Question about Whirlpool GHW9400 Duet Washer
Whirlpool GHW9400PT0 won't run unless I unplug and then plug in
This front-load washer will only run if I unplug and then plug in again. I tried opening and closing the door between each load, but I still get 3 beeps and the washer doesn't start when I press the start button. Help, please :) The model is a GHW9400PT0 Thanks for any help you can provide.
  • 16 Answers
SOURCE: Front load Whirlpool Duet
Hi, Has the door catch,which protrudes and goes into the hole, broken off, it should have a sort of hooked end. Tom.
Posted on Mar 15, 2007
  • 249 Answers
SOURCE: GHW9300PW/Dove Grey on White - Whirlpool® Duet® Ultra Capacity Plus Washer
are you sure about the door switch, thats all I think it can be.any lights on ?
Posted on Dec 08, 2007
  • 1028 Answers
SOURCE: Whirlpool 9400 Front Loader Washer Control Button Locked
find button with lock emblem beside it hold 3-5 secs
Posted on Oct 09, 2008
SOURCE: Whirlpool Duet won't start
I had a similar problem on my Whirpool Duet Washer model GHW9150PW0. I found the solution here (Scott says his wire was cut, but in my case one wire of the control ribbon cable was frayed because it had fallen out of its holder and onto the tub assembly, part of which is so coarse that it ate through the insulation and wire by friction during the spin cycle). A quick splice of the wire to close the circuit and some tape to keep the cable from falling out of its holder and away from the vibrating, coarse tub assembly did the trick.
- George
Posted on Nov 01, 2008
  • 1028 Answers
SOURCE: whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Posted on Nov 19, 2008
What to do about FH error on Whirlpool Duet washer?
unplug the washer to clear the board.turn on the water after one min. plug back in and try again
Sep 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer model WFW9050XW00 - Machine stopped still loaded and with door locked. I was able to unlock and remove clothes leaving water and heavy suds. Tried running drain-spin and...
Your pump is jammed with a blockage, remove the filter and check the pump behind it is revolving, usually a hair grip or button in there...remember the washer is full of water so you will have a lot of water coming out
Sep 05, 2017 | Whirlpool Duet GHW9150P Front Load Washer
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My LG front-loading washer WM2501H drum light comes on at the end of the cycle and won't shut off. Additionally the control buttons cease functioning. If I unplug the machine and plug it back in, the...
I am having this same issue. I have to unplug and replug back in every wash. Very annoying. Especially because I am short and can't reach the plug without a step stool.
Sep 12, 2011 | LG WM2501H Front Load Stacked Washer/...
Our whirlpool duet keeps throwing F21 codes we cheked the drain its clear so we unplug the machine and try to run a load again and it throws it again!! UGH PLEASE HELP
Hi Renee from retired Englishman in SW France,
Whirlpool's 'F21' (and 16,18,20 and 22) stands for 'control unit failure', sorry ;-0(
It could be just poor contacts/plugs/sockets but certainly needs an engineer's visit- sorry again ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When push the start button it will run for a minute and then beep the display window will read f 11
The MCU motor control unit is at fault.
Unplug the washer for 60 seconds.
Plug it back in and try again.
If the fault reoccurs,replace the MCU.
Apr 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code nf shows on my washer
unplug for 15 mins and plug again to rest
Sep 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Duet Front Loading Washer Won't Turn On
MY WASHER WAS DOING BASICALLY THE SAME THING. I HAVE A WHIRLPOOL FRONT LOADER MODEL #GHW9460PL0. MY HUBBY REMOVED THE 3 SCREWS FROM THE BACK OF THE WASHER, UNPLUG IT FIRST, AND TOOK THE TOP OFF. WE THEN CAREFULLY UNPLUG THE WIRES AND REPLUGGED THEM BACK IN 1 BY 1 SO U WONT GET THEM MIXED UP. WE THEN TRYED IT, AND THE CONTROL LOCKED LITE STAYED LIT. HE HELD THE SIGNAL CYCLE BUTTON IN FOR 3 SECONDS AND THE LIGHT WENT OUT. WE THEN TRYED RUNNING A CYCLE AND SO FAR SO GOOD!! GOOD LUCK!
May 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer is reading an error code "SuD"
First thing I Would do is unplug the washer for about 5 minutes and then plug it back in and try running a load as normal. If it errors again, make note of the error code and when replying, olease supply the complete modle number listed on a label on the area where your door closes against. If we can help futher, we are here. Eric
Feb 13, 2009 | Whirlpool GHW9100L Front Load Washer
Washing Machines Logo
127 people viewed this question
Dan Webster
Dan Webster
Sal De
