars, and is located at the front of the dryer's tumbler, to the left of the lint filter. The sensor should be cleaned with a clean cloth and white vinegar once per month.
9
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull out the lint filter. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then insert the filter back into the dryer and close the door.
10
Spin the laundry at a higher spin speed in the washing machine before placing the laundry into the dryer to reduce the moisture content.
11
Turn the dryer off and allow at least 30 minutes to pass for the dryer to cool, as excessive heat can cause a drying program malfunction.
Jan 09, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
I have a lg tromm dle2514 dryer and the check filter light is on. I am willing to clean it (I've already cleaned the front filter area) I just have no idea where there is another filter
There is no other filter to clean other then the one lint filter.
I would check the dryer vent to make sure it's not restricted with lint build up or has any kinks in it. Also check the outside flapper at the end of the dryer vent to make sure it's clear of lint and able to open all the way.
If your dryer vent is ok and the lint screen is clean then I would remove the front of the dryer and check the blower/fan housing for lint build up.
Aug 04, 2011 | Dryers
LENT SCREEN SEEMS TO LET LINT BY IT LINT IS BLOWING OT THE BACK
Maybe you need to do a cleaning. open the dryer up and clean out the lint. Use this GUIDE
Jan 15, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Clogged lint inside dryer exhaust
there is a vent cleaning kit that can be baught at lowes or home depot and comes with attachments to get down inside the lint trap to be vaccumed out.
you can also lift the lid and remove the front panel and get to the trap area
Mar 28, 2010 | Whirlpool LER4634J Electric Dryer
Kenmore Elite HE4 does not dry the cloths all the way.
if dryer is filled with lint or vent line is blocked the clothes will not dry correctly,shop vac is great for this it sucks and blows,vac out what you can see and then blow out the lint from back and on motor,clean out the lint duct,where ever you pull out your lint filter either on top or inside dryer you have to clean out the duct.now go outside and check the flapper,if it isn't blowing open or hardly opening i use a leaf blower and take off the vent line from the back of dryer and blow it out,good luck
Nov 02, 2009 | Kenmore Elite HE4 Electric Dryer
Odor around the lint trap, cleaned but persists
The lint trap is an opening into the dryer vent and vent pipe. The dryer needs to be pulled out from the wall, the vent pipe disconnected and then the back of the dryer and the entire pipe cleaned of lint and other debris. this is the only way to get rid of the odor.
May 20, 2009 | Dryers
I opened dryer and found burned lint. There was about a half inch of material around the heating elements that had also started to burn.
clean the lint out and make sure the coil is undamaged. dryers need to be taken apart and lint cleaned out once in a while. also clean the exhaust line out real good as too much lint can increase the back pressure, not letting all the lint out of the unit.
Apr 28, 2008 | Dryers
Kenmore 65924 Electric Dryer Logo
74 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
