Question about Haier ESD400 Stainless Steel 24 in. Built-in Dishwasher
Where is the back fuse located at in a Haier esd400?
I installed a NEW haier esd400 dishwasher and there is not getting power to the door unit. I called the Technician, and they said to check the back fuse in the unit. Were is the "back fuse" located?
  • 29 Answers
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
Location of thermal fuse on intergrated whirlpool 722 dishwasher
Are you talking the thermal fuse for the control it is located in the control panel behind the door panel
Feb 14, 2014 | Haier 24 in. ESD100 Built-in Dishwasher
Haier rrtw18vabw refrigerator is not working. Think I burnt the fuse. Trying to find out where it is located?
There is no built in fuse in refrigerator. Check the power plug with an ohmmeter,and the start relay of the compressor.
Dec 31, 2010 | Haier RRTW18VABW (18.2 cu. ft.)
Where is the best place online to get Haier dishwasher parts?
http://www.haier.com/products/more.asp?epcID=6
Follow the ;inks on their global web page....cheers.
Jul 26, 2010 | Haier ESD400 Stainless Steel 24 in....
Settings buttons partially work and will not start
Basically, the Haier is a piece of ****. Parts are not available and the phone-in service (if you can call it that) will keep you on hold endlessly. Do yourself a favor and get a better machine.
Apr 19, 2010 | Haier ESD400 Stainless Steel 24 in....
Dishwasher will not power on.
Did you ever get this fixed. Mine just started doing this a few days ago.
Apr 17, 2010 | Haier ESD300 / ESD301 Built-in Dishwasher
Haier Dishwasher hdp18pa - Power reset
Are you blowing a fuse or throwing a breaker? Either way there is a chance that no outlet you have chosen to test with yet is on a circuit with sufficient amperage-I had this with a microwave I recently had installed. If you have the manual, check for requirements regarding amperage. You then need to be sure you are using an outlet with amperage comparable to the requirements-this is on your fuse or breaker. If your requirement is, say, 20 amps, a 15-amp or less breaker or fuse is going to fail. I had to go to a 'clean' circuit from my garage with nothing on it to find out I did not have enough amps in my circuit. My solution was a dedicated breaker. Another option is to use my second option (which I did not need), to plug it into a gas generator with sufficient wattage/amperage. This ensures nothing else is on the circuit.
Failing all that, it could be the power supply for the washer, a circuit board issue, etc. Don't mess around if you don't understand electricity, though-it's not worth frying yourself.
Finally, if it worked ok before and this has just begun to happen, I'd tend to think it's an issue with the washer itself. Hope this helps.
Jul 07, 2009 | Haier HDP18PA Stainless Steel...
Haier dishwasher wont run and shows a code OP
Did you every get your this problem solved? I am having the exact same problem
Jun 10, 2009 | Haier ESD400 Stainless Steel 24 in....
Haier buttons not working!
From previous experience, I would bet that the circuit board/ control panel is failing. The one I had leaked steam near the top of the unit and the condensation will work it's way into the top control panel. Bad design on Haier's part. The worst part about mine was there is no adjustment for the door. I ended up getting a refund on the unit and buying a very nice LG model. Good luck dealing with Haier. They will send A&E factory Service out and they are not very good. I would suggest getting rid of the Haier. (personal opinion)
Jun 01, 2009 | Haier ESD400 Stainless Steel 24 in....
Open the dishwaser while still filling now keeps going to error
After reading a few of the other Haier models troubles, I pulled the unit out and tip it at 45 degrees backwards for around minute. Water pored from the back of the unit, once cleaned water up reinstalled unit and all seems to be back in working order.
May 16, 2009 | Haier Dishwashers
Haier ESD400 Stainless Steel 24 in. Built-in Dishwasher Logo
508 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Melissa Martin
Melissa Martin
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
